Question about Fisher and Paykel Washing Machines
MW511 will not spin at end of the cycle. lid lock light dose not come on
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now, does the machine drain the water?Does the machine show an error code?The error code will be a series of lights lighting up and the machine will beep.Please reply with additional information and I am sure I can help you.
Posted on Aug 22, 2010
Mw511 pride top loader shows lid locked and issues loud beeping.Is mid cycle and full of water
When it beeps what is the error code? Look at the top row of lights and count from left to right.Tell us which of the 8 lights are on & which are off.
May 29, 2016 | Fisher and Paykel Washing Machines
Why does the lid lock light start flashing after the wash cycle and will not rinse or spin?
Lift lid, stick screwdriver into slot where lid latch-pin inserts and see if it goes into the cycle. If so, try adjusting position of latch.
Sep 01, 2014 | Washing Machines
Whirlpool cabrio wtw5600xw0 will not spin
I had the power button off so no lights were lit. I also tried it in teh done mode. None of the buttons put it into self test.
My issue with spinning is it will not complete the spin cycle and the lid lock light flashes leaving water in the tub. If I out the machine on drin and spin it will remove most of the water
I also tried the soil level temp keydance to check the console self test and it would not go into that mode either.
Honda Parts.
May 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I am having problems with MW511 - it has just started going into rinse cycle then stopping and lights number 2 and 8 come on with a constant beeping, when I press pause the lid locked light comes on as...
(01000001) Phase 5 and 6 - Pressure Transducer (Ptx) error frequency > 90kHzThe Motor Controller module has received signals from the water level sensor (Ptx)above normal frequency values.Primary Source: Motor Controller module.Action:Replace Motor Controller module.
May 11, 2012 | Fisher and Paykel Washing Machines
Hello, my MW511 Fiisher and Paykel top loader washer is not working, the lid locked light keeps flashing before the spin cycle and it keeps beeping and never starts the spin cycle... what can be wrong? I...
Hi - you may have somehow put the machine into data mode - its either that or the door lock itself has malfunctioned - the only other logical one is thw controller module.
I'm assuming its a Phase 6 - try this - press/hold wash temp & power button until u get 2 beeps & lights up - release buttons...
NOW IMPORTANT - be careful you are in memory system of the controller -
1. press start/pause to unlock/lock & toggle that lid locked lights - check default is off.
2. I think its either advance or regular to turn pump on/off.
3. try a few buttons see what happens - THEN
turn off at the wall & try it again, if it still doesn't work then we may have a more sinister problem which will require correct testing of the components.
This will require a thorough knowledge of how to interpret the test results, to nail the culprit.
Sorry cannot help further...
Jun 30, 2011 | Fisher and Paykel Washing Machines
Squealing sound on spin cycle.........
Turn power off AT THE WALL,under the wash bowl Spray some wd40 on to the pump at both ends, while this may stop it for a while. Your pump may well be on its way out. you should replace for a new one. bad pumps can cause more problems problems .
Mar 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
My MW511 model is not spinning , slow motion wash cycles, noisy
Hi blow down the hose that the waste water comes out of, it may be blocked
Nov 29, 2009 | Fisher and Paykel (IWL12)
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washer will not spin
I'm having a little trouble understanding the question because of the spelling, but this sounds like a typical lid switch not making contact either by the depressor on the lit itself or the switch is broken. try depressing the switch with a screwdriver and see what happens. The lid switch will be in a little slot in the top inside where the lid closes.
Dec 17, 2007 | Washing Machines
Washing Machines Logo
314 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
