Question about Epson Stylus Photo R260 InkJet Printer
Page size for CD printing
I want to print my CDs from CorelDraw or Adobe Illustrator. I can't find the page size that corresponds to the CD tray. Is there a template (like a label template) specifically for the R260? If not, can anyone tell me the page size they are using?
Rick
  • 26 Answers
I use Surething to print my labels (I have a Canon IP4300) as it allows you to create your own custom templates. With the Canons the CD trays are different depending on model and I would not be surprised if the Epsons are the same. To create a template (in any software) you need an accurate ruler to get the exact measurements of the tray. Once you have them then it's simply a matter of setting your "page setup" to accommodate those measurements. You will need to specify page size, left, right and top margins. Top and left margins give the printer the start point and right margin gives width of print.
Using a graphics program to print CD labels is clumsy at the best of times and the task is a lot easier if you use a dedicated label print program. PrintCD is okay but Surething is the best! Download the trial version of Surething and then get the Canon templates (my creations) from my website here. Once you load them have a look at the page setup to see how to create your own (for your Epson).
Kev (http://www.kevsplace.com)
Posted on Sep 14, 2009
  • kev1952
    kev1952 Sep 19, 2009
    Zim - not so. Printing a CD label is the same as printing anything else - it's simply a task and is dependent on page setup (and instructing the printer to use the printer tray as the paper source). Using PrintCD (for Epsons) only makes the print job a little easier as the printer is already setup for you. However, you can use any CD label software to do the job.
I think that the CD/DVD printing ability depends on the software that epson bundles with the printer.
I had the EPSON R200 and i could only print CD's from the EPSON PrintCD software.
Posted on May 04, 2008
I'm getting an error code Illegal attribute value on my hp 4050 printer
Nothing to worry about. It just means that you have printed a page or pages that all the trays do not have the correct paper size. Say your trays all have A4 papers and you printed a PDF document (US letter size) downloaded from America. Printer prints the page, then print another page with your error message just to tell you your pages do not match the papers. This is HP PCL6 code. A Postscript printer driver will just refuse to print if page size mismatches and keep the user wondering why.
To avoid the message, just make sure that your documents have the same page settings as papers in your printer trays.
Nov 26, 2013 | Computers & Internet
I am using a Bizhub C550. I want to print an Illustrator file without maing it a PDF. Once, I was lucky to print 8.5 X 11 file using the Bypass tray. I like rinting through Illustrator ai instead of I
The easiet way is to open all trays and load the bypass and tell the machine you loading 8.5 x 11 on bypass.
You can also set it on any tray within the menu of the copier under paper > then select tray > then change paper tray settings. Usually it is set to auto. but you can change bypass to what ever size you want with respect to the spec of the machine.
Jul 12, 2017 | Konica Minolta Bizhub C550 Color...
The hp desktop 960cprint head stops mid page and shoots out paper
After scanning and editing it open it in Adobe Photoshop or in CorelDraw. Set the page size and layout. Keep bitmap resolution setting in corel at 300dpi, same for photoshop too and give print command from there...sodeep
Mar 13, 2009 | HP DeskJet 960c InkJet Printer
HP Design Jet 500- ODD issue- Cuts off the sheet too early at 4-6
In my experience with Adobe products and DesignJet Printers, you have to go to Effects in the Printing Preferences and change Resizing Options from Actual Size to Print Documents On: page size that you want.
It's a weird bug that never seems to get fixed.
Cheers,
Mike
Dec 02, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
Cannot print on 11 x 17 paper from one program.
hi jocelyn912 you have to adjust the paper size frome the printer propertise to fix the papesize to 11x17 ore to A3 size also tray to print via offica aplecations such as word . tray and let me know if the problem sold thanks.
Nov 21, 2008 | Gestetner Copier
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Problem Priniting on a Non Standard Paper Format with IP5200
the issue here is whether your canon can handle that size of paper. is it running on the manual insert tray?
when you choose paper source, you'll need to identify where the paper is coming from..
try that..
of course, up to date drivers are here
Feb 28, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
My printer doesn't want to respond
This is an illustrator/spooling problem. Reinstall the printer following the correct Epson procedure - Epson is very fussy here. Come off line/Disable A/V software -blah blah
Apr 26, 2007 | Epson Stylus Photo R1800 InkJet Printer
Printing an 5.5 " by 8.5 " announcement on my inkjet printer
Dear Sppamelot You did not write the software name, in which you are working. Place / open your document in word, coreldraw or pagemaker, photoshop or adobe reader. Put this document exectly in page shown on your screen, where you want to print. Size dosn't matter. it will print exect that place, where you have put it.
Apr 16, 2007 | HP PSC 1315 All-In-One InkJet Printer
Epson Stylus Photo R260 InkJet Printer Logo
270 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
