Question about D-Link Computers & Internet
Wireless signal fades in and out on Router. Not stable.
    Guru:
  • 825 Answers
This may be due to interferences in your area... try to change the wireless channel also eliminate interferences like cordless phones, battery backedup devices...place these devices atleast 10ft away from router...
Posted on Aug 22, 2010
Samsung rv511 keeps loosing internet connection, internet turned on...
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel. 2. Analogue video senders used to send audio and video to other TVs in the home. 3. Microwave ovens emit interference in the 2.4GHz band. 4. Wireless speakers and console controllers can cause interference with the wireless router. 5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem. 6. Power cables located near the wireless router can cause dropouts and speed reduction. 7. Fish tanks and mirrors will cause massive Wi-Fi shadow on the other side of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflect wireless signal away your computer. 9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
Apr 12, 2013 | Samsung Rv511
Poor connectivity
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Sep 10, 2012 | Linksys Wireless-G WRT54G Router
My wireless network connection (Realtek RTL8188CU Wireless LAN)(dd-wrt-688), the signal is not stable, how can i make it stable, since my router is working in my other computer.
Stability could be caused by other electro magnetic signals in your home or office such as cordless phones, microwaves, security systems or other wireless devices that operate within the same frequency. try turning off any of these devices and see if your wireless quality improves.
Aug 30, 2011 | Computers & Internet
The signal range of the wireless of my Edimax br6204Wlg isnt working well. One of these days i turned it on and the signal was really poor, i just could get it with my laptop at the side of the router, and...
At this point, replace the router. I suggest a asus rt-n12 router. It a decent router for a good price. It also allows you to flash it with a firmware called dd-wrt, which turns it in to a very stable high end wireless router.
Jul 22, 2011 | Computers & Internet
Wireless signal fades in and out...is this router worn out?
If the wireless signal of the router is intermittent what you can do here to correct it is to change some wireless settings on the router like the channel that you can play around to see which channel provides a better signal for you.
You can do that by accessing the router's setup page and from there you can change the settings , you can also follow the step by step procedure from this link to correct the issue , just click HERE.
Jan 05, 2011 | Linksys WRT160N Wireless Router
Keep losing my wireless signal. always have to disconnect and reconnect. Happens on my computer and now also on my ipod. Only fix i found is reseting the router. I have a Belkin N1
Enable 802.11g only disabled DHCP use CH6 and WPA also set the Bandwidth to 20/40 MHz instead of just 20 MHz. Also upgrade firmware if you haven't done so.
Oct 22, 2009 | Belkin Computers & Internet
Low signal in the basement
maybe you should try to purchase a better wireless adapter,like dlink dwa-110
Jan 29, 2009 | D-Link AirPlus DI-524 Wireless Router
Signal from router fades in and out
i think there is a heating issue with your router. check it.
Dec 15, 2008 | Linksys Wireless-N WRT150N Router
My computer keeps dropping the signal i have already talked with a tech i need help the signal keeps on fading and i cant get on the internet with my laptop computer.
you should try checking the wireless security & channel.
make sure if your network requires a security you should check that your typing the right one cause this is case sensitive.
make sure also to check the wireless signal of your router or Access point be sure to set that on channel 11.
Sep 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless router not working
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, call supportrix and use supportcall as your promo code for 1 free technical support.
Jun 10, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
283 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
