Question about Seca Mechanical Flat Scale
How can i unlock my seca scales - Seca Mechanical Flat Scale
Seca 769 error code e.10.11
showing error code " Seca 769 error code e.10.11" how can i solve this problem.pls help me.
Oct 07, 2013 | Seca 769 Digital Scale 400 Lb with Bmi and...
I have a Seca 703 digital scales, When I turn on it says Er:1:40 Can you help me?
This could be a power issue. Make sure your battery pack wire connections are good. If they are loose, I suggest purchasing the Seca 400 power adapter, which works with this model.
Sep 18, 2011 | Seca 769 Digital Scale 400 Lb with Bmi and...
How to calibrate seca 780
I recommend you look in your local yellow pages for a scale company. Calibration is very easy to do, but we recommend that you bring the scale to a local scale company. All unit sold by Precision Weighing Balances are factory calibrated and should provide you trouble free weighing for many, many years.
Jun 15, 2011 | Seca 780 Digital Adult Scale, 440lbs/200kg
How to calibrate seca 354???please help me...
I don't know if the 354 can be calibrated.
Here are calibration instructions for the 374. It includes a toll free number to call seca in case this doesn't work.
http://ons.wvdhhr.org/Portals/20/PDFs/policies/2.12%20Anthropometric%20Measurements%20Attachment%20-%202.pdf
May 19, 2010 | Seca 354 Digital Baby Scale Pediatric...
Balance beam wants to stick at about 300 lbs. not smooth moving
I contacted the manufacturer and here is there reply.
No need for oiling or grease, but tip the scale on its side, and look
under the base. There will be four "connection points" where pivot pins
connect to the linkage assembly; see if any of those pins or linkage
points are bent or look different from the other ones.
Then, note down the serial number of the scale located on the side of
the base, or behind the column of the scale at the top or bottom of the
column, and call our Maryland repair center at 800-542-7322 ext. 111 and
speak with Tyson Long from 9:00 AM - 4:00 PM Maryland time to describe
the issue and for further troubleshooting over the phone.
I have attached our new catalogue in PDF format as well. FYI: The model
703 is a very popular, extremely heavy-duty, high-capacity digital
column scale that is a popular alternative to the mechanical physician
scales in the gym and schools environment.
Kind regards,
William Morris
Sales Support
seca north america west
Medical Scales and Measuring Systems seca corp.
3401 Centrelake Drive, Suite 320
Ontario, CA 91761
USA
Telephone +1 909 605 7600
Telefax +1 909 605 7654
E-Mail william.morris@seca.com
Internet www.seca.com
Jan 26, 2009 | Seca 700KG Balance Beam Scale With Wheels,...
Seca Mechanical Flat Scale Logo
27 people viewed this question
Top Seca Health & Beauty Experts
Tom Chichester
Donald Ayers-Marsh
Are you a Seca Health and Beauty Expert? Answer questions, earn points and help others
