I have downloaded winpower and installed it, I see the "Device Status" as "no connection" for my computer. I am getting following error message when i click on search the devices. Communication Lost: check connection and port setting. Please suggest. Thank you, Karuna
SOURCE: Communication between computer and device
See the following topic for solution:
http://www.fixya.com/support/t404303-cannot_see_estimated_ink_levels_printer
Posted on Jun 07, 2008
SOURCE: the device is not ready
have you tried to remove and reload the drivers?
this could also be an issue with the USB cable itself
when you are not transfering any infomation to the printer or computer the cabble can handle it but when you start to transfer the information the cable could get overloaded it has happend to me. after i switched the cable it worked fine
Posted on Dec 09, 2008
SOURCE: Can't scan documents
For the system to work completely; you need the print driver, scan driver and smarthru4.
Once you install the scan driver (available on Samsung website); the issue will go away.
Also, another trick; instead of using the smart thru - which is kind of awkward, download Picasa 3 and if you have installed the scan driver correctly, you can use Picasa to import the scans by controlling the printer. It also allws for some other tweaks that are not so easy to get to in Smart Thru.
In addition to Picasa you can use several other graphic applications to scan the image.
Good luck.
Posted on Jan 26, 2009
SOURCE: Printer status -- Printer power off Communication error/printer mismatch
Had this exact problem after motherboard smoked and transferred hard disks to a new system. The printer installed fine on a different machine which was comforting, and would be a good test to run.
Turns out deleting the printer isn't enough. Wound up reinstalling the driver. That's a pretty obvious next step but the 1350W driver installer apparently does things its own way so if the windows add new hardware wizard comes up you MUST cancel it. Not sure which of these steps are required and which are not, but here's what I did to the best of my recollection ;-)
0) Turn off the printer.
1) Delete the printer (all instances of 1350W) in printers and faxes.
2) In add/remove programs delete the Konica Minolta application.
3) Reboot (this was always a key step in Win98 reality, not sure if XP requires but it can't hurt.)
4) Turn on the printer. If at any time the add new hardware wizard comes up, just say no.
5) Run setup from the driver CD. If you don't have the CD you can get it from KonicaMinolta or CNET (download.com).
6) For me it defaulted to LPT1 but I chose USB001 from the list.
7) If it throws an "error adding service" message don't panic. That may be why there was a problem to begin with (the error, not necessarily the panic.) This happened to me but clicked OK and after several seconds the installer resumed. Next thing I knew was prompting me to add paper.
The error message (for Googling purposes) was:
Error Adding Service
File: MLPTDR_Q.SYS
Dependencies: +Parallel arbitrator
Load Order Group: Extended base
dwServiceType: 1
dwStartType: 2
Hope this makes someone's day.
DaveWasHere
Posted on Aug 03, 2009
adnanbhatti
  • 1188 Answers
SOURCE: A USB device has exceeded the power limits of its hub port
Windows display this message when a USB device is short-circuited. Try another USB cord or connect the usb to the port at the back of your pc. If it does not help then the problem resides in the printer. I will not suggest to dismantle your printer as there are no user serviceable parts inside.
Posted on Aug 10, 2009
Update 1st time
Make sure that you are using the latest version of MyDrive Connect.
Connect your navigation device to your computer and switch on your device.
MyDrive Connect starts and automatically checks if a newer version of your map is available. If you are entitled to the Latest Map Guarantee, MyDrive Connect offers you the latest map.
Click Continue and follow the on-screen instructions to download and install the available map.
Once the installation is complete, the installation screen will close and you are re-directed to the My Content page. Also, the status in MyDrive Connect changes to Connected.
When you see the MyDrive Connect icon on your computer and the message on your navigation device that the installation has completed, disconnect your navigation device from your computer.
your device has been updated
Apr 18, 2015 | Tomtom Start 20 Europe
I am unable to scan a document to save and them pull it up to a word processing program in order to edit it. I am using hp, 1200 series, version 2.10. Is there a version that would allow me to do...
If you want to edit a scan in a word processor, you'll need another program called OCR: optical character recognition. This program reads the scanned bitmap, tiff or jpeg, and converts it to text.
Whether or not an OCR program was bundled with your scanner or not is another story, and typically expects that you will use your existing scanner software to save an image to disk somewhere, in a format that OCR will understand.
You may wish to clarify whether the problem is the scanner (unable to scan), the driver that came with it (unable to save), or the OCR software (unable to export to word for editing).
Sep 15, 2008 | HP Office Equipment & Supplies
I get a pop-up ballon that says "USB device not recognized"
How do I fix Error: TI-89 Detected, but could not get status with the TI-89
using the TI Connect software for Windows?
The Operating System (OS) will need to be updated on the TI-89 in order for the TI Connect™ software to detect the status. Try the following procedure to install the OS from the TI-89 Boot Screen. Make sure TI Connect 1.6 is installed on the PC.
• Connect the TI Connectivity cable to the TI-89 and the computer.
• Do not start the TI Connect software.
• Download the TI-89 v2.09 OS onto the PC's desktop.
**Force TI-89 into "Boot screen" (See instructions below**
• "Press I to install..." ([ALPHA]. [ 9 ]).
• Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader.
• Follow the on-screen directions to install OS version 2.09.
