Question about Whirlpool Dishwasher Water Heater Thermostat Control - 303282
Whirlpool water heater will not stay lit. - Whirlpool Dishwasher Water Heater Thermostat Control - 303282
  • 490 Answers
Two main possibilities: It could be a ventilation issue, in which case check the vent pipe is not blocked or clogged. Depending on the installation type there can be fresh air intake issues as well. Some draw outside air through a vent in the floor.
Second issue could be the thermocouple; the sensor that tells the valve to stay open based on heat from the pilot. Always turn gas to the off position and ventilate for several minutes between tries for safety. Hope this helps:)
Posted on Aug 22, 2010
My water heater will not stay lit.
Make sure that you used the correct thermocouple. If so then you probably have a bad gas control valve. Also make sure that there is a drip leg in the gas line.
Good luck,
Marty
Dec 06, 2012 | Whirlpool Water Heaters
My water heater pilot light will not stay lit
1) Copy following link for troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Clean air intake located on bottom of heater of American, State, Craftmaster, Reliance, Whirlpool, Kenmore
http://waterheatertimer.org/images/Flame-trap-inspection.jpg
3) Gas control valve thermostat might be bad.
Lowe's hot water heater pilot light will not stay
If it is one of the new ones with the fancy gas control and the blinking light... does the light blink?? or not??
If it is blinking then the pilot should stay lit...
If it will not blink then the sensor is bad or not in the right place...
Or... the gas control is bad... this is happening alot...
If it is brand new... take it back...
heatman101
Sep 05, 2011 | Whirlpool Water Heaters
I have an old whirlpool gas water heater and the pilot will not stay lit.
Suspects include bad thermocouple, thermocouple slipped down and not in pilot flame, dirty combustion parts and pilot tube, dirty air intake, backdraft caused by other vent fans pulling air down water heater vent, water dripping down vent because of poor venting, air in gas line, low gas pressure, bad gas control valve, hot attic environment, tight house not allowing enough air:
Replace thermocouple:
http://www.youtube.com/watch?v=v0aBPsNg6vo
http://www.youtube.com/watch?v=xGQngzqrIEE&NR=1
Troubleshoot pilot:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Clean combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Aug 24, 2011 | Water Heaters
Pilot light will not stay lit.
More than likely the thermal couple is defective. The thermal couple is a safety device that shuts the gas off if the pilot goes out. If it is defective the pilot light will not stay lit. The thermal couple is the device that the small copper line goes to. It is mounted beside the pilot flame and the flame much touch the TC for it to work. If the flame is not touching the TC bend it until it is in the flame. If it is touching the TC then replace it.
Jul 28, 2011 | Whirlpool Water Heaters
Whirlpool will not stay lit, having to relit about every month
Before calling service technician, open following links for help diagnosing common causes
http://waterheatertimer.org/pdf/Corrosive-atmospheres.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 28, 2011 | Whirlpool Water Heaters
Model # BFG1F4040S3N0V RESET BUTTON WON'T STAY LIT
You have a 6 year tank-type low-nox gas water heater
http://www.whirlpoolwaterheaters.com/products/ByCategory.aspx?id=1
Google search 'low nox' for more details about low nox type water heaters that burn fuel so less NO2 irritant is vented into atmosphere.
Owner's manual:
http://www.whirlpoolwaterheaters.com/downloads/6510397.pdf
1) You said 'reset button.' Only mention of 'reset' in manual is about FVIR flammable vapor ignition system where water heater shuts off when exposed to vapors that might catch fire or explode:
This model appears to have Whirlpool's new resettable FVIR so read instructions in manual for resetting FVIR. If FVIR will not reset using instructions, then call whirlpool at 1-877-817-6750
2) You said 'won't stay lit.' Manual has troubleshooting flowchart starting on page 24.
There are 13 items listed for pilot won't stay lit, with possible remedy for each.
There are 9 things for burner will not light, with remedies.
Call whirlpool at 1-877-817-6750
3) Save manual posted above. I install water heaters and tell everyone to read and save manual to empower them to help themselves.
4) Call a plumber for service.
5) Add a comment for more free help
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Jan 24, 2011 | Whirlpool Water Heaters
Whirlpool Dishwasher Water Heater Thermostat Control - 303282 Logo
118 people viewed this question
Top Whirlpool Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
jdthefixer
Mike
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
