Question about LG KF700 Triband 3G HSDPA 3MP A2DP Phone Silver
My phone won't pick up any signal in a full signal area.
Can't send or receive multi media text and picture text won't download when i get them
Contact your service provider and ask them to send settings to your phone. Its quick and free.
Jan 21, 2013 | Cell Phones
Why is the phone not picking up the GSM signal?
Try the SIM on another phone and if the same problem is seen then it can be related to a faulty SIM. Please check the network coverage of the provider in your area. Also counter check the phone with a working SIM to confirm the phone.
Jul 05, 2012 | LG KP500 Cookie KP 500
My LG thrill suddenly lost it's signal, and now
I had the same issue. A factory reset fixed it.
Dec 26, 2011 | LG Cell Phones
My LG Ally phone will carry a wifi signal & has internet access. It will not make normal phone calls & my 3G icon will not return to my status bar. Any help would be appreciated.
Try reprogramming your phone by dialing *228 and selecting option 1. If this call does not go through, your phone either has a broken radio (which I do not believe you can replace, you would need to start the warranty replacement procedure with Verizon), or you are in an area with very weak to no signal.
Try the process again in an area with stronger signal, and if it works, dial *228 and select option 2 to update your PRL (list of towers), then try again in the original location to see if the updated list helps your phone find a tower.
If you find that your phone is getting signal in other areas, but not a specific place that it used to, you should call Verizon from another phone and pick option 3. Their tech support can do advanced troubleshooting with you to find any potential problems with the network, and they can file a trouble ticket if there is a problem with the tower in your area.
If this helped you, help me with some thumbs up!
Jan 04, 2011 | LG Ally Cell Phone
I can't find any signal with my phone!
Firstly, switch off your phone and put it on again if the location is different from where you used to use your phone, or, Check the network settings and select automatic to see all the available network on the area pick from all the list and if none of these worked then the phone may need to be work on l.e to be fix.
Sep 01, 2009 | Nokia Cell Phones
Gps model 330
-after the units have been off for awhile...they need considerable time to reconfigure the satelites
-so.....
  1. go outside with unit turned on
  2. find an open area...with a clear view of the sky...i.e. away from trees/bldgs/etc.
  3. wait...upwards of 20+ minutes...depending upon your unit
  4. it should be picking up signals continuously...and begin to calculate your location
-the above assumes that the unit has batteries, hasn't been dropped, etc.
-if that is the case....then the unit has other issues
Nov 06, 2008 | GPS
Can not receive any signal
mm have u ever dropped the phone or any thing like that if it cant pick up any signal sounds like the internal areal has broken or faulty thats all it could be
Jul 01, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Nokia mobile phone
Check network settings on your phone if those are correct. If those are ok then you may have a problem in your phone hardware.
May 22, 2008 | Cell Phones
No service
i was recently told that if you use an external antenna on the razr, you can 'burn out' the internal antenna resulting in no service or intermittant service, even when in an area that normally provides strong signal, thus it may be that your internal antenna is the problem.
Dec 12, 2006 | Motorola Mobility RAZR V3
Open Questions:
See all LG KF700 Triband 3G HSDPA 3MP A2DP Phone Silver Questions
LG KF700 Triband 3G HSDPA 3MP A2DP Phone Silver Logo
314 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
