THIS IS HOW MY KEY BOARD IS BEHAVING For the following letters "Now is the time for all the good men" It types as below "N^&ow is the time for all the good men67" The alphabets are a b54 c d e f g h i j k l m n67 o p q r s t u v w x y z Block letters by pressing caps lock A B54 C D E F G H I J K L M N67 O P Q R S T U V W X Y Z Block letters by pressing shift key A B%$ C D E F G H I J K L M N^& O P Q R S T U V W X Y Z For the following figures "1- 2 - 3 - 4 - 5 - 6 - 7 - 8 - 9 - 0" It types as below "'1/-0 3/-0 b54 /-0 b54 /-0 n67 /-0 n67 /-0 =8 /-0 9‌" SPECIAL CHARACTERS For ~ it types "~!" For ! it types "~!" For @ it is typing n67othin67g here b54ut opens the Windows help and support Menu For # it types # For $ it types "B%$" For % it types "B%$" For ^ it types "N^&" For & it types "N^&" For * it types "+*" For ( it types "(" b54ut opens the edit menu as well For ) it types "?_)" For _ it types "?_)" For + it types "+*" For | it types | For \ it types "\" For pressing the Delete key it immediately shuts down the computer For pressing the Right arrow key it shuts down to change the user For pressing the Left arrow key it does nothing For pressing the Down arrow key it shuts down the system
colliewob
  • 781 Answers
SOURCE: Need to disable a key on my keyboard
check your keyboard in
Start/settings/control panel/keyboard right click open check what options available you may be able to stop key working
Posted on Jul 24, 2008
  • 70 Answers
SOURCE: Problem with sony vaio keyboard
Sounds like you've got something stuck under your shift key. Carefully clean out under the keys, try a paintbrush and a hoover (on low suction if possible).
Be careful not to knock any of the keys off. They're held on by small clips which pop out or break easily.
Posted on Aug 22, 2008
  • 153 Answers
SOURCE: Product Key Help
Do not use a keygen. Download and install this: http://www.belarc.com/Programs/advisor.exe and it will tell you what your key is. Write it down, but more important copy/paste it into the activation screen so things don't happen like putting in the letter o instead of numeral 0, transposing letters and/or numbers and the like.
Posted on Apr 22, 2009
  • 22 Answers
SOURCE: shift key shuts down my computer
Someone is probably playing a prank on you. Disable the services one by one until you find the program that is assigning those programs hotkeys so programs can't run with hotkeys.
Posted on Jun 08, 2009
SOURCE: keyboard stuck in upper case
press caps lock and F9 together see if that fixes it
Posted on Oct 27, 2009
User name and password for login as administrator
Go To SERVICE MODE
How to go SERVICE MODE Follow Below methods..
  1. Press Asterisk* (Look like men head and star inside the men head people called as)
  2. Press 2 & *8 (Press two keys at a time)
  3. Press Asterisk* (Look like men head and star inside the men head people called as)
  4. TOUCH COPIER
  5. TOUCH FUNCTIONS
  6. TOUCH CLEAR
  7. TOUCH PWD CLR
  8. OK
  9. POWER OF THE MACHINE
  10. AND ON THE MACHINE
Apr 25, 2016 | Canon 3225 Copier
How to unlock keyboard?
press numlock button once
Mar 04, 2015 | Computers & Internet
Why does the printwheel make letters other than what I type
You didn't give a model but check if there is a slide switch on he left of the key board labeled 15, 12. 10, & PS it should be in 10 or 12.
DickyO
Sep 21, 2014 | Olympia Office Equipment & Supplies
My m &n keys want work
if you plug in a usb key board and the m & n key works in notepad then your keyboard is ok.if it still doesnt type the letters then you should replace keyboards
Aug 01, 2014 | HP Computers & Internet
My SimpleDrive 320 is being recognized as "storage" with no drive letter designation. Ideas?
Connect harddrive to computer then when you power up the computer press F8 key 5 to 6 times then enter in safe mode then if still letter will not assigned then follow below.First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Apr 11, 2011 | SimpleTech 320GB SimpleDrive External by...
I have sony vaio EB series laptop, my problem is that when I type 1 it type 21, when 3 it type 0.3, when 1 below f1 key it type 1 and open help window. there are other similar keys behaving same way. I got...
Hello
If the new keyboard is behaving same, then try to plug in an external keyboard to see if that works okay. You can use any USB keyboard. If this keyboard works, you have a hardware problem and need repair from Sony Support.
Hope this helps, Good Luck
Dec 31, 2010 | Sony VAIO VGP-WKB1 Keyboard
How do i change my phone from numbers to letters
I am not sure about the brand & model number you are using. But in NOKIA phone you need to PRESS # for more than 5 Seconds then it will change to letter, word & vice versa.
Thanks...!!
Oct 17, 2010 | Lands Phones
Samsung txr3079 adjustment problem: I have a TXR3079 CRT HDTV (chassis type K62B). I replaced the deflection board to stop a whining/noise problem that seemed to be coming from a transformer next to the...
ow voltage i missing one of the diodes in ow circiuts is faulti ,bad,or the resistor between ow transistor and ow diodes is open, bad,or ow transistor is oc
Mar 03, 2017 | Samsung TXR3079 TV
Letter key on our keyboard doesn't work when you type on it
if handy with tools you can open KB an check all traces are good
if not need to use a HB pencil to re-trace grid @ non-working key
May 08, 2009 | Computers & Internet
How to make logitech keyboard & mouse work??
Hi there: I was also facing the same problem. But when you see on back of the keyboard the instructions are there. or follow these steps.
1. insert new batteries both in keyboard and mouse. 2. decide what device you want to connect 1st (Lets connect Keyboard first) 3. Pres and Hold the connect button for both key board and receiver for about 5 secs. 4. don't press any key on key board till 10 secs (During this time it trying to connect with receiver) 5. Check the key board connectivity if it works then take it away or put it behind some barrier so that when you are connecting the mouse it don't interrupt. 6. now for the mouse do the same process as you have connected the keyboard.(step 3 & 4) 7. now check both key board and mouse they will work fine. Thanks
Sep 21, 2008 | Logitech 967461-0403-PK Keyboard/Mouse
Computers & Internet Logo
262 people viewed this question
David Payne
David Payne
