Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitachi 55inch projection tv with blue shadow.
The tv has a blue shadow about 80% of the time. Any ideas???
  • Lankester Jun 25, 2008
    I also a have a big blue blotch that takes up at least half the screen. It's always there but is quite noticeable in dark scenes or when the channel is changed and completely goes black until the next channel is received.
    I thought it might have to do with my Dish satellite that I got when I moved into a new home and I didn't have satellite where the tv was before.
    Any suggestions?
  • Anonymous Jul 23, 2008
    I have a blue shadow on all pics all of a sudden. it will not go away.
  • Hitachi Master
  • 8,617 Answers
Blue Convergence Ic is defective. let me know if you need to know where to get a replacement IC
Posted on May 04, 2008
Blue shadow hitachi 52"
No,ur tv have a problems known as a convergence problems,it dead.The tv convergence board must have it 2 STK convergence ICS and some or all it resistors must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 16, 2010 | Hitachi 43GX01B 43" Rear Projection...
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Aug 06, 2009 | Televison & Video
Blue shadow on hitachi lcd rear projection tv
It is usually caused by the Light Engine.
Jun 28, 2009 | Hitachi Televison & Video
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 46f500 convergence?
a common problem wich i also have with convergence with blue and red convergence.
the image converge amplifiers are burnet out wich in turn blow out resisters that control individual color convergence.
Jun 19, 2008 | Hitachi 46F500 46" Rear Projection...
PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Blue shadow or ghosting on screen
  1. First try Magic Focus
  2. if this will not fix problem
  3. then you have a convergence problem
  4. You will need the Converg. Kit
  5. X480295 part number
Nov 12, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Blue and yellow shadows
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 15, 2007 | Hitachi 60FX20B 60" Rear Projection...
Blue and red shadows on screen
This sounds like one of the convergence IC's has cracked loose or burned out, and should be replaced and realigned by someone with experience.
Jun 26, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
304 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