The download should begin.
**Steps for Boot Screen:**
• Take one AAA battery out, press and hold down the Apps key while reinserting the battery to force device into the Boot Code screen.
• "Press I to install..." will appear.
Once the OS has completed installation, the TI Connect™ software will be able to detect the TI-89.
Mar 01, 2008 | Texas Instruments TI-89 Calculator
I had to reinstall the software for an HP 3390 on a Windows XP workstion. The device can print and fax. However, when I try to scan a document I get the following message: The HP imaging device could...
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP LaserJet 3390 All-In-One Printer
I get an eror message status Oxc00000e9 what does
There are 3 step to repair oxc00000e9 error
If you got oxc00000e9 error then there is a 94% chance that your computer has registry problems. To repair oxc00000e9 error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair oxc00000e9 error.
Here are the url of Perfect Optimizer:http://www.nomoreerror.com/tidpp-oxc0000… Source(s): http://www.nomoreerror.com/tidpp-oxc0000…
Nov 24, 2009 | Acer Aspire 5050-3371 Notebook
Ti 89 detected but couldn't get status
Here is what the FAQ and Knowledge Base area of the TI site has to say about the problem you are having. Hope it helps.
How do I correct the error message "TI-83 Plus or TI-89 detected, but could not get status" using the TI Connect software for Windows®?
The Operating System (OS) will need to be updated on the TI-83 Plus family or TI-89 calculator in order for the TI Connect software to detect the status. Try the following procedure to install the OS from the TI-83 Plus and TI-89 Boot Screen. Make sure TI Connect 1.6 is installed on the PC.
If using a TI-89 calculator:
• Connect the TI Connectivity cable to the TI-89 calculator and the computer.
**Force the TI-89 into the "Boot screen" (see instructions below)**
• "Press I to install..." (press the [9] key).
• Take one AAA battery out, press and hold down the [APPS] key while reinserting the battery to force device into the Boot Code screen.
Once the OS has completed installation, the TI Connect software will be able to detect the TI-89.
Oct 31, 2009 | Texas Instruments TI-89 Calculator
Won't scan or copy
Solution
These errors are usually caused by a failed scan, a bad installation, communication problems or software conflicts. Follow the steps below until the problem is corrected.
Step one: Restart the computer
Close all programs and restart the computer. A required task might have stopped running or the system resources might have decreased due to tasks left running. Restarting the computer will refresh all Windows tasks as well as increase the available system resources.
Step two: Check for the correct entries in the Device Manager
Verify that the unit was installed on a DOT4 virtual port in the Device Manager.
  1. Right-click My Computer , and then click Properties .
  2. Click the Device Manager tab. (In Windows 2000 and XP, click the Hardware tab , and then click Device Manager .)
Check the list of installed devices for references to DOT4. If there are no DOT4 references, the software has not installed correctly.
If any of these entries are missing, the software did not install properly. Review the information in the HP document Troubleshooting Installation Issues for USB-Connected HP All-in-One Products in Microsoft(R) Windows (bpu01858) for installation assistance.
Step three: Check for communication problems between the all-in-one and the computer
Communication might have failed between the all-in-one and the computer. Review the information in the HP document USB Connected HP All-in-One's Software Reports a Disconnected or an Error Status (bpu01859) to check for communications problems between the HP all-in-one and the computer.
Step four: Check the computer to see if it is infected with a computer virus
If the all-in-one prints but will not scan correctly and does not show any symptoms of communications problems, the computer might be infected with a virus. Some viruses try to disable virus scanning software and in doing so disable scanning from the all-in-one. The following are symptoms a virus problem:
  • The scanning software works after installing the all-in-one software until the first time the computer is restarted.
  • In the Device Manager, opening the Properties of the Imaging Device entry will reveal a status of "code 19" or "code 28".
  • A Scanner Cannot be initialized error occurs. While this error may other reasons, a virus will cause this error.
When the all-in-one is turned on and connected, follow the steps below to see if this is the problem:
  1. Right-click My Computer (click Start first in Windows XP) and then click Properties .
  2. Open the Device Manager:
    • Windows 98 and Me: Select the Device Manager tab.
    • Windows 2000 and XP: Select the Hardware tab, and then click Device Manager .
  3. Locate the Imaging Device entry and click the plus (+) beside it. It may have an exclamation mark beside it.
  4. Right-click the all-in-one entry under Imaging Devices, and then click Properties .
  5. A Properties screen will open. Look at the Device status section.
Hope it may helps;.
Regards, VOTIT
Sep 20, 2008 | HP Photosmart C4180 All-In-One InkJet...
ERROR: code 28 -- Windows XP & USB 2.0
I'm unable to connect my western digital hard drive to my Windows XP computer via the USB port. When I check the USB 2.0 Controller in the Device Manager, there is a yellow exclamation mark (!) next to it. When I check on the status of the USB 2.0 Controller, the following message appears:
The drivers for this device are not installed (code 28).
What do I do now?
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
I'm cannt to connect my digital camera to my windows via USB port. after this, I received message : The drivers for this device are not installed (code 28), what can I do?
Thx...
Sep 21, 2005 | Polaroid PhotoMax Fun 620 Digital Camera
982 people viewed this question
jasbo
jasbo
