Question about Kodak EasyShare M1033 Digital Camera
I can not start the camera by pressing the power switch on. The display screen is also not showing any image.
  • Kodak Master
  • 6,826 Answers
A common problem is that the batteries are not the right ones, or are not charged up sufficiently to power the camera.
Are the batteries the Kodak Li Ion batteries that are required for this camera to work correctly?
Posted on Aug 22, 2010
When turn on camera lcd screen is white instead of show view in front of camera. might be internal shutter stucked.
Not much to go on. I hear a lot about white screens, but don't know what it looks like. Cold be the LED's on the back are lightning and no info is send to the screen. Did you try to change the settings? sometimes the screen is switched off, to save power. Press the display button several times. It is on the top of the control button on the back.
If you take a picture, do you get an image on the memory card? Perhaps you only can see it on the PC.
If you don't get an image (or just a white image) your sensor could be damaged.
Dec 08, 2013 | Sony Cyber-shot® DSC-H20 Digital Camera
SONY DSC-T1 CAMERA WHEN TURNED ON PREVIOS PICTURE SHOW UP FINE ON THE VIEW SCREEN BUT WHEN THE THE SELECT MODE SWITCH IS MOVED TO EITHER TAKE A NEW PICTURE OR TO MOVIE MODE THE VIEW SCREEN IS MOSTALLY...
Based on the information you've provided it seems that the CCD Image Sensor of the Camera is affected. If the CCD Image Sensor is affected, the images captured may be discolored or with lines on it. Even if the CCD is affected, the previously captured images and icons of the Camera will display normally. You may try power resetting the Camera.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
Also try resetting the Camera back to factory default: The RESET button is located at the lower right side of the control button. To reset the camera just press the RESET button using a sharp-pointed object.
If the issue remains the same, then service may be required.
Thanks for using FixYa.
Mar 01, 2011 | Cameras
Display screen no longer works while taking pictures
Sounds like they accidentally pressed the DISP or DISPLAY button on the back of the camera. This manually turns the screen on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time with the camera turned on.
Aug 01, 2009 | Canon PowerShot A630 Digital Camera
When camera is switch on the menu shows but no picture/image
Your camera seems to have ccd chip problem. Image chips goes bad sometimes and when you play recorded image it is ok but when you want to turn on the camera to take picutures, you'll see scrambled image or no image at all. The remedy for this symptom requires a replacement of ccd chip. The average repair for ccd problem is $100-$130 in the repair market. -James
Mar 27, 2009 | Canon Cameras
How do I set the start image? I've tried following the menu commands, but when I select "Start Image," my options are the logo, "off," and then a black box with a question mark. I've selected it, and it...
After going through the menu and choosing user image, view the picture you would like to set as your start image. Press the button with the E on it that is underneath the zoom button. The screen should then show four images across the top, say the word "RESIZE" under that, and have the numbers 7,5,3,and 1 down the left hand side of the display. Below the number one there is an icon of a person and a camera. Scroll down to that icon and press the OK button. Your start image should now be chosen. Turn you camera off and power it back up to see if it worked. Hope this helped.
Mar 07, 2009 | Samsung L200 Digital Camera
Canon Power Shot A710 is
The hand with parenthesis is your image stabilization. It sounds like if your images are turning out black, you may need service.
Try hitting your display button a few times and see if anything shows up on the screen.
May 29, 2008 | Canon PowerShot A710 IS Digital Camera
The display image unseen and the screen is dark
display shows ,saf, memory card ,charge symbols but not the capturing image on the display screen.After some time the camera is switches off.
It is sony cyber shot DSC- T33 .
Dec 10, 2007 | Sony Cyber-Shot DSC-T33 Digital Camera
Turn on camera but the lcd sceen is black
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Kodak EasyShare M1033 Digital Camera Logo
55 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
