Humming from HLP5063WX TV and no color - Televison & Video
    Brigadier General:
  • 6,966 Answers
Initially, it would be suggested to try viewing a DVD or a VCR and determine if the humming sound & no color persists. If yes then conclusively, there is something wrong with the TV. If none, then the source of the humming sound would be the tuner section (internal to the TV) or your cable TV/aerial or your cable box/decoder.
If the humming sound and no color is present in either TV tuner/channel and with an external video source such as a DVD, then chances are that a large filter capacitor inside the TV needs to be replaced. It would probably be in the power supply section AC side.
If the humming sound and no color is present only on TV tuner/channel, you would have to check your TV signal source. If you are using an aerial, it may require re-orientation; if it were a basic cable, then you would need to consult with your cable provider; if you are using a cable box/decoder, then the problem could either be with the box/decoder or again your cable provider.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 04, 2008
Loud humming or buzzing noise have picture but flashes all different colors resets and goes off after awhile good pic after that
The tv problems and causes are 100% is the tv colors wheel it is causes and the tv problems.The tv are having humming or loud buzzing noises sounds are the causes of the tv colors wheel going off and out control of it motor mount and spinning in at high RPM speed and different colors showing up or flahes of black and white color in the tv back ground.The tv colors wheel must have to be replace.Best hire a tv tech to do the replacement of the tv colors wheel,because have to take out many mechanicals parts before can even come to the tv colors wheel is self to replace it.
Aug 19, 2011 | Samsung HLP5067W Television
The tv hums, you can turn the volum down to zero znd the tv hums to loud
You have a Bad Color Wheel,that is what is causing loud humming sound.
Encompass Parts Distribution 1-800-638-3328
Samsung Parts 1-800-627-4368
Color Wheel is Located Behind Lamp ,Pull Lamp out and with a Flash Light Look inside you should see Color Wheel. Color wheel spins 9,000 rpms per second
Apr 12, 2011 | Samsung HLS4676S Television
I replaced the bulb on my Samsung HLP5063wx, and there is still a humming when you turn on the TV....it does quiet down once it has been on for a while...what could it be?
The set uses a color wheel, it is your problem---part is available on EBAY etc and can be a do it yourself repair. You Tube has video instructions for most models for replacing the wheel.
SEE attached photo of the part.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 13, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
TV SAmsung, the picture is bad after color wheel changed
Hi,it's possible they gave you a different color wheel,there's a silver version and a gold version they spin at different speed,so mostlikely they gace you the wrong version check what this website says about the 2 versions : http://www.discount-merchant.com/product-p/samsung_bp96-00674a_colorwheel.htm God bless you ask for a refund.
Oct 06, 2009 | Samsung Televison & Video
I have a Samsung DLP 50 inch tv, model #HLP5063wx xaa. A friend gave me the tv, and told me it wasn't working, probably needed a new lamp. When I try to power on the tv, it comes on but makes a terrible...
the lamp led will light when the color wheel is defective. If the noise you hear is a buzzing or screeching the color wheel is the most likely cause.
Sep 10, 2009 | Televison & Video
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Loud humming noise
Usually a humming noise is a transformer going bad.
Jan 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Televison & Video Logo
185 people viewed this question
Top Televison & Video Experts
