Question about Music
Hi, I would to say thanks a lots to let put some words on yours email box. It's just regarding about how to set up a live band gigs @ outdoor stage in to mixer system. In a mixer setting, i wana know how every single of these instruments and it's amp speaker that sound should be like, more kick and nice to listen on stage. There are: 1. Drum with 1 set mics @ Bass drum, snare, hi-hat, tom1, tom2, floor tom and cymbals as well, line in to mixer. 2. Yahama keyboard with it's roland 8ohms speaker line in to mixer. 3. Guitar fender with it's fender 8ohms double speaker line in to mixer. 4. Guitar fender with it's marshall 8ohms speaker line in to mixer. 5. Bass guitar fender with it's fender 1000watts speaker line in to mixer. 6. Mics for a singer around 3pcs. For exposing the sound, i've possessed: a)2 pairs of big peavey speaker above 1000watts and 1 pair of carvin 800watts. b)2 units power amp. i)Peavey 1200watts ii)Behringer 2500watts. c)2 pairs of peavey moniter speaker 800watts.
    President:
  • 1,138 Answers
You will need at least a 24 channel mixer to give you spare channels. You also need an active crossover and a snake. The advice you need is too much to include here so I am including some links:http://mixonline.com/live/FixIts/, http://en.wikipedia.org/wiki/Live_sound_mixing, http://mixinglivesound.com/blog/tag/outdoor-concerts/,http://mixinglivesound.com/blog/, and http://www.scribd.com/doc/11435651/Beginners-Guide-to-Mixing-Sound. You may need more monitors than you are planning on and you might consider in ear monitoring.
Posted on Aug 22, 2010
On stage live...I want to use the B205D as a personal monitor...the band uses a Yamaha EMX512SC 8 powered mixer on stage...What would be the correct connections to hear only my vocals in the B205D monitor...
Oh my... the EMX512SC does NOT have any "sub busses" there fore there is no way to just hear YOUR vocals where there are other vocal present. The way to connect this is to run YOUR mic into the B205D and then run the line output that is intended to run to other B205D's from the B205D into a channel of the EMX512SC.
Jun 24, 2011 | Behringer Active 150Watt PAMonitor Speaker...
When i use my epro live drums on live gigs i sometimes get no sound when i hit the pads specialy the snare pad
Not used this kit inparticular, but if there is a main "brain" or sound mudule, check sensitivity settings. If not, take the pad to the store where you got it as the internal sensor may have gone, or the link lead may be faulty.
Jan 16, 2011 | Pearl ePro Live EPLX205P/C31 Electronic...
Hi there, I have a Nord Stage EX 76 and played a gig on friday night outdoors. I have set the keyboard up and now one or two of the notes occasionally sound much louder than they should. The problem...
What has happened is that one of the contacts on those notes is not working properly. Each key has two contacts. One makes before the other as the key is pressed. The processor MEASURES the time between those as you hit the key to read the VELOCITY you have hit the key with. This velocity is often used for loudness on many voices such as the piano. These contacts are USUALLY conductive rubber pills suspended in silicone rubber "domes". One can disassemble the key area and clean BOTH the black rubber pills and the circuit traces they are pressed against using Q Tips and ONLY 99% isoprophyl alcohol to restore proper operation
One needs to be very careful when disassembling unit as there are many tender ribbon cables and connectors. Best to have clear work area and two people to "control" the halves of the shell while opening..
Nov 07, 2010 | Clavia Nord Stage 88 - Digital Stage Piano...
I have an older Pyle 10" PA speaker and somehow it's completely blow itself to smithereens ...after lending my PA to an away band for a local gig, the band however they claim they never used the...
You need to search for a service that can "recone" speakers... However, you might be better to just replace the speaker in the cabinet. A 10 inch speaker is not that expensive.
Oct 24, 2010 | Pyle Music
Hi, I've owned a Fender Hot Rod Deluxe since '01. Around '06 I started having problems like crackling sounds when on but guitars volume was all the way down. Loss of volume here and there. While amp was on...
In YOUR amp, take a pencil and tap teh sides of the tubes GENTLY, listening for any crackling... note SOME microphonics is normal in the preamp stages.
Since retubing it fixed it once, it is likely either a tube was bad OR a pin of a tube wasn't quite making so replacing the tubes cleaned it and made it work. Tubes DO go bad, especially when they are vibrated like in these amps... BUT don't just replace the lot, try to find which is at fault..
On your friends unit, LIKELY an electrolytic bypass capacitor for one of the reverb preamp stages has dried out and needs replacing.
Apr 23, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Loading an MPC5000 with midi files
if the mpc has GM soundbank then this should be possible. You might be better off recording the audio from a suitable GM unit first of all before gigging with it, then you can make it sound the way you want and change the key to suit etc.
Dec 18, 2009 | Akai Mpc2500 Music Production Center
Hi! Im looking for the service manual or schematic for the Digitech Valve Fx guitar eff.proc. The unit can turn on, and in bypass mode has a clear sound, but in normal operation has terrybly noisy, It...
hello,
can be too late but one never knows:
http://mesnotices.fr/314159.php?k=b7e42b97c5e87d24451de2516f66eef9&ID=18334&q=DIGITECH%20VALVEFX
you must simply answer the questions to be able to download.
Philippe to France
Jun 10, 2009 | Digi-Tech Digitech Vocalist Live 4...
After a few minutes of use, there is clipping and sound cutting out with the guitar through. Vocal and harmony are fine. I tried using different guitar cords, different guitars, different amps to no avail....
I know you hate this answer, but it needs to be repaired. It has a circuit board inside, and there's really not a work-around. But it is broken. I totally understand about not wanting to send your gear out, especially if it's a pedal board you have set just right, and are completely usweed to using. You'll be a lot happier with it if you get it fixed though. Or find another one on eBay. I sold all me Digitech pedals when I got my Pod - but that's just me, I use a lot of distortions and it fit the bill better for me. I used Digitech pedals for about 20 years and thought I would hate anything else.
Take care.
Mark
Jun 05, 2009 | Digi-Tech Digitech Vocalist Live 4...
Low volume on acoustic and jazz amp type
Ok, so I hope you realize the Fender FM25DSP guitar amplifier is an "entry level" NON-valve amp with a DSP chip that has model shaping tones. I am sorry but this is a toy and Fender did not spend the tens of thousands of US dollars to have built-in tones that truly 'kill". This not digital modelling like Line 6 or Fractal Audio did and so you have a problem from the start. This amp was always intended as an entry level amp for the bedroom only and never to be used on stage.
Jazz and acoustic modes have some similarities requiring mid-range boost and some rounding. Not easy to achieve with a DSP chip that costs about US$10 to manufacture. Sorry, consider using the amp for practice but look at a more serious valve amps for live on stage
Apr 01, 2017 | Fender Fm25dsp 1x10' Guitar Combo...
Music Logo
185 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
