Question about Moen 87555C Trianna Single Handle Pulldown Kitchen Faucet with Soap Dispens...
LEAKS. HAVE GASKET KIT. BUT CAN'T GET IT APART!!
    Problem Solver:
  • 8 Answers
MOEN ARE NOTORIOUSLY difficult to get appart. There is a "Special tool" just for Moen faucets/tubs/showers. It is like an old "Brake drum puller" or "Faucet handle puller". I think about $10 to $12 at Home Depot or Lowes. FYI Moen and Delta both give "FREE PARTS" on "MOST" faucets for many years if not life, if your not in a hurry. Check your original paperwork for warranty. The washer at the end of the valve after being installed for more than a year, usually binds up and gets torn apart when removed. It makes it VERY difficult to remove, even with the "Special tool". They (Moen) give you a plastic wrench like thing that almost never works, with the purchase of a "New valve" DELTA800-345-3358 ..MOEN-800-289-6636
Posted on Aug 22, 2010
Oil leak from head gasket
For leaking head gasket it has to be replaced.For head gasket leaking and other troubleshooting,there are help links provided.Its suggested to click the link below and go through the troubleshooting procedure to confirm the issue :-----Leaking head gaskets? http://schematicsdiagram.blogspot.com/2011/12/leaking-head-gaskets.html
-----------Water in engine oil? http://schematicsdiagram.blogspot.com/2011/12/water-in-engine-oil.html
-----------How to replace head gasket on car?http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-head-gasket-on-1994.html-------------How to know what is faulty Cylinder head or Head gasket?http://schematicsdiagram.blogspot.com/2011/12/how-to-know-what-is-faulty-cylinder.html
-------------- Can I just replace Head Gasket on 1991 Buick Century?http://schematicsdiagram.blogspot.com/2011/12/can-i-just-replace-head-gasket-on-1991.html Location of Head Gasket ?
http://schematicsdiagram.blogspot.com/2011/12/location-of-head-gasket-on-1994-grand.html
HOW TO REPLACE A HEAD GASKET
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-head-gasket.html
How to replace Exhaust Manifold?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-exhaust-manifold-on.html
How to replace Intake Manifold?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-intake-manifold-on-acura.html
How to replace Cylinder Head ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cylinder-head-on-acura.html
Is it Easy to replace head gasket?
http://schematicsdiagram.blogspot.com/2011/12/is-it-easy-to-replace-head-gasket-on.html
Should I only replace head gaskets or complete head gasket assembly?http://schematicsdiagram.blogspot.com/2011/12/should-i-only-replace-head-gaskets-or.html
-----------FOR oil leak issue check the following help links:---Common Causes of Car Oil Leaks? http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html --------Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
---------Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
---------This will help.Thanks.
Jan 30, 2012 | 2006 Scion tC
I have a pancake compressor that won't hold air pressure, leaks out of the small hole in the head. I have replaced the head gasket and air pressure valuve and still leaks out of the hole in the top head.
If you replaced the head gasket then its probably the valve plate and gasket.
See here:
http://www.chasdayco.com/mm5/breaks/PorterCable/20041110144417_A08610-E.pdf
Jan 08, 2011 | Porter Cable Cable Brad Nailer and...
Transmission a mechanic said a hose rotted and the transmission died?? how can i fix it without replacing the tranny
Although this is may not work depending on transmission wear and tear, you will need to do this if you plan to replace transmission any way. Replace the damaged hose. Next I would get a transmission filter kit. This is a simple kit that is sold at part stores and includes filter and gasket. You will need to buy transmission fluid and a gasket sealant. Jack up the vehicle, drain the transmission fluid by loosening the transmission pan, if you need help finding this check the gasket shape you purchased. The pan will most likely be stuck a little from the previous gasket sealant. Carefully pry it apart with a flat head screwdriver or pry bar, transmission fluid will go when pan is dropped, so, be careful in placement of pan and how much you loosen all bolts. when pan is dropped check for metal shavings inside. If you have none things are looking good. Remove filter most oftenly attached with phillips head screws. Check this filter for debris and metal. If you do not spot anything serious by now, replace using new filter. Ensure you have a clean surface for the new gasket after removal of old gasket. Once you have this done, add a thin layer of sealant to pan and place gasket on top of it. Apply another thin layer of sealant to the other side of gasket and reinstall to transmission using correct tightening sequence and torque. These bolts do not need to be overly tight. Most leaks happen from overtightening bolts to pan. Usually a lil over hand tight is fine, but, check with you parts store. Add fluids to proper level and then you will be able to test the transmission out. I know it sounds like alot, but, it cheaper than buying a new transmission if you don't have to.
Sep 14, 2010 | 2000 Ford Taurus
Sun roof leaks
Most likely cause is the gasket around the Sun Roof. Most auto parts stores have a gasket kit to do it yourself. It is time consuming but much cheaper than having a dealer or sun roof specialist replacing it.
Apr 27, 2010 | 2002 Chevrolet Tahoe
We put a new plug in it lasts a couple of days then fails. the plug is not discoloured it just looks wet. The bike is a carb version 08
The carb float level(s) may need to be adjusted. It should be a simple fix with a manual. Read the instructions, and the warnings, then take it apart and fix it. Get a gasket kit, or a rebuild kit for it too, and clean the old gasket material from the surfaces good. There may be instructions in the kit.
Aug 26, 2009 | Aprilia Red Rose Motorcycles
Maytag MAH2400A Front Load Washer
likely a rubber gasket slipped off the groove.... try taking it apart and slipping the gasket back on.
heavy loads have more force during the spin cycle.
Apr 20, 2009 | Maytag MAH2400A Front Load Washer
My front loading Kenmore H2 has a torn gasket.
You will have to take the door apart to get the gasket mounted properly. Although not required, a second pair of hands really helps.
Mar 19, 2009 | Kenmore HE2 Plus Front Load Washer
Water is leaking from the unit.
Bunn makes a repair kit for this problem, Call them at 1-800-352-2866
They send the repair kit free,
Jan 29, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Moen 87555C Trianna Single Handle Pulldown Kitchen Faucet with Soap Dispens... Logo
460 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
