Question about Sceptre 17" LCD Monitor
No picture i have a sceptre monitor and it shows no picture. the power comes on and the blue light flashes. Can this problem be fixed?
  • Anonymous Jul 25, 2008
    where can i get a schematic for this monitor nope i tryed sceptre but they
    will not sell their schematics to the comsumer need the power supply board for this moniter, or schematic. i have repaired tv's for a long time but
    not a monitor can any body help. the blue light flashes i replaced mosfet n- chan 600v 4a to 220fp and it still flashes.
    thank you cowboy1 the power transistor is stp4nk60zfp--or-497-5980-5-n0
  • chefdave136 Nov 06, 2008
    sceptre monitor s1902D. I am having what appears to be the same problem. The power indicator light flashes green but no raster on screen.
    Problem Solver:
  • 12 Answers
I fixed mine. Had to replace one bulging capacitor in the power supply. Yours may need more or less but it was pretty easy if you do any electronics. The specifics can be found under some of the other problem posts, especially for one of the 19" sceptres.
Posted on Jul 31, 2008
If you take the back off the monitor....you should be able to see the part numbers on the power supply and backlight inverter....I would think it would be one of the two....also some of these monitors have combination power supplies with the backlight inverter built into it...either way you should be able to buy the part on ebay or from jimmy johns
Posted on Jun 07, 2013
Sceptre said it is the power inverter and they'd fix it for $100. I'm still trying to find a replacement inverter so I can fix it myself (if that's possible). Email Sceptre if you want to spend $100 they said the $100 is parts and labor....
monitor-ts@sceptre.com is the address here is their email to me.
Dear Customer,
The unit is no longer under warranty.
As long as it is not the display panel, it costs $100.00 USD to service
the monitor, parts / labor included. If you are interested in the
repair, please go to our website http://www.sceptre.com. Click on
SUPPORT. Download the RMA form and fill it out completely including the
out of warranty box. When you have finished filling out the form,
please fax it back to us for processing. We will give you a RMA number
within 24-48 hours. Please put that number on the box that you are
going to ship the monitor in. When you have finished packing up the
monitor, you'll need to ship the monitor to us with the address that is
at the bottom of the RMA form, thanks.
Best Regards,
Sceptre Technical Support Group
jolenetollenaar@comcast.net wrote:
> Hello,
> Thank you for returning my email, the serial number is 441M1112SA0735 and the
montior serial number is S1902D
> Thanks again,
> Jolene
> -------------- Original message --------------
> From: Sceptre Tech Support <monitor-ts@sceptre.com>
>> Dear Customer,
>> Most likely the power inverter of the unit is no longer working.
>> What is the serial number of the unit?
>> Best Regards,
>> Jolene Tollenaar wrote:
>>> I am trying to get my monitor to stay on/up. I hook it up, turn it on and it
>> comes on. I can see the image then 2 seconds later the screen goes dark. I
>> think I need to update the driver but because there is no image I can see to
>> update it, I have downloaded the driver but like I said I can't see to
install
>> it. Also, I am thinking I need to update the firmware for the monitor and I
am
>> hoping you can direct me to that.
Posted on Jun 04, 2008
3 Suggested Answers
SOURCE: Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Posted on Mar 10, 2008
  • 8 Answers
SOURCE: no picture sceptre 7x 17" monitor
Check for a bulged capacitor. They should be flat on top, look for one, possibly two with a "bulge" on the top :)
Posted on Nov 30, 2008
Power blue light flashes no picture
This indicates a power supply and inverter board issue, caused by bad capacitors that sometimes bulge indicate it is open.
Feb 23, 2011 | Sceptre X240T1920 Monitor
Exact Same Problem- Mfr charges 100$ to fix - another way?
Check for bulging capacitors on the DAC (power supply board) replace any that look bad, if all look good replace entire board. should come in under $50
Aug 17, 2009 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
I have a 20 sceptre widescreen lcd monitor
Have you tried any other monitor connected to your computer since your current problem? Check your connections, make sure your VGA cable/DVI cable are in good condition. If none of that works try to RMA it to sceptre if your still within the 1 year period.
Apr 07, 2009 | Sceptre X20g-Naga III 20.1" LCD Monitor
I have a sceptre x9g-naga III
Not an expert, but from what Ive read, this is a cfl inverter issue. I had the same problem on my Sceptre. Good luck finding parts. My solution: get another monitor.
Feb 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
No picture sceptre 7x 17" monitor
Nov 08, 2008 | Sceptre 17" LCD Monitor
Sceptre monitor x7g-nagaVI
Problem is 2 Capacitors on the power inverter board, at 1000 uf 16 volt. This one was on the model xg7-naga V 17 inch monitor.
Jan 14, 2008 | Sceptre 17" LCD Monitor
32" Sceptre LCD No POwer
0939a31.jpg This is the same problem I am having with my Speptre X20WG Naga Monitor.
The power LEDS are usually red in standby and blue in opp; but now they just go purple and nothing happens..no sound no picture. I called tech support and no dice they just wanted my money, but I think all we might have to do is change a fuse on the main pcb! As you can see the white arrow isnt really pointing to anything specific! I think the fuse is the lt blue component, but am not sure. This is all I can offer! If you gat any good tips or if anyone else finds a fix please email me pbj0327@yahoo.com.
Thanks! and good luck m007!
Nov 28, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Sceptre 17" LCD Monitor Logo
1,188 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
