Question about Nordic Track NordicTrack Treadmill, A2550
I have a Nordtrack viewpoint 3000, the tv will come on and when I touch the start botton it just beeps.
  • 3 Answers
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. The first few times I would push the bad button until it started beeping. That worked for awhile (couple of weeks but started up again). I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
Posted on Oct 31, 2010
  • 1 more comment
  • layson1080 May 24, 2011
    I have a 2255 nordic track i tried everything then i found this and found the one that didn' t beep which happen to be the place where the sims card for a runing program goes.Unpluged it and everything else works fine .Thanks for the post that helped me.
  • Kirt Adams
    Kirt Adams Mar 02, 2014
    After a million different solutions that didn't seem correct (but, I tried them) This one actually seemed plausible ...and it worked! Reached under the display cover and tore off the wiring-strap that connected the I-Fit to the circuit board ...and PRESTO my C2255 was back up and running. I hated that I-Fit interupting my flow anyways. Thank You very much for sharing this fix!
  • Moheb Maalawy
    Moheb Maalawy Jan 26, 2018
    Worked for me too. Thanks for posting.
Can't access ViewPoint Menu System
try first disconnecting tv from power for 20 minutes and see if problem disappears
Jul 06, 2008 | Mitsubishi WS-55857 55" Rear Projection...
I by mistake from the menu I pressed the hdmi botton. It went blank and I can't get a picture. What can I do?
If you are changing cables or cannot see an image on the screen, you may need to reset the video output to default settings. To reset the video output:
  1. While the PS3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the PS3 beeps a second time (approximately 5 seconds), then release it.
  2. The PS3 will power up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Sep 22, 2014 | Video Game Consoles & Games
I have a Nordic Track Viewpoint 3000, the display quit working although the incline and speed seem to be working just fine. Anything I could try to fix?
Dear Sir:
Please see the attached diagram for adjusting the reed switch, clean very well, and tigh the connector wires.
sincerely. God bless you
Apr 21, 2012 | Nordic Track Exercise & Fitness
My hp-compaq dx2300 microtower restarts automatically when working. It is installed on win xp sp3. Please let anyone help if solution is known.
Hi names Rui, i question for you does your PC give a beeping sound when you turn it on? if does can you tell me how many beeps it gives?
if it give a designated number of beeps this might be the problem i will give you a chart so you can differentiate the warning beeps you hear.
warning beeps:
1 Short Beep DRAM refresh failure
2 Short Beep Parity circuit failure
3 Short Beep Base 64k RAM failure
4 Short Beep System time failure
5 Short Beep Process failure
6 Short Beep keyboard control gate A20 failure
7 Short Beep Virtual mode exeption failure
8 Short Beep Display memory read/write test failure
9 Short Beep ROM BIOS checksum failure
10 Short Beep CMOS shutdown read/write error
11 Short Beep Cache memory error
1 long, 3 short Beep Conventional/Extended memory failure
1 long, 8 short beep Display/Retrace test failed
hope this will determine the problem if none of this warning beep is heard try reseting the power botton in you PC cause sometimes the power botton will loosen cause of continuous use of the botton.
hope this will help you.
Jul 20, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
Will not load game
take it apart (will need a sucrity screw driver) and clean the hard drive.
Apr 09, 2010 | Sony Playstation 3 (PS3) Console
Ps3 i swithch it on at the back press the touch botton at the front it powers up but no sound or visual i'v try differant leads an tv's and tryed holding the front button untill it beeps to reset visual...
Check out my common PS3 problem and repair guide for tips and suggestions for your problem.
Please feel free to email me any other questions and please don't forget to rate!
Feb 24, 2009 | Video Game Consoles & Games
RCA 52 inch Projection purchased in 2003 (warranty just ran out go figure)
Replace front panel board the one with off/on vol- vol+ channel- ch+.
Oct 31, 2008 | RCA P52960 52" Rear Projection Television
Epson GT30000 Document feeder error
if the ready light is off, and the error light is flashing, it indicates an interface error. please check all your cables.
Sep 16, 2007 | Epson GT 3000
Nordic Track NordicTrack Treadmill, A2550 Logo
1,053 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
