Question about The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac
The ratio of a to b is 2 to 5 and the ratio of b to c is 3 to 4, what is the ratio of a to c
    Habit-Forming:
  • 27 Answers
To solve this, you need to multiply the ratios together.
(2/5)*(3/4) = A/C
So (2*3)/(5*4) = A/C
6/20 = A/C
You can reduce that be dividing both sides by 2
3/10 = A/C
Here is an example:
Let X = 3
The problem states that A/B = 2/5
So let A = 2X & B = 5X
A = 2*(3) = 6
B = 5*(3) = 15
Now check the ratio: 6/15 = 2/5. The same as what was given.
Now lets look at the ratio for B/C. The given ratio for B/C was 3/4
Using the value of B that we just solved we get:
B = 15
C = (4/3)*15 = 20
Check the ratio.
15/20 = 3/4
Now we have the values for each of the variables
A = 6
B = 15
C = 20
The ratio of A/C is 6/20
6/20 can be reduced to 3/10 be dividing both numbers by 2
Posted on Mar 02, 2011
Diff ratio. On a 1994 toyota 4 runner v6 petrol ??
4x4, 4 cyl, 4.10 ratio, ABS 4x4, 4 cyl, 4.10 ratio, w/o ABS
4x4, 4 cyl, 4.56 ratio, ABS 4x4, 4 cyl, 4.56 ratio, w/o ABS
4x2 (3.90 ratio), 2 wheel ABS 4x2 (3.90 ratio),
4 wheel ABS 4x4, 6 cyl, 2 wheel ABS, 4.30 ratio
4x4, 6 cyl, 2 wheel ABS, 4.56 ratio 4x4, 6 cyl, 2 wheel ABS, 4.88 ratio 4x4,
6 cyl, 4 wheel ABS, 4.30 ratio 4x4, 6 cyl, 4 wheel ABS, 4.56 ratio
4x4, 6 cyl, 4 wheel ABS, 4.88 ratio there are a few options. you will need to figure it out or look at the code panel in the truck. if you want to figure it out. you will need to remove the cover from that axle and count the two ring gears and then divide the numbers to get the gear ratio. for example if one is 40 and the other was 11. would be 3.72. so here is the trick to counting the gears. they are covered in oil so have a pan ready when you pull the cover. and use a marker or crayon and mark a tooth on the gear ring. then count the gears and you will know where to stop when you get back to your mark. the little gear will be harder since its in the back. you might have to turn the wheels and you will need it in neutral and jack the rear end up. as always use jack stands to prevent damage to you or the truck..
Mar 20, 2015 | 1994 Toyota 4Runner
Please explain how you do ratios
A ratio can be simplified by dividing both sides of the ratio by the Highest Common Factor (HCF). The highest common factor is the largest number that goes into both numbers of your ratio. In example 1 you are asked to simplify the ratio 6:8. Here the HCF is 2 so divide both sides of the ratio by 2 to give 3:4.
https://www.youtube.com/watch?v=cbjQWf411O8
Mar 04, 2015 | The Learning Company Achieve! Math &...
How do i do eqivalent ratios
Ratios are like fractions: to make an equivalent ratio you simply multiply both sides of the ratio by the same non-zero number. 1:2 is equivalent to 2:4 (both sides multiplied by 2). 10:12 is equivalent to 5:6 (both sides multiplied by 1/2).
Nov 09, 2014 | Computers & Internet
What is the ratio of 400
A ratio involves two numbers.
The ratio of 400 to 1 is 400 to 1. The ratio of 400 to 2 is 200 to 1. The ratio of 400 to 10 is 40 to 1. The ratio of 400 to 1000 is 2 to 5.
Jul 03, 2014 | Office Equipment & Supplies
How do i calculate ratio
Unless you are meaning something more specific, ratios are calculated through simple division. For example if there are 2 oranges and 4 apples, the ratio of oranges to apples is 2:4, and the ratio of oranges to the total number of pieces of fruit is 2:6. These ratios can also be expressed in fraction form: there are 2/4 as many oranges as apples, and 2/6 of the pieces of fruit are oranges. If necessary you can perform the calculation 2/4 = 2 therefore there are .5 (half) as many oranges as apples and 2/6 = 0.33333333333333 therefore approximately .333 pieces of fruit are oranges.
