Question about Maxon 49-HX 2-Way Radio
Need to know where to get battery charger for maxon two way radio serial#970906899 model#SP-1008
    Sergeant:
  • 250 Answers
Hello bobt78,
Your best bet is going to be contacting the manufacturer directly via their website at http://www.maxonusa.com.
Best Regards,
Ken
Go Ahead. Use Us.
Posted on May 05, 2008
I have a Maxon cp0510p works with charger, battery charges but won't work when I unplug from the charger
Make sure the battery is good,bad battery connecter,unplug the charger from radio,could be a switch under the battery, battery clip faulty.....hope this helps...
Feb 02, 2010 | Radio Communications
HOW TO INSTALL BATTERIES IN MAXON 27KC AND WHAT ARE THE TWO BLACK THINGS IN WITH THE BATTERIES
KC27 Maxon CB need 10 batterys rechargables 1.2 v for 12v total, use the most amperes or miliamperes possible, if you have a charger case or 27-CRDL Cradle for 27-KC you can use 13.8v regulated 5 amps. máx. but need external antenna. When you put a radio in charger case it switch to use external mic, voltage, antenna & speaker. Actually 2500 mAh "AA" battery is very common and cheap. You can charge batterys on to radio case, only need a 200 mAh eliminator at 15v for 6 hours.
May 31, 2009 | Maxon HCB-10 40-Channels Handheld CB Radio
BATTERY CHARGER HCB-30A CB MAXON
you can get that charger aftermarket at radio shack take the walkie with you to get the right power supply the voltage should be close to where the external power plug goes into the radio.
Mar 13, 2009 | Maxon HCB-30A CB Radio
Looking for these radios need new
I have a Maxon sa - 70wv2 that is operational with a mic and antenna but no charger. Make offer.
Nov 07, 2008 | Maxon 49-HX 2-Way Radio
Reprogramming a Maxon SP 100G?
Hello codeencrypt,
THE SP100G is essentially the same radio as the SP100U UHF business band unit that Maxon made at the same time, just pre-programmed for GMRS. I believe there is a programming kit for this radio (Model number: SPK400C) which may still be available for purchase from Maxon directly. Otherwise, your best bet is going to be contacting your local Maxon dealer to see if they have the capability to program he radio.
Best regards,
Ken
"Go Ahead. Use Us."
Jun 04, 2008 | Maxon SP-100G (4 Channels) 2-Way Radio
WTA-3 charger
I'm not a maxon guy, but I think this is what your looking for? http://www.scannerworld.com/content/product/model/WTA3DA
Aug 14, 2007 | Maxon HCB30 2-Way Radio
Maxon GMRS-21a
I Just had Batteries Plus rebuild mine with 600mah cells $ 23 each.
Apr 18, 2007 | Maxon Gmrs Two-way Radio...
Maxon MCB 10 A
I'm not sure about your particular model but many CB radios use the microphone push-to-talk switch to kill the speaker while the radio is transmitting. If you don't have the correct microphone or if the cord has a broken wire it can cause the radio to have no sound. Another possibility is that the speaker is bad. There is probably an external speaker jack on the back of the radio. You could try plugging a different speaker or even an earphone in the jack to see if you get sound there.
Mar 07, 2007 | Maxon SP-100G (4 Channels) 2-Way Radio
Maxon 49-HX 2-Way Radio Logo
80 people viewed this question
Top Maxon Radio Communications Experts
Steve
AnyMHz.com
AnyMHz.com
Mike Charette
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
