Question about Cameras
Hello I've got a problem with my Samsung ES25. When I turn on camera with my SD card and want to take picture it says card blocked, but when i want to take a picture without a card its good. My SD is not blocked by any switch, its in open position. Also my pc cannot recognize the camera, when i plug in the camera nothing happens.
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
Hello
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 22, 2010
Free software download lost
If you haven't done anything with the card since then, you may be able to recover at least some of the pictures. Do a Google search for "data recovery software" and select a program for your computer and operating system. Put the card back into the card reader, cross your fingers, and run the program.
Next time, don't scan and fix. Personally, I always slide the lock on the card to the write-protect position before putting it into my card reader. Not only does it prevent the "scan" dialog from popping up, it keeps the computer from putting the recycle bin and other garbage onto the card.
Jun 03, 2013 | Samsung ES25 Digital Camera
When I take a picture, display "blocked card"
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 24, 2012 | Samsung Digimax D53 Digital Camera
How can i upload pics from sansung es25 to computer without usb cable, i have lost that cable.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 07, 2012 | Samsung ES25 Digital Camera
I'm connecting my Samsung ES25 camera to my PC but the PC cannot read the camera, and the PC fits all the requirements as indicated. What could be the problem?
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 14, 2010 | Samsung Cameras
Comes up with format then check sd card
I've had this problem too.
Your Samsung Digimax L80 accepts SD Card cards.The largest SD Card card you can use in your Samsung Digimax L80 is 2GB anything larger and it doesn't work.
Jun 03, 2010 | Samsung Digimax L80 Digital Camera
Just bought samsung es25.took2 photos and the screen showed memory full.do i need tobuy a memory csard already?
The internal memory of the ES25 can only store one or two pictures, but you can buy SD cards from amazon.com quite cheap. 2GB will give you space for about 1000 photos (with super fine setting). bare that in mind
May 29, 2010 | Samsung Cameras
Cameras Logo
186 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
