Question about HP Computers & Internet
Have power problems with my Pavilion dv 5016 EA laptop.New battery but battery power runs down even when operationg connected to AC power
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Aug 22, 2010
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
HP pavilion laptop ZV6203CL will not charge the battery anymore, even a new battery, and will not use the battery power, will only power up when plugged AC. Is this a problem in the board or the AC DC...
This must be due to AC DC Power Jack. Test your Laptop with a new one. It can also be the Power Configurations in he Windows Control Panel. Do check those settings also.
Aug 31, 2011 | HP Pavilion zv6203cl Notebook
Hp Pavilion DV 8000 (dv 8113 ea) heats up then hangs & turns off
I believe that would be the battery I would get a new battery that should solve the problem. When you use office or surf the internet that does not require as much power as playing games and watching videos. Just buy a new battery and that should solve the problem
Jul 18, 2010 | Compaq Presario CQ60-220US PC Laptop
I have a hp dv7 laptop it does not work with the ac adapter but worked with the battery whenever it is working with the battery and the ac adapter is connected it shuts down.
You most likely have a short in the AC adapter and I would replace it right away. I have had my dv 7 for a little over a year and had to replace mine 3 times so far.
May 11, 2010 | HP Pavilion dv7-1130us laptop
I am Using HP dv 4 I have a problem that when i plugin the ac adopter it shows that it is plugeed in but not charging
Shut down the system. Take the battery off. Leave it for half an hour. Re-connect the battery and plug-in. Charging stops if the processor fan is being blocked. Use surfaces like table to use ur laptop. Don't use it on bed.
If problem persists contact service centre.
Apr 16, 2010 | HP Pavilion dv4000 Notebook
I have a HP dv7 laptop it does not work with the ac adapter but worked with the battery, whenever it is working with the battery and the ac adapter is connected it shuts down.
Remove the battery and plug the ac adaptor in check wethere the light on the port where you connect the ac adaptor glows or not, if no then check the wethere the ac adaptor is getting warm or not after you plug it in for few minutes if not then ac adaptor has to be replaced.
If the light on the port is glowing then it is likely that the power supply of the notebook has gone bad as it is not able to switch to ac adaptor or the port where you connect the ac adaptor to the notebook has a short circut when the acadaptor pin is connected , better try with a different ac adaptor to be sure wethere the issue is with ac adaptor or the notebook.
My best wishes
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
HP DV600 laptop doesn't turn on even on mains.
It sounds like your ac adapter has died, and thus is not charging the battery back up. Test the adapter for power output. If it isn't working, the only option is to purchase another.
Jan 07, 2010 | HP Pavilion dv6000z Notebook
Bought new power cord for pavillon dv 1000 and
If the laptop runs on batter but cannot run on the AC adapter, you have a broken DC Jack. If you laptop cannot power up with the battery or flash low battery indicator, you laptop is dead.
Oct 30, 2009 | HP Pavilion dv1000 Notebook
Laptop wont boot and the battery and power lights flash
a simple power cycle might work. Take out the battery but keep the ac power connected. hold the poewr button down for 1 minute. then hit the power button again and it should poewr back up. If this doesn' t work. iyou said hte battery light flashes so the problem isnt the battery..the problem might be hte ac power adapter..if you have a warranty this would be a good time to call them. Try the power cycle first though this fixes the problems lots of the time
Apr 15, 2009 | HP Pavilion dv1000 Notebook
My hp pavilion dv 9000 does not start.
Hard drives are cheap. Find out what type of drive this supports (i.e. ATA or SATA), and buy a new drive. They're quite easy to replace, too. You'll just need a recovery CD to re-install your OS (operating system) after you put in your new drive.
Jan 03, 2009 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
52 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
