Question about HP 2009M Monitor
I have an HP2009 wide lcd monitor. Lately, when clicking pages, the screen flashes a black background with the text in white before resuming normal output. It almost appears as an x-ray image. The problem is worsening as the x-ray image now appears even when I am not changing pages. Any idea what the problem might be? Thank you, Bob Renzi
MUKHTAR
  • 2017 Answers
SOURCE: All copies and scanner outputs result in a totally black image
i is problem with your scanner if you ablt to open it and just apply little bit servicecing for your scanner head rod or ypy can show it service peronnel.
bye
Posted on Oct 16, 2007
SOURCE: 2605dn prints red background randomly
From the Adobe support web site:
Solution to the red box problem:
http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=kb400692
Posted on Jan 21, 2008
Fix-4U
  • 293 Answers
SOURCE: Hp F1703 LCD Monitor gray/white Screen
Hi...there,
It's seems you got a busted AD board... Need to replaced a new one or replaced a new bios...
Posted on Nov 29, 2008
RyMS
  • 63 Answers
SOURCE: Black Bars each side of my new monitor wide screen
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
Posted on Jan 30, 2009
SOURCE: LCD Display Blank
When the camera is turned on, the LCD diaplay screen is blank (dark
Posted on Feb 06, 2009
Black background web pages
Step 1:
Web Pages That Do Not Display All Colors
Web pages that do not display all the appropriate colors have either a browser-related issue, monitor display problem, Windows comparability glitch or incorrect web pages Internet and HTML settings. More than likely, a setting dealing with your contrast ratio in Windows is the culprit. Once this issue is resolved, your web pages will display properly and accurately like they were designed to from the start.
Click on "Start" and navigate to the right pane and click on the "Control Panel." Click on "Ease of Access." Click on "Ease of Access Center." Click on "Set Up High Contrast" (one white and black box overlapping each other.) Check or uncheck "Turn on or off High Contrast when left ALT + left SHIFT + PRINT SCREEN." Click on "Apply" and close the Ease of Access Center. Press "ALT + left SHIFT + PRINT SCREEN" to turn on high contrast. Open your browser and go to a website to determine if color is restored to normal.
http://en.kioskea.net/faq/60-white-background-s-problem-in-web-pages
Feb 05, 2013 | Microsoft Internet Explorer 7
My Acer AL1717 Screen has turned Blue......I just want to know how to Turn it back to normal colour.....Anyone can Help??
hi,
reset your monitor color setting by the following setting
Press the menu button
Select Reset
press enter
this will reset the monitors color setting to factory default
ok
Jan 19, 2011 | Acer AL1717 17" LCD Monitor
I thin k I am having back ilight and/or inverter program with my HP dv6275us Notebook based on the following: - machine powers on but o video or image on screen or image is extremely faint. Upon closer...
These are typical symptoms of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
As for the cost, I would suggest a search on ebay.com
Sep 06, 2010 | HP Pavilion dv6275us (RP284UA#ABA) PC...
When i plug the monitor into my computer the flashes Benq only!
Try connecting the monitor to a different computer, e.g., a laptop.
The power-cord to the monitor seems to be OK.
Check the "data" cable between the monitor and the computer -- try a different cable.
With the monitor turned on, restart your computer, and watch the monitor. The computer should show some start-up messages (white text over black background), followed by the Windows "splash" screen. If it does, the monitor is working correctly.
Jul 03, 2010 | BenQ FP737S-D 17" LCD Monitor
SyncMaster 213T Screen quality
did you try change the VGA cable? if not, try it.
Dec 19, 2009 | Samsung SyncMaster 213 T 21.3" LCD Monitor
Normal screen is white background, but lately I am getting a blue tint that clears up sometimes and sometimes not. Please advise
Try hooking up another knowng working monitor to the computer and see if the blue tint comes back intermittently.
If it still comes up then you know your video card is the culprit. If the blue tint goes away then you know the original monitor is bad.
Aug 04, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
LCD Monitor pixels that should be black are white
The contrast of the monitor is very low. reset the monitor settings using the menu button in the monitor.
Apr 17, 2017 | Sony STYLEPRO SDM-S71R/B (Black) 17" LCD...
Computer Turn then a flash of white type with a black background
connect your machine in an external monitor to check if the display is okay on the external monitor. if yes, the problem would the the LCD screen from your laptop. you might need to replace it. also, check if the video driver is correctly installed. if not, re-insatall your video driver. if there's no display on both panel i suspected it's a motherboard faulty.
May 25, 2009 | Computers & Internet
Stripes appear on monitor at bootup
I decided to change the background of my desktop and it works.
May 14, 2009 | Gateway FPD1760 17" LCD Monitor
Monitor image size
There is nothing wrong with the monitor, the issue is that the web page you are looking at is designed for a lower resolution than you LCD is set for (Web pages are normally designed for 800 x 600 or 1024 x 768) you like have a wide aspect ratio monitor.
As I sit here writing this on my 12" wide aspect LCD I have a 2" wide white space on each side of my screen due to my 1280 x 800 aspect ratio.
The issue is one of WEB PAGE DESIGN not the fault of your computer video settings. The web page is written using page frames and fixed aspect ration settings to ensure that the page displays properly regardless of monitor type.
If you had a high end LCD (WUXGA 1920 x 1200), the web page would fill the upper left 1/4 of the screen.
If you lower the resolution of your display, then you'll have fuzzy icons and text, so essentially, get used to it.
Eventually, wed design will catch up with current display technology.
Jul 24, 2008 | Computers & Internet
HP 2009M Monitor Logo
107 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
