Question about Jack Lalanne Power Juicer 250 Watts
Dont know how to clean screen and under it
Please help with cleaning instructions. screwed up and bought without guide.
  • 4 Answers
I have been given a breville je14 juicer but do not know how to dismantle for cleaning can you help please.
I've found a site that has the instruction manual. It shows the seperate parts and gives a quick overview of which of these parts should be washed before first use. Hope that helps Page 6 of Breville Professional Juicer Instructions JE16 ManualsOnline com
Jan 13, 2015 | Breville Juicers
Manual for Emson Juice Extractor, Model GH-2011
I bought one without a manual today for 2 dollars at a yard sale , blades lock in about a half inch - turn counter clockwise to remove, may need to press down or press button in back. base below comes off too for cleaning - turn clockwise. They may come off hard the first time. the button in the back may help releasing both. Make sure to unplug first. I don't have a manual either, just some mechanical sense.
Oct 07, 2014 | Juicers
INSTRUCTION TO CLEAN AFTER USE
Cleaning the juicer immediately after use makes it really easy to clean. Run few cups of water through the machine while running and make sure to use a bristle brush to scrub the screen with after use.
Aug 10, 2013 | Jack Lalanne Power Juicer (Stainless...
I bought a used one without a manual-I don't know how to take it apart and clean it, and beginusing it, thanks
Rotate the cover to remover it, unscrew the clutch
nut in the center of the blade and lift everything out.
If the juicer is stained, boil the parts in a solution of
Oxi Clean and water for a few minutes. They will
scrub up like new.
Oct 15, 2010 | Acme 6001 Juice Extractor
Do not know how to remove basket
(1) Remove the food plunger and top cover; (2) unscrew the 3 screws from the blade/cutter plate and lift it off its base; (3) Unscrew the plastic base COUNTERWISE and lift it off of the center spindle; (4) Now you can remove the basket and juice bowl for cleaning.
To reassemble, reverse the process.
Dec 29, 2009 | Salton JM411 Juiceman II Elite Juicer
Open to clean juicer maching
http://www.powerjuicer.com/customer-manuals.html
This is the site to download Jack Lalanne's Power Juicer Manuals of all models which include troubleshooting guide, user instructions, cleaning and opening machine.
Jul 13, 2009 | Jack Lalanne Power Juicer (Stainless...
No manual, how disassemble for cleaning;miss platform/extra blade
I just posted this info on an earlier question.
Here's the link to the owner's manual (PDF) you can save or print.
http://www.powerjuicer.com/pdf/express.pdf
FROM THE TABLE OF CONTENTS
Important Safety Information
Helpful Hints
Parts List
Assembly
Disassembly
Cleaning Your Juicer
Troubleshooting
Jan 20, 2009 | Jack Lalanne Power Juicer 250 Watts
Cant grt it apart to clean
Take off the top part of the juicer that has the chute. You will see the blade and basket. The blade appears to be attached to the basket with three small screws but is actually screwed onto the basket by a large screw that protrudes out of the basket underneath the blade. So the trick is to unscrew the blade, turning it to the left by using maybe a small screwdriver that you will have to put into one of the two small holes that are on the blade surface and pushing the blade to the left. This should loosen the blade and then you can just unscrew the blade off the basket. Once you get that blade off, the rest of the juicer comes apart. The newer models come with a little tool with a couple of arms that go down into those holes and loosen the top. Good luck.
Jul 22, 2008 | Jack Lalanne Power Juicer (Stainless...
Can't get filter out?
Well this is September ,so i just got one to,so i dont know if you solved your problem since then,but you never take the screws out the blade to take the blade out you keep screws in and take the vise gripe the black vise grip and put it in the blade while still in the processer and turn it left keep turning it and the whole thing will come off and so you will be able to clean the filter .
Jul 20, 2008 | Jack Lalanne Power Juicer (Stainless...
Jack Lalanne Power Juicer 250 Watts Logo
102 people viewed this question
Top Jack Lalanne Juicers Experts
Greg Cann
Greg Cann
Starnley Johnwells
Starnley Johnwells
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
