Question about Philips 50PF9631D 50 in. HD-Ready Plasma Television
5 different colored vertical lines on black and white picture.
50pfp5332d/37 philips plasma TV worked fine in the morning. After work I turned it on and got 5 different color vertical lines on a black and white picture. Sound is fine, tried unplugging and plugging everything. Hooked different tv up to satellite and it worked fine. Has worked great for about 8 months. Help very much appreciated, thanks
  • Anonymous Mar 25, 2014
    evrything else works, itsjust the white negative color of the picture
    President:
  • 2,712 Answers
Hello wisportsfan2,
Try the following first:
If you are using a direct cable connection from the wall outlet;
  1. Check the incoming cable or antenna signal connection to ensure that it is properly secured to the TV's antenna input.
  2. If the connection is good, perform the auto program and ensure that the Installation mode (Antenna or Cable) is selected correctly.
If you are using a coaxial connection from the Cable or Satellite box to the TV;
  1. Set the TV to the channel specified by the service provider.
  2. Change the channels at the Cable or Satellite box to view the program.
If you are using a video connection (CVBS, S-Video, YPbPr, HDMI) from the source (DVD, Cable or Satellite box) to the TV;
  1. You do not need to perform auto program to search for the channels.
  2. Press the 'SOURCE' button on the remote control repeatedly to select the correct input source.
If you are using an HDMI connection from the source (DVD, Cable or Satellite box) to the TV;
  1. Reset the TV and source by unplugging it from the power outlet for 30 seconds.
  2. Press the play button on your source device. If the source is HDMI CEC compliant, the TV will automatically switch to the HDMI input.
  3. If your source is not HDMI CEC compliant, turn on the TV and switch to the HDMI input.
  4. Turn on your source.
If you are sure you have selected the correct input or channel but still have no picture and sound;
  1. Try resetting the TV by unplugging it from the power outlet for 30 seconds.
  2. Press the 'SOURCE' button to select the correct input source.
You can try the "Whack" method first though..Just smack or whack the set with your hand or fist around the cabinet to see if that will either aggravate or restore the picture. If so, it means there is a loose connection or cold solder joint of some kind, which you may be able to repair yourself if you have the soldering skills.
If it still does not work, it looks like there is a problem with the vertical blanking due to faulty ribbon connectors, although there are several things that can cause it.
But in my honest opinion, it is best to have an expert technician come in and do some tests on it in order to diagnose the root cause of the issue. It is not easy to fix this yourself, if you have no experience, as there are a lot of parts that have to be removed before you can reach the components. It could be as simple as a loose connector ribbon or a bust capacitor, but it could also be more complicated. Hence, in my honest opinion, better get a qualified technician.
If you wish to contact Philips customer support to arrange for a service, please call 1-888-744-5477 Monday - Saturday 7:00 am - 11:00 pm EST Sunday 8:00 am - 11:00 pm EST Excluding major holidays
When you contact Philips please have available:
  • The exact model number
  • Your date of purchasing
  • The serial number of your product
Send an e-mail
Hope that helps! If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides helpful information that helps solve the problem.
  • "Thanks for Trying" - The solution provides some help but does not solve the problem.
  • "Inappropriate" - The solution has nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 04, 2008
    Brigadier General:
  • 6,966 Answers
Hi wisportsfan2,
With the indulgence of sweet_rascal...
I would suggest that you consult your dealer or claim warranty repair with any Samsung Service Centers. Should the option be available, may I also suggest you ask for a replacement unit. A number of similar issues are known of this very nature due to defective PDP a rather expensive repair. Additionally, some have reported improvements with firmware updates but likewise would require the services of an authorized service center.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role May 04, 2008
    Sorry, that should be "...Philips Service Centers...."
    Guru:
  • 1,894 Answers
I think it must be a signla problem..
Philips 50PFP5332D 50 in. Plasma Television won't load software upgrade. Was doing the upgrade to try ans resolve a picture issue of black and white double image picture with vertical lines
I had the same problem with the same tv, replaced the main logic board for $30 used on ebay and it works perfect now. Make sure all part numbers match on the replacement part otherwise it will not work, some tv parts work in combination with other parts.
Sep 05, 2011 | Televison & Video
We were watching tv last night and it the picture just turned off. the machine was on but no picture. i turned off the tv and tried again this am. no picture.
You either need this part (http://cgi.ebay.com/Philips-50PFP5332D-37-LJ92-01401-Buffer-Board-/150501144120?pt=LH_DefaultDomain_0&hash=item230a913638) or this one depending on your dead screen issue (http://cgi.ebay.com/Philips-50PFP5332D-37-LJ41-04216A-X-SUS-XSUS-Board-/170550290208?pt=LH_DefaultDomain_0&hash=item27b596e720)
Oct 20, 2010 | Philips 50PFP5332D 50 in. Plasma...
Half of my screen plasma TV 50" is black. What I have to do to fix it? plhilips plasma tv model 50PF7321D/37
Your Television problem on vertical section.
Solve: If you repair itself replace vertical IC or thoroughly resolder dry any components.
Jan 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
Only get black & white, double images
bad power circuit may cause such problems.
may be power ic or bad capacitors.....
Aug 18, 2017 | Philips 50PFP5332D 50 in. Plasma...
TV sound but no picture
Can you tell me which Cable box you are using?Which model/region?
The possibility is that the HDCP handshake could not have happend correctly and hence the issue. Try to connect to different HDMI input of TV from Cable box. If possible change the resolution of cable box and check video
Nov 01, 2009 | Philips 50PFP5332D 50 in. Plasma...
I have a Philips plasma 42 with black lines across the screen
I would first check if there is an available firmware upgrade for your model .Upgrade requires you to download firmware from philips website.Then transfer it to a memory stick .Then use a memory stick reader to plug into tv for firmware upgrade.Other wise the set would probably need repair .Possible a bad SSB board or another issue
Aug 26, 2009 | Philips 42PF9630A 42 in. Plasma Television
Television has sound but no picture
Check the cables first that connect to your video device, are they in tightly?  Test the cables on another TV to make sure they haven't gone bad, which is common.  Also check the input selection on the TV to make sure it matches with the video input the cable is connected to.
Dec 06, 2008 | Philips 50PFP5332D 50 in. Plasma...
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Philips 50PF9631D 50 in. HD-Ready Plasma Television Logo
211 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
