Question about Tunturi T85F Folding Treadmill
I have a Tunturi T85F and it displays error message 'data transfer error'. The manual gives no indication to a solution. Can you help?
3 Suggested Answers
SOURCE: Hi, I have a tunturi T85F treadmill and when I
Dear Richard,
Did you get a solution to this problem
Fitz London
Posted on Jan 09, 2011
ercupa190
  • 12223 Answers
SOURCE: i have a tunturi t60 and it as stopped working and says data transfer error on display
Dear Sir:
LUBE inmediately the machine, the problem is lack of maintenance, maybe you have deck belt worn, that produce enough friction and by consequence shut down the machine.
2) Lube the rollers bearing in according with the instr.manual schedule.
3) Measure the voltage motor, if there are voltage the motor need repair or replace.
4) Test the output voltage board, for input voltage motor, if there are NOT voltage the board is faulty.
5) Run the software calibration for diagnose, and troubleshooting.
See my personal tips for help.
sincerely. God bless you.
Posted on May 08, 2012
I have just purchased a Tunturi T85F. While running ( not on any program ) it stopped with Motor Overload shown on the screen . Any idea what the problem is ?
The motor is not turning at correct speed and is drawing too much power. Shuts down to protect it from burning out. Check the drive components for excessive friction .
Dec 26, 2015 | Tunturi Exercise & Fitness
Where can i find a replacement safety key?
contact the manufacturer or service agent for the machine
I would not think that it is a specific key as it is only used to stop the machine when pulled out
Nov 03, 2015 | Tunturi T85F Folding Treadmill
System check failure
You can completely switch off the power for a few minutes and there is also a 'reboot' button at the front/bottom of the treadmill that needs to be pushed for about 5 sec (check manual). In my case that did not work and I had to replace the complete control panel/dashboard. My problem was different, I got funny messages about errors and flashing numbers on the dashboard. Tunturi was helpful in getting me the necessary spare parts. Good luck.
Mar 30, 2014 | Tunturi T60 Folding Treadmill
Tunturi T85 data transfer error
Yoy need now lower power board
Dec 29, 2012 | Tunturi T85 Treadmill
Tunturi t80 treadmill gives check lubricant message after multiple times of lubricating the belt
RESET the machine. Use your owner manual read section troubleshooting and proceed according.
God bless you
Aug 02, 2012 | Tunturi T80 Treadmill
Service 4wd bad accelerator
Hi there:
The FDCM has a code, and for me to be able to correctly diagnose your vehicle..You will need to get that code retrieved by a scantool.\.
The service 4WD indicator gives an indication to the vehicle operator when the Final Drive Control Module (FDCM) has recorded a Diagnostic Trouble Code (DTC) for an electronic transfer case circuit or component malfunction. This indicator is controlled by the instrument cluster logic circuit based upon cluster programming and electronic messages received by the cluster from the FDCM over the Controller Area Network (CAN) data bus.
The service 4WD indicator function of the reconfigurable dot matrix Organic Light Emitting Diode (OLED) display unit is completely controlled by the instrument cluster logic circuit, and that logic will only allow this indicator to operate when the instrument cluster receives a battery current input on the fused ignition switch output (run-start) circuit. Therefore, the OLED service 4WD indication will always be OFF when the ignition switch is in any position except ON or START. The instrument cluster will turn ON the service 4WD indicator for the following reasons:
Service 4WD Indicator Lamp-On Message - Each time the cluster receives an electronic service 4WD indicator lamp-ON message from the FDCM, the service 4WD indicator will be illuminated. The indicator remains illuminated for about five seconds, until the cluster receives a lamp-OFF message from the FDCM, until the cluster arbitrator logic determines that another display request has priority, or until the ignition switch is turned to the OFF position, whichever occurs first.
The FDCM continually monitors the electronic transfer case control circuits and transfer case shift motor/mode sensor assembly to determine the condition of the system. The FDCM then sends the proper lamp-ON or lamp-OFF message to the instrument cluster, also known as the Cab Compartment Node (CCN).
For proper diagnosis of the FDCM, the CCN, the CAN data bus or the electronic communication related to service 4WD indicator operation a diagnostic scan tool is required. Refer to the appropriate diagnostic information.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 23, 2012 | 2000 Chevrolet Blazer
I have a tunturi t60 and it as stopped working and says data transfer error on display
Dear Sir:
May 07, 2012 | Tunturi T60 Folding Treadmill
Data Transfer error
You need new lower power board some people say lower circuit board . This will cost around 280 but anyone looking to buy I have got one brand new.contact me on 07943858686
Mar 14, 2012 | Tunturi T85 Treadmill
Error when installing Move data process :-132
try to use another grabbee i think there's something wrong with the connection... that's why it display an error message..
Apr 28, 2009 | Computers & Internet
Tunturi T85F Folding Treadmill Logo
53 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
