Question about Singer Sewing Machines
I have a model 327k singer machine - approx. 45 years old. Seems in good order overall but has just started to break the cotton from the needle and occasionaly mis feeds the thread when first setting up and jams in a muddle under the removable plate. Any ideas please? unfortunately the manual was lost years ago Regards John Hughes
  • 109 Answers
You can get a manual for $9.99 at sewingmachinemanuals.ecrater.com for your machine.
Posted on Aug 23, 2010
I have a Singer 7466 and recently I developed an issue with the thread stripping and then breaking.
three possible reasons
old cotton will break or shred easily so get brand new cotton
next is eye size of the needle
a small eye with a heavy gauge cotton will not allow the cotton to pass easily
next is needle /hook timing
out of time allows the hook to pierce the needle thread and create the problem take it to a service centre for a check of the timing
Jan 11, 2017 | Singer 7466 Mechanical Sewing Machine
How to refit slide plate of singer 327k
seems like it just slides in the groove .
Mar 03, 2016 | Singer Sewing 327K Sewing Machine
How to the timing on a sewing machine
all sewing machines are the same a very simple. to adjust timing so the bobbin catches the thread, just slightly loosen screw on the main needle shaft(the one that has the needle and goes up and down), move the flywheel so that bobbin point is behind needle at lowest point, tighten screw. test it out. you cannot break the sewing machine, tho you can break a few needles as you master the timing technique. dont be afraid to try. it really is easy. one summer many, many years ago, while i was in college i worked for singer in a singer store. things havent changed since then. (almost 45 years ago). good luck
Jul 28, 2014 | Singer Sewing Machines
Singer featherweight 11 cotton keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 28, 2013 | Singer Featherweight II 117
I have a Singer 327K that stitches three or four good stitches and then stops completely stitching
it's very possible that when the needle broke the machine went out of time & would have to be retimed at a sewing machine shop
Mar 10, 2012 | Singer Sewing Machines
I have a very old singer model 15-1. It was my grandmother's machine and I've been using it for years with no problems. Recently I started having a problem. The thread seems to get stuck between...
take some unwaxed dental floss & clean between the disk gently
you can even use a can of air on that area also
check to make sure there are no loose thread or lint
it's also a good idea if you use it alot, to clean under the needle plate & in bobbin area for lint or loose threads
if these suggestions above do not stop the problem,, then the tension knob or spring might need to be replaced
Aug 06, 2011 | Singer Sewing Machines
Singer Overlocker/Sergers require particular threading order. If that does not help you may as I did have to take it to an Authorised repairer. It has to be a Singer Authorised as they have done training...
Sergers thread upper looper first, lower looper second, right needle third and left needle last in that order. If your thread breaks, CUT ALL THREADS and start from scratch or you will not get a good stitch or your machine may jam. It's probably just a "user error."
Good luck.
Jun 17, 2010 | Singer 14SH654
Singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Mar 15, 2009 | Singer 3116 Simple
Needle jams and breaks off
Needle jams....Thread is caught in the hook...solution...Remove the upper thread and bobbin case,turn the handwheel backwards and forwards by hand and remove the thread remands.
Needles breaks
1. Needles is damaged..Insert new needle
2. The needle is not correctly inserted....insert flat side towards the back
3. Wrong needle size for the fabric...Choose a needle to suit the thread and fabric.
Mar 24, 2008 | Singer 1116 Mechanical Sewing Machine
Sewing Machines Logo
427 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
