System configuration data read error in toshiba satellite a-300-11T
spike888ph
  • 77 Answers
SOURCE: motherboard
Try dismantling your laptop and one by one remove the module components like the Wifi card, Lan modem module (if possible) and try booting it up again and see if this problem will be solved.
What did you do prior to experiencing this particular problem?
Posted on Apr 05, 2008
mitch_3020
  • 70 Answers
SOURCE: Toshiba Satellite laptop boots up but shuts down on its own very shortly
Hi JOJO0803,
Based from the error message you're getting it sounds to me that your problem there is not software related but is more hardware in nature.Since you're getting a message "disk read error occurred IDE#0" this pertains to a problem with the hard drive itself. It's possible that your hard drive developed bad sectors or errors on the disc itself.
So to be sure I would recommend that you run the hardware diagnostics for your laptop computer especially the one for the hard drive since you're getting this message. If the hard drive fails the test or any other part fails in the test, contact your techsupport and ask for replacement parts if your PC is still under warranty. Otherwise you may have to buy parts for your laptop.
If the hard drive tests passed and all the other hardware tests also passed then you may proceed to troubeshoot the software using the Windows XP Home CD. Boot from the WinXP Home CD, and you get to the setup screen, choose "R" for recovery console and then on the prompt type "CHKDSK /R" let it run, it may take a while. afterwards it will bring you back to the prompt then type EXIT and it will reboot the system, see if that fixes the problem. Worst case scenario you may have to format then reinstall Windows XP again to fix this problem.
Hope this helps!
Peace! :)
Posted on Oct 23, 2008
kbdesign
  • 370 Answers
SOURCE: System configuration data read error
If the flash bios installation was stopped, you might have to do it from dos, otherwise, go ahead and press f2 and correct any obvious errors (ie floppy drive listed and not present)
Posted on Mar 19, 2009
  • 3278 Answers
SOURCE: toshiba L500D new out of the box and will not boot
Your best choice is to contact Toshiba, since your laptop is brand new. Let them help you and document the problem, in case their solution doesn't work and you need to return the system. Assuming that It was tested before shipping, it could be a hardware problem. Hope this helps. Plz let me know.
Posted on Jul 27, 2009
Preeth Tom
  • 129 Answers
SOURCE: how clean toshiba satellite a300d-11t laptop
Its quiet simple.by use of an USB vacuum cleaner you can easily clean
You can order it through any of the internet shopping sites.
Most of the usb cleaner has the following specifications :
  • Two nozzles were provided with the package – one bristle brush and a slim one for cleaning keyboards. The brush suction tube attachment is used for general cleaning of air vents, monitor and other computer areas and the squeezable keyboard tool is designed to vacuum the dust and dirt trapped underneath the keyboard keys.
  • A “turbo” button is also designed to boost the suction power for vacuuming heavier dirt and dust. Last but not least is the provision of a little LED built-in work light which aims to illuminate the area in which you are cleaning.
Hope this helps.
Posted on Mar 16, 2010
Trying to factory restore my toshiba satellite with no luck, i have tried everything that i have read. while pressing F8 there is no option for factory restore. every option on my screen i selected with...
why you not try to select last known good configuration. it will fix your blue screen error. it is may be a registry error or driver configuration error,but if you can fix disk errors with chkdsk command after select safe mode with command line.
chkdsk c: /f
Sep 18, 2017 | Toshiba Satellite M45-S165 Notebook
On toshiba laptop satellite a55-s106 computer, what it mean when screen are blue. and said a problem has been detect, UNMOUNTABLE_BOOT_VOLUME what that mean?
Welcome to Fixya. If you have an error message UNMOUNTABLE_BOOT_VOLUME you can refer on the link below on how to fix it.
How to Fix UNMOUNTABLE_BOOT_VOLUME
If you have questions please let me know. Thanks for using Fixya
Apr 06, 2011 | Toshiba Satellite A55-S106 (PSA50U0NE02E)...
Windows boot manager for TOSHIBA PRO L300
You will need an original windows installation disc and not a recovery disc. If you do not have one, then you have the option of taking to a shop that does and have them run the repair utility. Or, if you can find someone who has burned a copy of the windows ultimate boot disc, that will also help in repairing the boot manager and files.
May 23, 2010 | Toshiba Satellite A135-S4527 Notebook
Wheres the ram?
RAM modules must be installed in special locations on the motherboard called Sockets. These memory sockets are what hold the RAM module in place and can range from 1 to 16 or more. Banks consist of a group of 1 or more sockets. A system can have 1 or more of these banks of sockets. If a system has more than 1 socket in a bank, a Kit must be purchased for that bank. A kit is simply more than one, usually 2 or 4, like RAM modules. All sockets in a bank must be filled. Typically you will see 2x512MB or 2x256MB signifying you get 2 units of 512MB RAM modules or 2 units of 256MB RAM modules, respectively.
The Toshiba Satellite A40-S270 has 2 bank(s) which have 1 socket(s) in each bank for a total of 2 memory socket(s). This means the Satellite A40-S270 can support up to 2 individual RAM modules.
Below is a visual representation of the memory bank(s) and socket(s) configuration for the Toshiba Satellite A40-S270.
socket_1.gifsocket_1.gif This graphical representation above details what the memory configuration would look like with the maximum memory installed and does not necessarily model your system memory configuration. This graphical representation is not drawn to scale and should only be used as a general reference. Please consult your system’s user manual for your actual memory configuration.
May 11, 2009 | Computers & Internet
Problem with recovery of the system (Windows XP)
check the status of harddisk on bios, whether detecting it or not if detecting then also check the hdd status, change its native status
Oct 24, 2008 | Toshiba Satellite A135-S4527 Notebook
Recovery Disk can not recover system
It could be a hard drive crash. Can you refort the hard drive and see if you get any errors.
Check to see if you have any scratched on the CD.
Jun 22, 2008 | Toshiba Satellite A105 Notebook
Motherboard
Apr 04, 2008 | Toshiba Satellite M65-S9092 Notebook
Computers & Internet Logo
634 people viewed this question
David Payne
David Payne
