Most likely the drum encoder has picked up lubricant from the maintenance kit. If you remove the right side cover it is on the end of the drum shaft. Normally cleaning that well resolves blurrs.
The drum itself may not getting perfectly into print position either. A cable hanging it up just a little to far from the drum.
But most likely the encoder needs cleaned. Possibly replaced.
I have the same problem with our Phaser 8560. I opened it up, but I have no idea what the drum encoder looks like. any pictures of what i'm looking for? Thanks for all your help!
I am having the same problem intermittently. Was wondering if the maintenance kit would correct it? Also, how do you remove the right side cover?
