Hi - and thanks in advance - first time here - have Panasonic model CT-2769SW - audio is either happening (coming thru or mute) or not - inconsistent - any ideas ? Mike :)
  • 8,617 Answers
Could possibly be a defective audio output IC. I would try re-soldering it first though as that often will cure an intermittant audio problem.
Posted on May 04, 2008
Panasonic color TV model CT-32G9J won't turn on.
been a long time since fixed an crt tv. but if you have a stand by light the problem on this model is the control chip if remember right it sits on the left side near to the front. think its an 8 pin chip. these just go and it will not turn on. these chips are easy to get hold of and are cheap. you just need to remove it and replace with a new one. and the tv will work again. its not on the power board but is controlling the power start up. if there is no stand by light its a longer problem to solve. it could be a number of problems. would need to know if any problems happened before the tv did not turn on.
Jan 15, 2014 | Televison & Video
Black square comes on tv
hi,
in your tv the closed caption option is in on position. make it off o run out the black square.
to make the closed caption (cc) off. do the following.
1. press the menu button
2. select setup
3 go to closed caption (cc)
4. select closed caption mute (cc mute)
ok
Jan 27, 2011 | Panasonic CT-36D32 36" TV
The speakers are partially muted thru the TV mode.
you mean with all tv channels too? there might be an attenuation setting somewhere that has to be de-activated. Check the manuals. hope this helps and pls come back for a feedback
Aug 19, 2009 | Toshiba Regza 46RV535U 46 in. LCD HDTV
Picture on and off
these arent easy fixes,have them serviced
May 19, 2009 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Car CD player will not come off Mute (CQ-1301N model)
either fault in the cd player or there is a mute wire and it is shorting on body of car
Feb 24, 2009 | Panasonic CQ-C1103U CD Player
Hissing sound from a Panasonic old TV...Sound and picture are OK. The hissing sound even continues when the MUTE on the Box is ON. The hissing only stops when the MUTE on the TV is ON. I am using the...
If you disconnect or power off the converter box does the hiss go away?
If you connect a VCR or DVD player does it still have the hiss? We
need to isolate what source is causing the hiss if it is from the set or
if it is from the converter box.
When you turn the volume control down on the set, does the hiss
reduce in level? If mute stops it, it should reduce in level as you
turn the volume down. Then turn up the sound level control on
the converter box whether its a manual control or by remote. If you
can get a combination that minimizes the hiss and gets higher sound
level from the programming that may cure it.
I am not familiar with the converter box you are using. Are you using
Audio/Video cables from it to the set or is it coming out with coaxial cable
and used on a channel? If you are using a very old set with a tuner input
perhaps the fine tuning is out of adjustment.
Feb 21, 2009 | Panasonic CT-20D11 20" TV
Please Help !!!!!!!!!!!!!!!!!!!
1. hit menu, use right arrow and select 'Audio'.
2. hit menu use down arrow to scroll down and select 'Speakers'
3. hit right arrow to scroll thru options, select 'on'
4. hit menu 3 times to save and exit back to picture
Jul 28, 2008 | Panasonic CT-36D32 36" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
