Question about Sony KP-41DS1 41" Rear Projection Television
Hi i have a sony kp-41ds1u rear projection which has lost picture and audio but the power light flashes on when pressed ? can it be fixed ?. It was turned on one morning but made a small pop sound and lost both picture and sound .I checked the fuse in the plug which was fine and the stand bye light flashes on when pressed
  • Sony Master
  • 5,138 Answers
On your powerBoard the one that has your FBT flyback Transfomer
Look at the hori output Transistor and right behind it feeding to output is a 2K volt capacitor Ive seen them with tiny burt hole in them,causing lost of high voltage,if it is OK then you either have Bad FBT or Bad STK ICs. STK392-110s Mats Has Parts for this set 1-800-628-1118
Posted on Aug 22, 2010
  • Mike Wilson
    Mike Wilson Oct 10, 2010
    If you can't fix it Mike., I have one of these for sale, its surplus to requirements so i'll let it go for a reasonable offer, if your interested, contact me on Mike@StradaVanservices.com Cheers. Mike.
Sony KP-57WS500 57 in. Rear Projection tv When I press the power button there is no picture but the "timer / Standby" light flashes. Sometimes when pressing the power buttonthe light flashes and I hear...
CK your hori output Transitor and behind it is a blue high voltage capacitor 2k sometimes they will have small burt hole on them ,If it is OK then Replace your STK ICs example STK392-110 Mats has them 1-800-628-1118
Feb 15, 2010 | Sony KP-57WS500 57" Rear Projection...
I have no picture and the timer/standby indicator flashes seven times. i cant find a list of the codes on the internet for what that flashing light means
seven blinks is over current protect try to turn the tv on using the sony original remote with this button sequence press display 5 volume up then power if the tv comes on replace ic8002 on the power supply if it doesn't I would still try that fix very common on sony tv's
Jan 24, 2010 | Sony KP-48S70 48" Rear Projection...
Sony kp-51ws500...i turn it on and get a blue screen..can hear audio..but the standby/power light flashes then turns off.. count 8 flashes please help..thanks
Sounds like from your description the Blue CRT ( picture tube ) is shorted. I believe they are no linger available. If in doubt, I would call a service company to verify this.
Nov 21, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP53XBR45 Hi, this tv lost video while watching it but still had sound. now when press power button the light flashes 7-times and will not power up. Please help, Thanks.
the IC's on the circuit board will have to be replaced. it is common. this controls the convergance which seems to be off. the stk's can also be bad causing no picture. Depending on what type you have. You can get a manual and a tester and test each cap to see which one is the faulty one.
Sep 23, 2009 | Sony KP-53XBR45 53" Rear Projection...
Sony KP-FX43M31
On the Sony FX43 100Hz 43-inch rear projection TV, three flashes indicates an Over Voltage Protection problem, occurring in one of the power supply circuits T603 or R672.
The fix will most likely cost more than the set is worth second-hand, I'm afraid.
Jun 28, 2008 | Sony KP-51WS510 51" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Powers on then right back of light flashes 8 times
i have a sony wide screen projection tv KP-51WS500 Red stand by light on flashs no picture
Mar 10, 2008 | Sony KP-51WS500 51" Rear Projection...
NO PICTURE, ONLY AUDIO.
Hi
Your TV is trying to tell you what is wrong with the red flashing.
Five flashes means that you have a white balance problem or the x-ray protection is enabled.
Although I could tell you how to solve the problem, this is not really something you should try and do by yourself.
If your set has Tele-Text that is most likely where your fault comes from. This is however something a Sony techinician should fix.
Sorry about the bad news.
Good luck.
Feb 24, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection Television
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-41DS1 41" Rear Projection Television Logo
238 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
