Champion evaporative cooler wm28 - Heating & Cooling
2 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: we have a champion mastercool
Hi, I am surprised Home Depot didn't have one as this is a very common motor. I don't know where you are from, but if you look on lone for Grangers supply, or Motion industries, they will have this motor for sure. They both are large suppliers of anything you need in this line of parts. This is a very common motor, totally sealed bearings and body with adjustable sheave, ( pulley ). Please let me know what you find. I will be here to help.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Aug 14, 2010
How to i fix my swamp cooler
sounds like a alignment problem. take a straight edge between pulleys. also start out with new belt. be sure your using original belt number.
Aug 04, 2015 | Champion Cooler 4000 CFM Down-Draft...
Ultracool Portable Evaporative Cooler CP35--says "no water" but water has been added---how to get it to work.
I have/had the same problem with mine and I know it to be the float as I took it apart and I can get it to work if I remove the circuit, but then if it runs dry and I am not around, I run the risk of burning out the bump. I can't find the replacement part; anyone have a clue where to get parts?
May 29, 2014 | Champion International Champion Cooler...
Champion CSF30 compressor high screw temp fault
Check the oil level, if oil level is ok, check the cooler for cleanliness, if cooler is clean, check the thermal valve by measuring the temperatures going in and coming out of valve. The final thing would be the air-end (pump). has lost it clearances.
Apr 04, 2014 | Champion Air Tools & Compressors
Marvel wine cooler leaks water
All coolers produce water as a result of condensation which occurs when air is cooled. The water appears upon the radiator (technically called the evaporator) inside the cold area of the cooler. When the water drips off of the radiator, it is caught by a pan which may or may not be a removable piece. The pan should lean toward the rear of the cooler and the water should pour into a drain tube. The drain tube should lead down into the compressor area of the cooler and deposit the water into another pain which is outside of the cooler where it should evaporate back into the air. Sometimes "cardboard" fins are used to help the water evaporate. Sometimes a pan with a huge surface area is used to help the water evaporate. Other times the pan is literally on top of the compressor. Make sure the cooler itself is level. Make sure room air is able to move over the pan where the water is supposed to evaporate. Make sure the drain hose is not clogged. Make sure pans are not leaking.
Jun 11, 2011 | Marvel (6SBARBSG) Wine Cooler
Can I get a replacement filter for my cp35 I dropped mine and broke it
http://www.appliancefactoryparts.com/evaporativecoolers/ultracool/cp35.html#Other-Parts
Jun 07, 2011 | Champion International Champion Cooler...
We have a champion mastercool evaporative cooler single inlet ASA 71 ordered from Home Depot. I am having a hard time finding a 2 speed 1 hp motor for it HELP!
Sincerely,
Shastalaker7
Aug 14, 2010 | Mastercool 67680 Evaporative Cooler Air...
I need a wiring diagram for a mastercool evaporative cooler
Here is a link to the owners manual for the new Symphony brand evaporative cooler. Symphony is the new name for the old Adobeair brands Mastercools.
The owners manual will have the motor and pump wiring schematic.
Sep 03, 2009 | Mastercool 67471 Evaporative Cooler Air...
Evaporated cooler is not filling up with water
yes ur water pump is not working properly..
ur will have to check it
Jun 29, 2009 | AdobeAir Mobile Swamp Evaporative Air...
Evaporative cooler pumps in dust
You should not have dust. Your water pump is probably shot. The hoghair might need to be replaced or the whloe unit might need a good hosing down. As far as a draft all the time? That is what you want in an evaporative cooler ain't it?
May 16, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