On your calculator you should simply need to use the division button to accomplish this.
Oct 28, 2012 | Casio FX83GT Scientific Calculator...
2240 code on honda accord 2000
P2240 HONDA - Front Air/Fuel Ratio Sensor Bank 2 Sensor 1 IP Line High Voltage.
Symptoms - Engine Light ON (or Service Engine Soon Warning Light)
- High Fuel Consumption
- Excessive Smoke from Exhaust Possible causes - Air/Fuel Ratio Sensor Bank 2 harness is open or shorted
- Air/Fuel Ratio Sensor Bank 2 circuit poor electrical connection
- Faulty Air/Fuel Ratio Sensor Bank 2
- Inappropriate fuel pressure
- Faulty fuel injectors
- Intake air leaks may be faulty
- Exhaust gas leaks
Jan 23, 2012 | 2000 Honda Accord
1.the ratio of the corresponding sides of two similar traingle is 3:2 what is the ratio of there height 2.the ratio of the corresponding sides of two similar traingle is 5:9 what is the ratio of...
1. the ratio of there height is 3:2
2. the ratio of areas of the triangle is: 125:6561
3. the perimeter of smaller parallelogram is: 40 cm2
4. THe real length of the object is 7 cm
Jan 21, 2011 | Dell Computers & Internet
Ratios
1/25 IS the ratio of 1 to 25. There is not much you can say about it.
Can it be reduced to simpler terms? No! because there no factor common to the numerator (1) and the denominator (25) which you can simplify.
So 1/25 is in its reduced form.
Case of the ratio 2/100
It is clear that we can write the numerator as 1*2. To hope to reduce the ratio to simpler terms we must be able to find a factor that is common to the numerator and the denominator.
Although 100 =1*100=2*50=4*25=4*5*5 it is clear that the only factors common to 2 and 100 are 1, and 2.
To take 1 amounts to doing nothing, but if we take 2 we can write
2/100= (2*1)/(2*50)
Simplifying by 2 (the two 2 cancel each other) we get
2/100=1/50
That is the reduced form.
May 26, 2010 | Vivendi Excel@ Mathematics Study Skills...
How do you know what ratio a subaru wrx gearbox is if it doesn't have a trans code sticker on it?
This information is from my genuine service manual. I hope it is of help.
Non-turbo
Turbo
Sedan Wagon
Type 5-forward speeds with synchromesh and 1-reverse
Transmission gear ratio
1st 3.454 3.454
2nd 2.062 1.947
3rd 1.448 1.366
4th 1.088 0.972
5th 0.780 0.738
Reverse 3.333
Front reduction gear Final
Type of gear Hypoid
Gear ratio 4.111 3.900
Rear reduction gear
Transfer
Type of gear Helical
Gear ratio 1.000 1.100
Final
Type of gear Hypoid
Gear ratio 4.111 3.900 3.545
Front differential Type and number of gear Straight bevel gear (Bevel pinion: 2, Bevel gear: 2)
Center differential Type and number of gear
Straight bevel gear
(Bevel pinion: 2, Bevel gear: 2 and viscous coupling)
Transmission gear oil GL-5
Transmission gear oil capacity 3.5 2 (3.7 US qt, 3.1 Imp qt)
Mar 21, 2010 | 2007 Subaru Impreza WRX Sport Wagon
What is the gear ratios on a 1990 heritage soft tail 5 speed
Here are the stock gear ratios:
Gear Ratio (1): 10.11
Gear Ratio (2): 6.96
Gear Ratio (3): 4.95
Gear Ratio (4): 3.86
Gear Ratio (5): 3.15
Dec 21, 2009 | 2005 Harley Davidson FLSTC - FLSTCI...
The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac Logo
395 people viewed this question
Top The Learning Company Computers & Internet Experts
k24674
Stitch85
Level 1 Expert
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
