Question about ASUS Computers & Internet
Can you tell; me if this computer has250gb hd or a 160gb hd
I am using K8S MX Motherboard with OS-Windows XP. but my hard disk is not working. i want to purchase a new 160gb IDE hard drive. please tell me if it supports 160gb hard drive or not
The specs for this motherboard say it has a Utra-DMA 133, and 2 SATA 3Gbs ports.
You can connect any IDE HD, and any SATA 3 or lower HD. These standards are backwards compatible. When it comes to size, there is a 2TB MBR limit.
I would skip IDE and go directly with a SATA 3 drive.
http://www.asus.com/Motherboards/AMD_Socket_754/K8SMX/#specifications
GL
Dec 11, 2012 | ASUS K8S-MX Motherboard
When ever I plug in my maxtor onetouch 4 mini my computer doesn't see it so it doesn't come up. I was able to access my files before but it doesn't now...How do I get to my files again?
Reboot the computer and plug the HD to the USB port again after the computer settles. Have Windows discover the device to install the driver and wait until it tells you that it is now available to use.
Nov 04, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
How much is my computer worth
Based on brand new parts:
500GB SATA - $56
160GB SATA - $45
4GB RAM - $112
V-card - $105
CPU (Proc., Mobo, P/S, reader) - approx. $107
Your rig can be sold at around $425 - $450 approximately.
Hope this helps.
I had assembled a Quadcore system at around $750.
Mar 20, 2010 | Computers & Internet
I have WD 160GB external hard drive. when i plug in to the computer.it shows on the taskbar as USB storage device but without an assined letter . on my computer window shows nothing about the external hard...
Attach your external HD with some other computer, that will definitely appear normal, the problem is due to a virus in ur HD. Your computer's antivirus software stops it to appear. Back up your data on the other computer, format ur external HD, remove un-necessary files and run a virus scan to the files u copied from HD, Hope this will solve the problem, if not, let me know and tell me what would be the response on the other compuer
Sep 20, 2009 | Western Digital 160GB 7200RPM HDD WD1600BB...
Need new laptop harddrive
Go to either bestbuy.com or compusa.com and look for the hard drive there. The hard drive will be cheaper going thru either of those places. Also check out pricewatch.com cause you can compare prices there. Also go thru google and check out the shopping results of the hard drive your looking for as well.
Lots of places to check and the hard drive will definitely be cheaper then going thru HP.
Jul 06, 2009 | Compaq Computers & Internet
Fabrik simpletech 160GB external HD
Dear,
I think this is warrenty period and you should visit your nearest service center.
Regards,
Rakesh Kumar
Mar 31, 2009 | SimpleTech Signature Mini 160GB External...
Using the 160GB passportHard drive
are there any errors that popped up while copying the music files? if not, then it probably works fine. the files are now stored on the harddrive.
if you want to safely unplug and carry the HD over to another computer, you can., the files should be accessible... that's all a harddive does.
Dec 29, 2008 | Western Digital Passport 160GB External...
New 200GB HD on my LG P1 Express Dual
i have p1 express dual, i have put windows 7 ,2 gb ram , and upgrade HD to 250 7200rpm, i only have to run a cd so i update the bios. my email is m4rios@hotmail.com it took me many hours of searching to find it, i ll send it to anybody i dont believe that even lg company has that bios, is from ''phoenix''
Mar 17, 2008 | HP Pavilion dv6000z Notebook
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Computers & Internet Logo
15 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
