Question about Technics SL-BD22 Turntable
Hey i have a turntable that works along/is powered by my hifi. pioneer pl-888z. one day it suddenly started to spin a bit too fast so the records sound too high in pitch. it looks like an electric problem. how can i fix this? thank you. wyldwolf
  • 80 Answers
Is this direct drive or belt drive?i have a tchnics 1200 mk 11
Posted on Aug 22, 2010
  • wildsnowwolf Aug 22, 2010
    belt drive
  • Martin Smith Aug 22, 2010
    have you replaced the belt?
Hi! I have a Pioneer PL 530 record player went on the fritZ!! Wont shut off?
Go to the vinylengine website. There are forums full of experienced users to help
Apr 07, 2015 | Pioneer Audio Players & Recorders
Pioneer turntable to Pioneer VSX 515 receiver
I'm not sure what you mean by "Wot", but I assume you mean that the receiver doesn't have a phono input, as most receivers now a days don't. You will need a phono preamp. Cost is under $25.00. It provides the amplification to be able to use any high level(CD, DVD, AUX, etc) input as well as the RIAA equalization you need to decode the record correctly. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 12, 2013 | Pioneer PL-990 Turntable
How to adjust the speed using the lights.
When the turntable spins the light shines on the edge. You will see at least two indications. One for 45 and one for 33. With the record playing you should adjust the speed control, till one of the indents appears static and not moving. You will have to do this for both speeds. You also might see some varations in speed. These are quite normal and getting it right is trial and error. It will only read true when the stylus is on the record too. If you can't get the indication to stay still then there is something wrong with the drive.
Jun 14, 2013 | Pioneer PL-990 Turntable
The arm will automatically return without playing the record
Hi Lisa, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 28, 2011 | Audio Players & Recorders
Re. pioneer pl 990 turntable can the lid be closed
No you cannot play while lid is closed and YES you need an amp/receiver amp
Feb 28, 2011 | Pioneer PL-990 Turntable
Converting a turntable from automatic to manual
I suppose the only way to do it would be to stop it functioning completely. The only way would be to dissasemble the auto function. What you would need to do is work out which parts are essential for the turntable operation and which only activate the return. So you need to whatch the mechanism working. You will need to remove the base and look at from underneath, just like going underneath a car!
I can't say for certain if you can do it, only you will be able to determine it can be removed without affecting the operation of the entire turntable.
May 21, 2010 | Pioneer PL-990 Turntable
Pioneer PL-670 record rejects continually
Are the record size tabs sticking up through the turntable platter cover? They sense the size of the record being played and adjust the run out distance for either 45 or 33 rpm records.
Jan 04, 2009 | Audio Players & Recorders
Pioneer PL-570 turntable (c.1973)
Yes first check is that the Gnd wire from your turntable is connected to the Gnd (ground) post at the back of your amplifier with a good clean tight connection.
If the problem persists, check ALL your hi-fi components mains plugs for earth connections including your turntable, then remove the earth connections on all but one component so that you are left with only item earthed.
What does sometimes cause problems is if 2 or more hi-fi separates are earthed and connected to each other the earth cables along with the hi-fi interconnects form an inductive loop that picks up interferance such as mains hum etc.
Regards John
Sep 16, 2008 | Pioneer PL-990 Turntable
Trouble with sound
Confirm that the stylus you bought is spec'd out for that turntable
Also check all four wires to the cartridge
Mar 13, 2008 | Pioneer PL-990 Turntable
Technics SL-BD22 Turntable Logo
200 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
