Question about Samsung Televison & Video
I have the 29" flat CRT Samsung television model number - CS-29K40ML and type number - KS7B29K40. When television is switched on, I see three lines all on the top 5 inches(yellow on top, green line around 1 inch below the yello line and red line around 1 inch below the green line). What is the issue? And how can it be resolved?
    New Friend:
Replace all capacitor on vertical block circuit
Posted on Jun 02, 2017
5 Suggested Answers
  • 103 Answers
SOURCE: samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Posted on Mar 05, 2008
SOURCE: LG flat panel plasma with red line
I had the same problem and fixed it by replacing the control board. It's a little nerve wracking, but required only simple hand tools. If you'd like to see detailed pictures of the repair check out my blog.
http://greenrenovation.wordpress.com/du-42px12xc-repair/
Posted on Feb 04, 2009
  • 49 Answers
SOURCE: 29 inch TV model
Sir 1- Use heavy ampier transister for hor output
2-measure h output transister base and emitter resestance value it is nearabout 15to33 ohms,you can use.
3-check lot by replacement
Posted on Oct 03, 2010
SOURCE: I have got Samsung Plano 29 inch TV. I see
I have got Samsung Plano 29 inch tv. I see redgreen and white color lines at the top of the screen.this slides down till the middle of the screen. Please suggest
Posted on Nov 25, 2010
Samsung model number CS-29K3NT plano
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ . Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Nov 14, 2016 | Samsung Televison & Video
Service mode tv samsung model cs 29z57mh
Service mode entry option to different models to this TV will differ to each other. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window
Oct 19, 2013 | Samsung Televison & Video
My samsung 29 inch flat CRT TV fell down while transporting, after switching it on only yellow display is visible, it can be repaired...?
Someone who can open it is going to have to open it to see if the circuit board is cracked/damaged and if so how bad, some sets when this happens can be repaired and some cannot
Dec 14, 2012 | Samsung CW29M64NS 29" TV
I have crt samsung television model cs-21z68mg. There is sound but no image,help please and thanks.
Check its horizontal output section circut for the fault. Most probably, line output transformer might be faulty. Not, might be, but is.
Aug 30, 2012 | Samsung Televison & Video
Please what is the factory reset for samsung tv.Modle Cs-21z58ml.
samsung tv MODEL CS-21Z58ML.no picture and low brightness problem has been re solved by replace the crt .if you found 4voltage for heater 190volt for scren still no picture you have to replace crt.but some times might be the micro chip on the circuit that its not pushing up the RGB's colors but most and common problem is CRT board.if you'll try to replace the transistors or ic.it will not change any thing.so guys letme know if you fixed it at costerntine@gmail.com thanks
Mar 07, 2011 | Samsung LN-T3253H 32 in. LCD Television
Which remote control used for 29" TV CS-29L30ML SAMSUNG
If there is any customer sevice center of Samsung nearby, please enquire there about the remote model of your tv set by giving your TVs model number, usually marked on the back side of the tv. They can surely guide you.
Oct 15, 2010 | Samsung CW29M64NS 29" TV
29 inch TV model no.CS 722 AN. H. output tr blows off and stand by blinks
Oct 03, 2010 | Samsung Televison & Video
Cuting words on the screen
Nothing wrong in you TV just resold video section and your problem probebly solve.
Aug 07, 2008 | Samsung CW29M64NS 29" TV
Cuting words
In technical language we call it cold soldring.This must be the resolve your problem.
Bye
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
46 people viewed this question
Jerry Greenberg
Jerry Greenberg
