Question about Toshiba Office Equipment & Supplies
HI, i am having a toshiba TDP-E10 projector, i just used it a couple of time and it was not used for anout a month, and it kept covered and clean everyday, today i tried to switch it on, and it was one for 20 seconds and then it goes off and on the standby button on the projector instead of blue light it shows red light and the projector makes sound like the fan is running, it happened onece before but it got rectified by itself....strange... . but this time it dosent. i tired to swith it off and on again but it still the same thing gooing on...please help me out....ihave hardly usd around 178 hrs
5 Suggested Answers
  • 4 Answers
SOURCE: Blub goes out during use.
Most fans have a sense line to detect the fan is working properly, Possible the sense circuit has failed. The unit should not start if it thinks the fans are not running. Possible thermal problem with the sense circuit, since your unit starts up then stops.
Posted on Mar 31, 2007
Marrie
  • 563 Answers
SOURCE: Toshiba projector switching itself off
Hi 123d
Have you tried resetting the lamp timer ?
If you have and it didn't solve the problem , take out the lamp and check for any discolouration or markings on the lamp.
If you do find anything out of order then the lamp would need replacement.
Posted on May 21, 2008
SOURCE: toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Posted on Nov 12, 2009
projdoc
  • 2236 Answers
SOURCE: I've owned a Toshiba TDP-S8 projector for about 20
if the fans won't go on, you have a power supply problem. chances are it's a bad capacitor. this model is known for making their power supplies with underrated capacitors. if you are good with a soldering iron, you can replace the main cap (c1, i believe) with one that has a slightly higher voltage rating with the same microferads. otherwise, replace the power supply.
Posted on Dec 11, 2009
Tip
Toshiba TDP-P9 Lamp time reset
I had sleepless nights with my customers TDP-P9 projector where I changed the lamp.
The lamp timer resetting gave me headache but now I finally solved the right combo:
1: Unplug the power cord
2: Hold down 'On/standby' 'Input' and 'up arrow'
3: While keeping the buttons pressed, insert the power cord and wait for the projectors led's to flash briefly and then power button to keep illuminated and then starting to blink.
4: Release the buttons and power on, it should now have 0 hours in the timer.
on Apr 06, 2011 | Toshiba TDP-P9 DLP Projector
I have a toshiba projector TDP S 20 it starts & automatically Light goes off in Couple of minute \r\ni don't understand what is the problem \r\nlooking for help
hey mike. thereis no glass in there no bulbs havebeen smashed in it, gaz what do you mean i need a sub d connection between pc. im using the vga. also it doesnt have a usb port on it and whats a pj lol. thanks guys
Nov 11, 2010 | Toshiba TDP-S20U Multimedia Projector
Focusing
Hi real12
Unfortunately you will have get the focus ring replaced before you will be to make use of it if your model doesn't have automatic zoom and focus in the user menu.
Sorry , but there simply is no other way.
May 21, 2008 | Toshiba TDP-S9 DLP PROJECTOR *2% DISCOUNT...
My Toshiba TDP-ET20U Multimedia DVD Projector will not play a DVD. I can hear it reading and reading it, but it will not play. The same DVD will play immediately on another DVD player.
Hi jennydority
Have you tried cleaning the DVD player's lens with a CD/DVD cleaning disc yet ?
Give it a go , it normally solves the problem.
May 06, 2008 | Toshiba TDP-T90 Multimedia Projector
Toshiba TDP-S1 Projector parts
Hi there
You will have to locate your nearest Toshiba dealer and give them a call.
Apr 03, 2008 | Toshiba TDP S1 Multimedia Projector
Toshiba TDP T 91A
Hi there
I would suggest you investigate it yourself first before dishing out that sort of amounts.
Check if the fans are running.
Most of the times the overheating of a Projector is as a result of a faulty fan.
Mar 26, 2008 | Toshiba TDP-T91AU Multimedia Projector
Toshiba TDP-T90 projector, lamp
is lamp cover closed firmly-is power cord good(try with another cable)-is power fuse ok!!!-is power supply ok.and gives normal rating output voltage as a the book say.all previous will check first befor lamp and fan.
Feb 16, 2008 | Toshiba TDP-T90 Multimedia Projector
Toshiba projector tdp-s8
please start your computer first and then the projector- use function key with f4 or f6 or f7 or f5-and select computer from input of the projector.
Dec 29, 2007 | Toshiba TDP-S8U Multimedia Projector
Toshiba tdp-mt800
Hi there
Have you tried using another input like the Component instead of the DVI. See if it makes any difference.
If not it could be the DMD or your Mainboard.
Most of the time it is the Mainboard - Home Theatre Projectors come out with awesome DMD's , so I doubt it to be the problem.
Hope this is usefull !
Aug 08, 2007 | Toshiba TDP-MT8 DLP High Definition Home...
24 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
