Question about Garden
DR Trimmer / Mower Owners Manual - Garden
4 Suggested Answers
Dolfoff
  • 148 Answers
SOURCE: Need motor manual for Model FC-150V engine for DR TRIMMER/MOWER
If it's Parts Lookup you need you can click the link HERE and select the particular "Type Code" of your engine.
Kawasaki built thirty (30) variations of the FC150V engine (depending upon the application) and the link will take you to where you can choose which one you have.
Hope this helps,
Dolf-
Posted on Oct 17, 2009
bbreton
  • 437 Answers
SOURCE: Need manual for kawasaki Model FC-150V 6.75 engine
You did not specify what manual you needed. But Kawasaki has a website, www.kawpowr.com. You go to it, look under engines; parts catalog; 4 stroke engines; and put in your model and it will come up with a parts catalog for you. Hope that helps.
Good day.
b32d7b0b
  • 269 Answers
SOURCE: 80s model Dr trimmer mower. What size belt?
Parts info and manuals here:
Ordering Parts DR Power Equipment
Posted on Aug 07, 2015
DR field and brush mower belt was off when delivered. I put the belt on and it came off again.
There is a bolt that can be tightened or loosened to tighten/loosen the blade belt. Look in the manual and/or call DR. Their customer service is excellent. I could explain it, but I'd have to write a small book. I promise you it's in the manual.
Aug 06, 2013 | DR Power Equipment Reconditioned 20HP...
I have a toy-bilt trimmer/mower misplaced the manual. cannot get the strings to stay in. thought i might be missing a bushing or the like for the string to grab hold of [between the metal plates]. wanted...
The manual and parts diagrams for many Troy-bilt products are available here: http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001 . You will need your model and serial numbers. http://troybilt.custhelp.com/app/answers/detail/a_id/253 gives the standard format for the model numbers. The model and serial numbers are given on a plaque on the trimmer/mower. The plaque is in a location that is unlikely to get damaged during use.
I hope this helps.
(I know where to look for this plaque on other Troy-bilt equipment but I'm not sure exactly where it is on the trimmer/mower.)
Jun 19, 2011 | Garden
I'm trying to do some work on my DR Trimmer and Mower. I need to know the configuration for putting a belt back on and how to adjust the cable that activates the mower head
The DR Trimmer/Mower V-belt (1/2” x 45” 4L450) loops around the Trimmer Head pulley and the engine pulley. The V seats into the pulley grooves and the flat side faces out.
On older models there is a stationary idler pulley near the front of the trimmer which remains inside the belt loop. Another smaller pivoting idler pulley sits further back near the engine pulley and rides on the outside (flat side) of the belt loop. This is attached to the clutch cable which can be adjusted to apply more or less tension to the belt.
To adjust the clutch cable on older models, follow it down to where it mounts to the Trimmer frame with lock nuts. Loosen those lock nuts and move the cable in small increments forward for more belt slack or backwards for more belt tension, tightening up the lock nuts when you find the proper position.
If you have a newer model, the trimmer won’t have the stationary idler pulley, it will have a twin idler pulley that pivots on a bracket and is attached to the clutch cable. The belt loops to the outside of the first idler pulley and to the inside of the 2nd idler pulley (pulley is inside belt loop). Be sure the belt retainer brackets don’t rub against the belt when it is engaged.
The Clutch Cable adjustment is the same procedure except that the adjuster is mounted to a bracket on the handlebars with lock nuts.
You may download the DR Trimmer manuals for more detailed information at the following web link:
http://www.drpower.com/Trimmer-Mowers_Manuals.aspx
Jun 12, 2010 | Garden
Need manual for kawasaki Model FC-150V 6.75 engine for DR TRIMMER/MOWER
Good day.
Oct 17, 2009 | Garden
Hope this helps,
Dolf-
Garden Logo
154 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
