Question about Dryers
The vent hose is off the wall how to i put it back on? do i use duct tape?
  • gerigash06 Feb 14, 2009
    i have no vent hose on any of the three vent holes can you tell me if i need to fit just one hose or three please
  • 78 Answers
Duct tape will probably work, but you really need to get a vent clamp available at places that sell dryers.
Posted on May 05, 2008
Dryer not drying in alloted time
there is a thermostat. it usually is located on the heating element housing
May 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Clothes aren't drying
Check the vent ducting for obstructions, like lint deposits, insect or birds nests and kinks in any of the flexible duct.
May 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Getting a lot of condensation at wall where the dryer vent attaches, we have moved and the new house has a smaller laundry room. The first time we used the dryer I noticed a puddle of water, checked washer...
My suspicion is that the damper on the dryer vent is not completely closing, allowing the cold air to pass into the house. Also check to see if the vent hose is sealed to the vent with duct tape or steel tape.
Feb 22, 2010 | GE WSXH208A Front Load Washer
Our house is a split level and the laundry room is downstairs. The dryer vent hose goes up to meet the wall, where it goes outside. The vent doesn't take all the lint outside, most of it ends up in our...
Are there crackes in the hose and is it clamped on at the dryer outlet ?
Check also to see if it is pluged up or if the hose came off the connection to vent outside or also the vent flaps are sticking. If you by chance have solid tubes, wrap up the seams and connections with duct tape.
Oct 25, 2009 | Maytag Dryers
The vent for a/c is blowing out of defroster vent. not able to make it come from dash vents
Look under the hood near the condenser. There is a vacuum hose that usually breaks over time. try to put it as closely as you can back into place and place electrical or duct tape around where the air is leaking.
SJV
Jul 16, 2009 | 1999 Dodge Durango
The dual climate control is blowing very cold on the driver side vents and extremely hot(like the heater is on) through the passenger vents. is there something to do to check that unit without taking in...
look under the dash and find the air ducts and put the air duct back on the ac housing that has fallen off and tape it with duct tape so it wont come off again.
Jun 17, 2009 | 2007 Chevrolet Silverado 1500 2WD
Kenmore Electric Dryer Can't replace heating unit
I removed the deflector and duct from outside the house, disconnected the hose, attached the hose to the dryer, passed the hose through the wall as the dryer went back in, then reattached the hose to the duct/deflector and reinstalled the duct/deflector
Feb 09, 2009 | Kenmore 659 Electric Dryer
Outside venting GE Profile Spacemaker XL1800
Your vent flap could be taped or it could be faulty installation not allowing the vent to open. If you take the front vent cover off, you should be able to reach in above the fan unit and gently push the vent flap up, it should move freely with no binding. If it doesn't it is taped or blocked. If it is taped, gently putting upward pressure on the flap might release the tape. If that doesn't work the vent installation is blocking the flap. You might have to remove the unit from the wall (two people to do this) or disassemble the vent duct above the microwave and rework the interface for clearance.
hope this helps,
Sep 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How can I connect my dryer to the vent without crimping the hose? Whenever I connect the hose and push the dryer to the wall, the hose gets holes in it...
The dryer should not be pushed all the way against the wall. For the ventilation to properly work, you should leave about a one foot space between the back of the dryer and the wall. Using 90 degree elbows on the dryer and wall can also eliminate crimping. Also, it is strongly recommended that use use the semi-rigid metal type vent hose ducting. It is not that expensive and comes in adjustable lengths. The semi-rigid ducting is recommended by most builders and it resists crimping and rodent damage. If you continue to use a dryer with the exhaust vent clogged it will lead to eventual heating circuit failure due to overheating. If you have any questions, please post back and let me know. I hope this helps answer some of your questions.
NOTE: If you purchase semi-rigid ducting, make sure you purchased the hose clamps that go with it. This will prevent the hose from slipping off the connection points.
Jun 15, 2008 | Dryers
Dryer takes too long to dry
This complaint is most often caused by the dryer's vent being blocked with lint. Dryers need to be properly vented, otherwise the moisture in the air can't be properly carried away. Vents that go out the roof are particularly problematic-- the dryer may take far too long to dry clothes and the vent pipe may even drip water that can't be exhausted. Minimum size for a dryer's roof vent is 4 inches. If your dryer has chronically poor drying, if possible, have the vent moved to where it exits a house wall near the dryer. The vent should be made of 4-inch aluminum rigid duct and elbows or, where absolutely necessary, flexible metal (but not flexible thin foil). Do not use flexible plastic duct-- it restricts air flow and is combustible. The dryer should vent outside--never into a crawl space, wall, ceiling chimney, or other type of flue. The bottom of the exhaust hood should be located at least 12 inches above the ground. Here is what to do: 1) Check the lint trap and clean it. 2) Be sure the dryer isn't pushed so close to the wall that it pinches off the airflow through the vent's air duct hose. 3) Check the point where the air duct vents away from the house. Be sure plants, birds, or anything else hasn't blocked it. If the duct vents out the roof, it could easily be blocked with lint. 4) Disconnect the air duct hose from the back of the gas dryer and clean out built-up lint. Note: For safety, first turn off the gas to the dryer, then unplug the dryer; this means you will have to re-light the pilot light later if the dryer has one (read your owner?s manual for proper re-lighting techniques). 5) If necessary, clean out the ductwork from the dryer to the exterior wall where it vents; this may involve disconnecting sections. One trick that sometimes makes this job easier (but only if the dryer duct is fastened firmly at all connection points) is to blow lint and debris through the duct and out the exterior wall vent, using an electric leaf blower.
Jan 18, 2006 | AEG T57800 Electric Dryer
Dryers Logo
46 people viewed this question
Top Dryers Experts
