Question about HTC Touch Viva Cell Phone
Hi, im using my htc touch bviva from past a year i dint had any problem till date but from past 2 days my touchflo stopped working my cell phona is working fine only problem with the user interface(touchflo) i did restarting and reset aswell but was not able to fix it please help me fixing this issue
    Problem Solver:
  • 17 Answers
Turn of your phone and remove the battery for 10 minutes. The reinsert the battery and deploy the HARD RESET ( Check HTC Viva Manual how to do hard reset). Also you may try to clear storage in the settings. BY doing this your device will reset to orginal factory settings.... BE SURE TO BACK UP YOUR DEVICE before starting this... you can use SPRITE BACK UP also available on the HTC website.. download both device and PC software ... take back on PC for easy restore.
Good Luck..
Posted on Sep 05, 2010
Htc touch viva touchflo not working
Try to delete all unwanted SMS + Clear your call log and than open TODAY tab and check Touchflow tab....Cheers
Jan 31, 2011 | HTC Touch Viva Cell Phone
Touch Pro2 won't go past the htc load up screen
Make sure your TouchFlo app is turned on. Goto Start, settings, Personal TAB, Today icon, Items Tab. Scroll down the list of items and check the TouchFlo 3D item then click OK.
Apr 14, 2010 | HTC Touch Pro Smartphone
I have HTC Touch HD and suddenly Touchflo will not load...pls help
have you tried resetting? using the red button behind your battery cover, if it still doesn't work you can do a full reset which will return everything to factory settings... but it won't touch anything on your memory card.
i can't remember how to do it off the top of my head but you can google 'hard reset HTC Touch HD' and it should pop up.
Nov 17, 2009 | HTC Touch HD Smartphone
TOUCHFLO IS NOT LAUNCHING. AFTER CHARGING, I JUST SAW ON THE SCREEN "TAP HERE TO LAUNCH TOUCHFLO" AFTER TAPPING, IT SAYS "LAUNCHING TOUCHFLO" BUT IT DOESN'T PROCEED. INSTEAD, IT GOES BACK TO "TAP HERE TO...
This can be an indication of a Out-Dated Firmware. In this matter, you need to download the Software Updater tool from the Official HTC Website. If not available, take it to a Service Center of HTC and tell then to install the upgraded version.
Thank you Sir, Have a nice day.
Oct 16, 2009 | HTC Touch™ 3G Cell Phone
Themes don't run in HTC Touch Viva T2223
Themes do work but you cannot see it cause of the TouchFlo provided by HTC. If you really do not like or use the touch slider on the main view, then go to Settings > Personal > Today > Uncheck TouchFlow
Now you can see the theme, but now you will miss the regular buttons ;o)
Chose which view you would prefer.
These themes actually for other Windows Mobile which do not have TouchFlow like helpful interface.
Regards,
Paritosh
Sep 23, 2009 | HTC Touch Viva Cell Phone
Themes dont run on htc touch viva . i have installed the themes but there are no changes due to that theme .
Regards,
Paritosh
Aug 11, 2009 | HTC Touch Viva Cell Phone
Touchflo of HTC Touch 3G won't launch
Hi. TouchFlo is the special today plugin for the HTC devices, and as you realized, you can still use all functions of your PDA without. I think there is an error in the installation of TouchFlo (There can be a bunch of reasons, we have to know everything you did with your PDA in order to guess them), but there is a safe solution for that problem, you can backup all your personal data and software to your PC, then you can hard reset your PDA to its factory default settings. That way both your phone and the TouchFlo will work. In order to hard reset your PDA (after the backup of your personal data), you can follow the steps in this link: (http://www.hardreset.eu/htc_touch_diamond_hard_reset_soft_reset_en.html). Hope this helps.
May 27, 2009 | HTC Touch Diamond Smartphone
Can't Change the background of the screen
The Touch series uses the Touchflo userinterface on top of Windows Mobile and has it's own background-wallpaper setting. You probably changed the "normal" Windows mobile background picture, which is hidden "behind" the Touchflo interface.
To change the Touchflow wallpaper select the "Settings" icon in the scrollable bottombar (which leads to the Touchflow settings) instead of the "Start Menu | Settings" shortcut (that's the "normal" Windows mobile settings)
Mar 22, 2009 | HTC Touch HD Smartphone
Touchflo does not appear to be working on new Touch diamond
TouchFlo is an application that needs to run on top of Windows. It is quite well hidden in the menus....
To start with, I assume you get the normal Windows Mobile 'Today' screen? If not, you have bigger problems!
If so, hit "Start" --> Settings
Then on the 'Personal' tab, go to 'Today'
Then look at the 'Items' tab and make sure that TouchFLO 3D is the only checked item.
Hit 'OK' top right, then 'X' top right and you should get back to find it activated.
@deepak - TouchFLO 3D is standard on the HTC Diamond. If you have TouchFLO then I guess you have a HTC Touch (different phone).
Dec 02, 2008 | HTC Touch Diamond Smartphone
HTC Touch Viva Cell Phone Logo
361 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
