Question about Nokia 3110 Cellular Phone
My nokia 3110c is not switching on properly it auto matically switching off within 2-3 second yesterday i had download some wallpapers from internet it might be due to virus so what i should do
    Problem Solver:
  • 15 Answers
Try to reformat your micro sd memory card,you might have downloaded a corrupted file.by doing so will erase all of your files installed in your micro sd memory card.
Posted on Aug 22, 2010
My nokia 3110c restriction code please help me send to my email my imei-351939037479528
All you need is Upgrade your 3110c Fimware.
What you need is only Data Cable and Nokia Software Updater.
You can Download Nokia Software Updater from www.nokia.com.
To Upgrade firmware your 3110c with Nokia Software Updater,you need to Connect to the internet.
what you have to do is :
1. Connect your internet,
2. and connect you phone to Computer,
3. and then Open Nokia Software Updater.
Nokia Software Updater will work by it self.so this is realy easy.
Jan 05, 2012 | Nokia Cell Phones
My nokia 3110c phone restarts 2 to 3 times....n then it gets switch off
Hi!
There are many solutions for this issue, please check and try the one that applies. Make sure you back up any data before proceeding.
- Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
- Don't get your phone loaded with too many themes downloaded from the internet or atleast, don't switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
- Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
- Don't try updating of music library frequently or don't often transfer data in/out of your Nokia 3110c phone.
GoodLuck!
eBookBoy
Jul 11, 2011 | Computers & Internet
That is the your battery charge problem. your cell phone battery doesn't give sufficient back up to your cell phone. first charge your battery full charge then try. otherwise change your battery.
Aug 22, 2010 | Nokia 3110 Cellular Phone
Where can i find free themes for nokia 3110c .. can you pls. give me some sites where can i download themes.
Go to this Link and select "Wallpapers". Select the theme you want to install in your mobile.
You get two options to download that wallpaper. You can either download it to your computer and later can transfer it to your Nokia 3110 mobile via USB cable, or you can choose Mobile Web by which you will have to go to a link from your mobile and will have to enter a code and the respective wallpaper will be installed in your mobile.
Later you can apply it to your mobile phone.
Thanks for using Fixya.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jul 01, 2010 | Nokia 3110 Cellular Phone
Auto matic swich off
hi,
it is a common problem in the classic series of nokia phone...it is cause by corrupted software...try to turn off your phone then unplugged your micro sd ,then turn it on...observed your phone if it will switch off..if same status ,you need this tools ,flash file and gadget to fix your phone...
1.)fbus cable 3110c
2.)mx key dongle with ufs interface
3.)3110c flash file v7.23 (you will get it in this site.....http://www.lsdshka.narod.ru/firmware_nokia.html )
procedure..
connect the phone in mx key dongle using 3110c fbus cable ,open mx key ,tick bb5 then bus check ..if the phone is connected to mx key put the flash file ,mcu ,ppm and cnt ..before flashing the phone and everytime you do flashing always make a back up in pm section and rpl of the phone to prevent bigger damage...now it is safe to flash the phone .after the flashing is done inse the battery and test the phone...
if you have no gadget that i mentioned above ,dont do the programming in your phone..go to a expert mobile technician ti fix it..
thanks for trusting fixya and i hope it will help you..
My nokia 3110c not working properly
Clean and dry the battery terminals, check if the battery has swollen which indicates poor battery, reset all the settings to factory default, possibility of bad memory cells (memory card), it seems the handset is still in warranty period, contact nokia customer care for free repairs or replacement.
Oct 08, 2009 | Nokia 3110 Cellular Phone
3110c
got this from the net, maybe it helps:
The Problem with Nokia 3110c – Switching off and automatically restartingThis is what happens. Nokia 3110 hangs, gets switched off andrestarts randomly. More often, it restarts around 3 times or so andthen gets switched off.
Possible Causes and SolutionsCause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500KB, so as to keep things running smoothly on your phone and preventNokia 3110c from restarting.
Cause 2 – Changing Themes – Some people havereported that the phone restarts automatically when they try changingdisplay themes on the phone.
Solution – Don’t get your phone loaded with toomany themes downloaded from the internet or atleast, don’t switchthemes frequently. These themes, mind you, also load up things intoyour already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB datacable (or) Updating Music Library – A few people have reported thattheir Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but considerconverting all your MP3 music files to WMA and then store them on thememory card. Some users suggested this.
Disclaimer – Follow the suggested solutions at your own risk. The author is not responsible for any damage caused to your phone.
UPDATE:IT LOOKS LIKE A FIRMWARE UPDATE COULD FIX SUCH NOKIA 3110CRESTARTING PROBLEMS – RESOLVE YOUR ISSUES RIGHT NOW BY UPDATING YOURNOKIA 3110C FIRMWARE – CLICK HERE TO KNOW HOW YOU CAN UPDATE YOUR NOKIA PHONE FIRMWARE
Jul 23, 2009 | Nokia 7610
Automatic restarting problem with Nokia 3110c mobile phone
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Feb 12, 2009 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
51 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
