Question about RCA RD2826 MP3 Player
On the fritz
I got an RCA RD2826A it came with a universal charger (and it was on a higher voltage when I accidently plugged it in, everything went black and hasn't turned on since. I am hoping there'is a chip or something besides the hard drive that burns up. Can anyone help me? It's brand new . Can it be fixed?
    Novelist:
  • 164 Answers
Everthing can be fixed, the issue is that if it can be fixed at a reasonable price.
You are right, when the wrong voltage is applied to this family of Lyra mp3 players, there are a couple of integrated circuits in the battery charging circuitry that are burned out. They do need to be replaced.
You can look for local qualified repair centers for a quote to repair it.
If you want a diagnostics/repair service for it, at lower fee, you can contact the Ebay seller with ID Great_items_2004
Best regards,
Posted on Jul 25, 2009
I have a RCa 10 inch tablet and it just went dead on me when I press the power button all it,s showing is a battery I keep it plugged in alll the time what is wrong and do I keep my tablet plugged in
Are you using the charger? Some tablets specifically mention a similar problem occurs when trying to charge via USB. The charger has a higher output voltage.
May 24, 2017 | Tablets & eReaders
IBM Thinkpad X60- Charging LED ( Amber) flashes continuosly- battery NOT charging
An incompatible charger could be doing this, as could a failed battery charging circuit in the notebook. It is also possible that the battery is no longer capable of accepting a charge. The universal charger must be able to provide the same voltage as the original charger and have an equal or higher rating for wattage or current.
Feb 08, 2013 | IBM ThinkPad X60 1706 Laptop Universal AC...
I lost my original charger for it so is there another kind of charger i can use to charge it
There are 4 things that have to match up.
Plug - obviously the plug has to fit
Polarity - If the plug fits, this is PROBABLY ok, but the negative/positive must be the same as the original
Voltage - The voltage output should be the same as the original, which will be a few volts higher than the battery. If the voltage output is the same or less than the battery, it won't work. If the voltage is too much higher than the original, it might fry the battery and the charger.
Current rating - If the current rating of the replacement charger is less than the original, it might fry the charger. If it is much higher than the original, it MIGHT fry the battery. You can probably go +/- 20%
Jul 17, 2012 | Razor MX500 Dirt Rocket
Computer wont charge with universal charger
Please check the technical specifications of your computer charger and see that your universal charger fulfills the same. Generally it is found that the universal charge may supply the required voltage but may not provide the required amperage. That is the reason most of the electronic companies insist on their chargers. If your charger is not working please get one from the company rather than using the universal charger and the spoiling your computer. Universal chargers are OK for some of the electronic devices which do not require higher currents.
Dec 27, 2010 | Dell Inspiron 1525 Laptop
A quick question, I have an Acer Aspire 5516 and today the charger just flat out stopped working. it was a 19v 65w charger, then I had gotten a universal charger that came with 19v 75w and 19v 90w tips. I...
You do not have to be worried about the wattage. Wattage (in the case of chargers) is the capacity a charger can provide. So higer the wattage better it is. However, higher the wattage higher the price usually. Voltage has to match. But the most important thing to look for when you buy a universal adapter is the polarity. Take care to match the polarity. Polarity will be represented by a small line encircled by a circle with + AND - . If you look at it carefully you will understand that it is trying to tell you what polarity is the inner lead and the outer lead. You will see this marking on the charger and also on your laptop close to the DC in. (Usually the inside lead is positive and the outside lead is negative) However some manufacturers reverse this. (I have no idea why they do it though I think some kind of regulatory body should make a standard to avoid unsuspecting users from frying their devices). If your voltage and polarity is matching you are good to go with 65 watts or above. If this holds good, don't worry about any listings.
Sep 19, 2010 | Acer Computers & Internet
How do i know if its my battery thats not working or is my universal adapter not strong enough to charge it ?
- Your laptop should have an indicator that tells you that its battery is being charged (when plug-in to charger) or discharged (when running of battery).
- The universal adapter will have several voltage settings: make sure you have selected the correct voltage (DO NOT USE VOLTAGE SETTING HIGHER THAN REQUIRED OR YOU WILL DESTROY YOUR BATTERY REGULATOR!)
Dec 29, 2009 | Office Equipment & Supplies
Don't know voltage setting for charging this unit.
You can use any adaptor that supply 12V or more. If you have at least 800ma of current, and 12V or higher it will do the job. Higher voltage rating will charged it much quicker but you have to watch it.
Jun 18, 2009 | Xantrex Technology Xantrex Xpower...
Charger
next to the jack on the camcorder it should have a diagram that shows polarity (a + and - sign) for the plug, the tip should be one sign and barrel or outside of the plug should show the other polarity. you have to have your plug with the correct polarity, and you have to have the correct voltage( it should say 9v or 12v or something like that) and the supply you use should be as high or higher of a current rateing as recommended in your users manual or printed on the supple that came with it.
Dec 27, 2008 | Universal Battery Charger Charges Multiple...
Bad or Missing lyra_sys folder
Does it come with an original restore disk?
Feb 03, 2008 | RCA RD2826 MP3 Player
Programming RCR311 universal remote to samsung tv
RCA Universal Remote Control-Programming Codes
Try chicking on the web page above and see if this helps. Good Luck.
Ed
NC Electronic
Mills, Wyoming
Jan 25, 2008 | RCA RCR311B Remote Control
RCA RD2826 MP3 Player Logo
52 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
