Question about Lenovo IdeaPad Y510 Notebook
Shuttle centre and Web Camera and veri face, not working due to without backup we cleaned hard disk, now cd also not working for lenovo3000 y300/y500, 7761-3AQ, pl help for software/driver
  • 794 Answers
Hi savantss,
Hope ithelps.Thanksfor using Fixya.
Posted on Jan 29, 2011
HARD DISK PROBLEM
No, you must format all your hard disk, (erase all) for you can be install the new o.system. Otherwise you must get some error.
Of course if you are installing disk, you must sure is very clean or your lector cd is very clean, try to use the disk cleaner from radio shack, or other electronic store or if you are using USB , that you tab correctly.
God bless you
Jul 28, 2013 | Televison & Video
Do pc run slow due to hard disk fail
If you have hard disk problems then this can cause many other problems on your computer, including impacting on performance due to the resources which are used in handling and trying to correct the disk problems.
I would strongly recommend that you make a full backup of your computer while it is still working and before the hard disk fails completely.
If you are using Windows 7 then you can do this using the Windows Backup process to make a System Image backup which can then be used to recover your system provided the image is written to either an external USB hard drive or to DVD discs.
If you have a different version of Windows, then you should try using one of the free Backup programs such as Easeus Todo Backup or Paragon Backup & Recovery Free - the links for these are below:
http://www.todo-backup.com/
http://www.paragon-software.com/free/
If you want to replace the failing hard disk yourself (after you have made a full backup as advised above) then see the Dell Inspiron 580 Service Manual for details on how to do this.
Jan 06, 2012 | Dell Inspiron 580 Desktop Computer (Intel...
Laptop lenovo3000 Y500 ram 1 gb hard disk 160 gb (a) c : use to be approx 20 ? (b) d : use to be 120 (c) 20 gb hidden problem 1. one key recovery not working due to change in...
Most manufacturers automatic restore partitions set 50-50 so 80G for C and 80G for E.
Anything can of course be set with the correct software.
Hope this helps.
Feb 27, 2011 | Computers & Internet
How can I install my hard drive without the cd?
HI jamarrfinney
If you only want to install on your hard drive as backup, cd is not needed. just set the hard disk jumper to slave for IDE hard disk. If you are using SATA hard disk, no need to set jumpers, just insert the cable and then set the bios setup hard disk as a second hard drive (if necessary)
regards
Jan 11, 2011 | Computers & Internet
I have lenovo Y510 with vista home basic installed. After some problem all veriface,power2go,shuttle centre and Easycapture did not worked. Then i installed vista from recovery cd. Now everything is...
download driver then download eyeline surveillance when it says add camera easycam pops up it works pass it on u have juss been school holla back
Aug 22, 2010 | Lenovo IdeaPad Y510 Notebook
I want to reset it
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Apr 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
How to install web camera (logotech 5.4.1) without CD
Depending on which operating system you are running, it is possible to install without the CD. Generally Windows Vista and Windows 7 are plug and play, which means you can plug the camera in and Windows will apply a generic driver to it, making it functional but not as functional as if you had installed with the disk. Example, you would not be able to use the camera software as it would not be installed. Check the manufacturer's website and see if there is a newer software for you version of Windows. You can download it free. The site will also tell you if the camera is compatible with your current operating system, which, unfortunately, many are not with Windows 7.
Apr 02, 2010 | Logitech Webcam
How ti installa camera (web) without a cd ?
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Oct 21, 2009 | Veo Stingray
I Ball driver CD lost
Dear,
Give us Model of the Cam. we will provide you driver.
Cheers
Jaggu
Sep 23, 2009 | Computers & Internet
Shuttle center not working
instal the driver disk you found with your laptop
May 10, 2009 | Computers & Internet
Lenovo IdeaPad Y510 Notebook Logo
83 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
