Question about Vacuums
How do you set the time and alarm on a Zenith Z1261S??
Body{padding: 10px;}#Post p {margin: 0px; padding: 0px;}#Post ul{padding: 0px;margin: 0px;list-style-position: inside;}The time settings is under the top panel of the clock-radio. Turn the device to the back. There are two screws at the top and a message saying unscrew them to take off top. Remove the screws and take the top off. You might have to pry it off a bit. There are white buttons underneath the plate. Press the "time" button and then use the back-forth buttons on the front to adjust the time. You have to adjust the time minute-by-minute. There is no hour button. You have to keep holding down the forward-reverse keys until you get to the right time. Replace the top panel and screw in the screws to put back together. You might have to open the CD door to pull the panel through the front catches. And that should do it. (By the way, this is a hotel clock radio, not a vacuum cleaner!)
Posted on Dec 23, 2012
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
How do I set a Omexey RT018B clock as I have lost the instruction book!
Press and hold the "Alarm set" button at the same taime as "DST Set" button this will then cause the year to start flashing
Adjust all settings with the + & - buttons (use "Alarm set to accept each option.
The time is the last in the sequence
Mar 27, 2011 | Vacuums
How to adjust time, date and alarm
hi please specify ur brand name and model number of ur vacuum cleaner for a normal vacuum cleaner u can see a slider on the top slide the slider to the time and select the minute button and hours button to set the time and for setting the date slide the slider to the date and set the date using minutes button and for setting the alarm slide the slider to the alarm section and set the alarm on to off the alarm there are two options u can either press the snooze button which will stop the alarm for 5 minutes and after that it will ring ring again to permanently switch off ur alarm slide the slider to alarm off tab and press ok was this useful to u pls vote for me if u liked it
with warm regards - bonefirediv
Mar 25, 2011 | Vacuums
How do I set the alarm clock on my wharfedale ne 3120?
Press the INFO button several times until you see "Alarm Status" displayed. I had to press it five times.
Then use SELECT button to choose between ALARM OFF and ALARM ON. If you choose ALARM ON, you can adjust the alarm time by first holding down the SELECT button until the display flashes. The you use the UP and DOWN buttons on either side of SELECT, to adjust the time, the type of alarm (Beep, FM or DAB) and if you choose FM or DAB, you then select the preset. Exit by pressing SELECT a final time.Then the INFO button to exit from setup.
Hope this helps.
Feb 10, 2011 | Vacuums
I dropped my battery operated alarm clock: the second hand still works but the alarm doesn't come on at the set time and the hour & minute hands don't "hold" their position - I took the clear...
The hour and minute hands can be pushed onto their respective shafts at any point in most clocks.
If you already know the time that the alarm is set, let the clock run until it sounds.
When the alarm sounds, install the hour hand and the minute hand to the exact alarm set time. If, say, the alarm is set for 6:30, push the hour hand onto it's shaft at exactly half way between 6 and 7 and then push the minute hand onto it's shaft pointing at exactly 6.
I think this should get you operating.
Gary
Jan 16, 2011 | Vacuums
I have a westclox 70034 and I need to know how to set the alarms
Push the alm1 alm2 button until your desired alarm number shows. Then hold the alm1 alm2 button for approx 3 seconds. The alarm time will flash. push the ADJ button until you reach the time hour you want. Then push the alm1 alm2 button to set the minutes. push ADL until you find the desired minutes. The push alm1 alm2 button and alrm will stop flashing. Your alarm is now set...... I to lost the manual and had to figure it out myself.
Dec 14, 2010 | Vacuums
I have a Uni-com wireless doorbell, model 55075/SC352R. I would like instructions as I'm not finding it easy to reset things and have inadvertantly set the alarm and don't know how to turn it off!
With the display in normal mode showing the time, date and temperature and with the double dots flashing each second, press the MODE button. The first press will give you the option for setting 12 or 24 hours on the time display. The second press should bring up the setting for the alarm time. Press the SET button once and it flashes the hour for the alarm. Press it again and the minutes for the alarm will show. Pressing the SET button a third time lets you set the number for each musical tone choices for the alarm. A fourth press will ' set' the alarm so the alarm time will show, plus the number representing the ring tone you selected below the alarm time. Normally what you would do next is press MODE again 3 times to return to the ordinary time display. But if you want the alarm off, instead of doing this, press SET a fifth time and this will set the alarm time to 'off' and the display for the alarm will show '-:--' now press MODE 3 times or until you see the ordinary time display with the double dots flashing. You can check the alarm is off by pressing the ALARM button - it should still show '-:--'. The ALARM button is only for showing the alarm time which has been set, not for actually doing the setting. A quicker way, starting from the normal display with the seconds flashing on the time, is to just press the ALARM button once, then press SET 5 times then MODE 3 times.
Aug 27, 2010 | Vacuums
I'm using my dad's old Panasonic RC-6064 alarm clock. How do I set the time and the alarm?
The Hour/Minute buttons are on the bottom of the radio. Just press the hour or minute buttons to adjust the regular time. Alarm is the same but you hold the alarm button on top.
May 18, 2010 | Vacuums
Vacuums Logo
561 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
