Question about Poulan Genuine Weedeater Part # 36006-128
Hello.érdeklÅ?dnék hogy van nekem egy weed eater wg1136-os fűnyíró traktorom és ékszíjra lenne szükségem de nem tudom a méretét,esetleg ebben szeretnék segitséget kérni.köszönöm
KMusselmann
  • 247 Answers
SOURCE: starter rope on bv2000 weed eater blower needs to be replaced.
Hi, Try the following, But make dure you can wind the spring. If not the spring is broken.
Kurt
This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
6. Put the blower housing back on and your ready to start the engine & mow.
Posted on Mar 23, 2009
#1 Taper
  • 1041 Answers
SOURCE: weed eater starts, runs 5 min. then cuts off
The gas cap may be clogged.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
Just let me know if you need further assistance.
Jim
Posted on Jun 28, 2009
bulldogchief
  • 388 Answers
SOURCE: Can't get weed eater started. Have an older weed
This is a common problem on older Poulan models. Press the primer button 10 times and pull the starter rope twice, then pull the spark plug and examine it. If the plug is wet that means gas is definitely getting to the combustion chamber. Next thing is to use a compression tester. If you do not have a compression tester but have an AutoZone anywhere near you, you can get a loaner from them. Screw the compression tester into the plug hole and pull the start rope 4 times. If the tester reads anything below 90psi, you have a bad ring and will have to take the motor apart to clean the piston and ring or replace the ring.
Keep me posted on what you find, ok? I can walk you through the procedure to replace the ring if necessary. Good Luck!
Posted on Sep 17, 2009
Testimonial: "thanks...I will give it a try and keep you posted"
  • 64 Answers
SOURCE: Having a problem starting my Shindaiwa T22 Weed Eater.
take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
Posted on May 04, 2010
suzukiracing
  • 200 Answers
SOURCE: my weed eater starts but won't stay running. what
Try a new spark plug.Thanks for asking and I hope it helps
Posted on Jul 21, 2010
Jó napot! Egy Samsung GT-E2120B fajtájú
Write these into the home screen. I think your phone will be unlocked.
#pw+744 340 570 225 443+1#
#pw+816 001 043 452 307+2#
#pw+144 574 377 237 374+3#
#pw+393 836 722 100 735+4#
#pw+207 245 732 534 547+5#
#pw+177 804 703 540 107+6#
#pw+723 810 650 120 516+7#
Thank you...
H.M Rezoan Duranto
Jessore, Bangladesh.
Dec 31, 2010 | Samsung Cell Phones
�dvözlöm.Van egy Compaq M 300-as
please post in ENGLISH
and then ask a question.'
tell what OS too, operating system or all answers may be wrong.
M300 printer or PC?
it has full name and model number on the service tag
this?
https://support.hp.com/id-en/product/compaq-armada-m300-notebook-pc-series/96234/drivers
May 11, 2017 | Compaq Armada M300 Notebook
A képernyÅ?n egész nap a brithness beállítási ablakot nézegetem bármit csinálok nem tűnik el a...
Ugyanez volt a problémám.
én mechanikusan tudtam csak megoldani:
Talpat leszerel.
Ezután egy csavart fogsz találni, ami az előlapot rögzíti. Kicsavarod.
Alul, a két sarokban lesz 1-1 "pattintós" műanyag. Ezeket nagyon óvatosan nyomd be valamivel (ne késsel, hanem valami tompa, életlen tárggyal).
Eztuán óvatosan el lehet választani az előlapot. én erre egy nagyobb sima csavarhúzót használtam.
A gombok egy külön panelen vannak elhelyezve, amelyik egy csatlakozón keresztül juttatja el az infót a kijelzőhöz. Ezt a csatlakozót széthúzod és vége a problémának.
Persze ezután semmit nem fogsz tudni állítani és kikapcsolni sem tudod majd a monitort, mert egyetlen gomb sem működik, de 0 forintért megoldottad a problémát.
Ha bővebb infó kell szólj (roudi22@gmail.com)
Sep 16, 2010 | Philips 190V6FB 19" LCD Monitor
Sziasztok! Az volna a problémám,hogy a készülék működik,de a bázisállomást nem...
hello,please kindly resend the question in english language so i can provide you with adequate solution.
take care.
Aug 15, 2010 | Cell Phones
Poulan Genuine  Weedeater Part # 36006-128 Logo
Top Poulan Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Poulan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
