Question about Cobra Digital DC6415 Digital Camera
Computer not seeing my dc6415 digital camera when i plug it in usb port i tried right click my computer device manager
  • 6,826 Answers
Http://www.opendrivers.com/modeldriver/Cobra_Cameras%20and%20MP3%20Player_DC6415-driver-download.html
The above is a link to the driver for this cobra dc6415 camera. It is a free download.
Posted on Aug 22, 2010
How to check fo faulty USB port
W 7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for XP or earlier
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts Check if USB Ports Are Damaged
USB ports are an important part of your computer's hardware.
Many devices connect to the computer via USB, such as music players, cell phones and digital cameras.
This connection lets you charge your devices and manage files on them.
When you connect a device to a USB port, it is typically recognized automatically.
If not, there may be a problem with the port. USB ports sometimes fail on their own, or they may be damaged by force.
Plug a variety of devices into the USB port you think is damaged.
If none of them work, the port is probably broken.
Connect the same devices to the USB ports on a different computer.
If they work, this is another indication your ports may be damaged.
Run Windows Update on your computer to ensure your devices and computer function together and have the latest drivers.
Click "Start," then type "Update" in the search bar.
Click on "Windows Update," "Check for Updates" and "Install Updates."
Open the Windows Device Manager by clicking "Start," then typing "device manager" into the search bar.
Click the Device Manager link when it appears.
Click on each of your USB ports.
In the Properties window, look for "This device is working properly."
If this is displayed for each USB port, they are not damaged, but there may be a problem with your device instead.
Click "Update Driver" next to each USB port in the Device Manager, and Windows searches for and installs the latest driver.
If one can't be found, go to your computer manufacturer's website, and download the driver there. Try to use the USB port again.
Sometimes, outdated or damaged drivers result in a non-working USB port.
Open your computer case by unscrewing or sliding off the side cover.
Use a can of compressed air to clean out the dust from inside, especially from within the USB ports.
If your USB ports are hooked up to the motherboard, remove the cable, then replace it.
These actions sometimes help to fix non-working ports.
http://askbobrankin.com/usb_ports_not_working.html
Sep 05, 2013 | Dell OptiPlex 780 Desktop Computer 1 x...
I have HP digital Camera PB360t...I am uploading some pictures my PC did'nt recognize it .. how can i upload the contents in my digi cam ?
you will need to connect your digital video camera using the bluetooth connection to your computer through a usb port and install it
once its connected to the usb lead it should automatically in windows 7 or you might have to open it open up manually click start right click on my computer you might see it listed as a mass storage device if you dont see it
click start control panel administration tools computer management device manager scroll through all of the devices if you see a yellow question or exclamation mark ? ! or a red x you will need to update the driver right click on the device to update driver
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disc the drivers could be on it
hope this helps
Aug 12, 2011 | Audio Players & Recorders
I need my camera to work i have lost the cd , computer said that it is a generic digital
you will need to connect your digital camera using the bluetooth connection on the camera to your computer through a usb port and install it
once its connected to the usb lead it should automatically in windows 7 or you might have to open it open up manually click start right click on my computer you should see it listed as a mass storage device if you dont see it
click start control panel administration tools computer management device manager scroll through all of the devices if you see a yellow question or exclamation mark or a red x you will need to update the driver right click on the device to update driver
hope this helps
Jun 28, 2011 | Computers & Internet
Cant get pictures from my camera to the pc
you will need to connect your digital camera ((the camera should have a blutooth plug)) to your computer through a usb port and install it
once its connected to the usb lead it should automatically in windows 7 or you might have to open it open up manually click start right click on my computer you should see your mass storage device if you dont see it
click start click on my computer to open from there you should see your camera then right click to open you should find the photos in there
click start all programs accessories open windows explorer navigate to your photos
right click on the photo
Jun 24, 2011 | Computers & Internet
Pc doesn't recognize canon GL2 video camera...I'm reading online forum that there's problem with firewire port ????
you will need to connect your digital video camera to your computer through a usb port and install it
hope this helps
Jun 22, 2011 | Computers & Internet
When i plug my digital camara into my computer, my computer do not recognize it
At first try to connect through USB
  • Just connect your camera data cable into the USB port of the Computer
  • On your camera
  • Then Right Click on My Computer select Manage then Go to the Device Manager and Click on Update Hardware Option
  • After updated you see a Icon as yellow Question Marks with The name of your camera.
  • Just Right Click on it and select Update Driver
  • Do as per the given Direction.
After successfully install your driver you just restart your computer. Your camera is now installed with your PC
May 18, 2011 | Kodak Easyshare C813 Digital Camera
I cannot get ther pictures off of my camera and onto my computer
The important thing is, did you install the CD FIRST, and then connect the camera? If you did it in the reverse order, the drivers for the camera will be loaded wrong and need to be removed and reinstalled.
Removing a driver:
If you have done the faux pas above, all the installs in the world will not fix it. You MUST remove the USB driver. Use Device Manager. In XP, this is found by right clicking my computer and selecting properties. In properties select the hardware tab and choose 'Device Manager'.
Stop here. If you have no idea what I wrote, review 'Device Manager' on the Windows Website or ask a KNOWLEDGABLE friend for help. See http://support.microsoft.com/kb/310123.
Now, select the USB device, while it is plugged in to the USB port, and right click. Select 'Uninstall'. Remove your USB device when device manager is done.
Close Device manager and all the other windows. Start your USB install from scratch, without the USB plugged in untill the install asks or completes.
I have ALWAYS had successful installs with this method.
Apr 24, 2010 | Nikon COOLPIX L18 Digital Camera
Computer can't detect camera.
go into the device manager with the camera plugged in. if you see it in there, click "uninstall"
if it shows unknown device, click "update driver"
Mar 18, 2009 | Sanyo Xacti VPC-S770 Digital Camera
Computer does not recognize coby mp705
remove the device, swear a few times, promise your son you'll buy him a proper ipod, then give it to the dog to play with.
Dec 25, 2008 | Coby MP-C7085 MP3 Player
No usb port found
If you can't find such on your machine, then it's either disabled, the BIOS is out of date, the OS doesn't support your USB (Examples abound!) or other. I cut my time loss by adding an USB PCI card.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Cobra Digital DC6415 Digital Camera Logo
Top Cobra Digital Cameras Experts
Daniel Dollive
Daniel Dollive
Greg Cann
Greg Cann
Are you a Cobra Digital Camera Expert? Answer questions, earn points and help others
