Question about Acer Aspire 5570-2758 Notebook
Turning off my laptop turns off for no reson havnt had for a year yet and my usb ports dont read anything that i plug in and i have no sound,
    President:
  • 2,351 Answers
Do not walk but run to the phone & call Acer, (See you're manual for phone numbers). Before you're 1 year warranty is up.
After that it will cost you dearly for a repair. All notebooks & most PC's come with a 1 year warranty. Unless you bought a used notebook. They are warranted for about 90 days.
Notebooks turn off for a reason, usually from over heating. Acer is no fun to deal with so be firm!
If I suggest a way to repair you're notbook you might miss the chance to have the Acer Co. fix the notebook.
Please make the call!
Good Luck!
Post back if you get the chance & let me know what Acer has suggested........
Mike
Posted on May 04, 2008
My HP 625 laptop is turning all my external memory files into shortcuts and creates some weird shotcuts to...none of the shortcuts work and i can only veiw whats on my memory card or usb if i search that...
When you plug a mass storage device in a USB or other ports, the OS gives it a drive letter E,F,G, H. I ... If you insert it another time it will give it a drive letter that may be different from the previous one because some other device plugged in has that drive letter. It may also happen if you change USB port.
So if you created shortcuts that pointed to one device that had driver letter G, they are no longer be valid if when you inserted it again the OS refers to the device with another letter.
Insert a device in the same USB port. If you have to plug in many devices try to plug them in in the same order. This may save your shortcuts, but there is no guarrantee it will be so.
If you are looking for a file you know is on a device, just use the Window explorer and point to it.
Jan 27, 2012 | HEWLETT-PACKARD 625 Notebook PC
I am trying to upload pictures from my razer phone to my dell latitude d410 laptop and when I plug into to the usb port I get a message saying power surge on hub port...a usb device device has...
Using a different USB port might solve the problem, turn the phone off completely and plug the phone in after doing so turn the phone on if the same problem persists then contact the phone manufacturer and ask if its a common fault
Jun 27, 2011 | Computers & Internet
My magic jack is not being read by my acer notebook
when you plug it in does anything come up? If not then go ahead and try different usb ports and see if its read by any of them. If none of your USB ports read the magic jack and you know the USB ports work cause you can hook other devices to them then that means the magic jack is bad and would need to be replaced.
If none of your usb ports are reading any devices then that means the motherboard is bad at that point.
Aug 06, 2009 | Acer Aspire 3680 Laptop
Dell: AX210 speakers, no sound
Turn on the round circle volume on top of the speaker and you will be all set, the reson you are not able to here is because the volume is turn off and there is no marking on the volume control to say weather it sis turned off or on.
No need for drivers.
Jun 13, 2009 | Dell Audio Players & Recorders
Have 4 USB ports on my compaq R4000 lap top, and only 2 work...
its better that u dont use other 2 usb an use just 2 that works.but try this.
go to bios and load default value and save and restart .
Jun 08, 2009 | HP Compaq Presario R4000 Notebook
I just bought a new laptop Vista computer and I can not get it to read my Polaroid i735 camera when plugging the USB port in.
I know this sounds ridiculous but you have to turn the camera on.... I often have the same problem because I forget to turn it on when it's plugged in.
Jan 24, 2009 | Polaroid i735 Digital Camera
USB port
Hi-
Have you tried reformatting your laptop? chances are the USB drivers and ports is corrupted. try reformatting laptop or have ports USB check.
Hope this helps
Oct 10, 2008 | Compaq Evo N1000C Notebook
Zune 30 gig Brown Overheating
well?    This sounds like you have the wrong cord.  It is too short and so it gets power every now and then and then after doing this for a wile it gets over heated.  The power going into the Zune is changing so fast that it is causing the plug to burn-up inside itself!
I wound try to call about a warranty and then if that doesn't help then get a new cord!!!
May 29, 2008 | Microsoft Zune JS8-00001 Digital Media...
Short circuit
If you look into the USB port and there are four finger like metal contacts and one of these is bent and touching the metal casing it is shorting out the 5 volts supply. Remove the connection to the power supply and remove the battery then straighten the finers so they dont touch anything. Replace the power adaptor and try again - if the laptop now works that is fine but you will not be able to use that damaged usb port.
Please be sure to rate this solution as we depend on your feedback.
Mar 23, 2008 | Packard Bell Easy One Silver 2120 Notebook
USB Ports dont work!
Try deleting the USB controller in the system properties and rebooting. The system should reinitialize the hardware and reinstall the drivers, which should take place automatically.
Feb 14, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5570-2758 Notebook Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
