Question about Cameras
My Samsung st50 turns on and seems operational but their is no view even though the lens cover is open? Please help :)
  • Cameras Master
  • 4,924 Answers
If you do not see anything ..not even the menu ..it means that either the ribbon from the display or the display itself is gone ...
if you do see the icons from the menu ...look for something in the view area called preview and enable it ..or ...just look in the main menu for the settings and than reset to the factory settings ..and enable it ...this will get it back to the original settings ..if the preview on the camera is stopped..by mistake ..But like I said ..if there is nothing on the monitor..not even a menu icon ..than it is something wrong physical with the camera and you will have to open it and see whats wrong ..either the ribbon is out from the plug or you need another display ..
Posted on Aug 22, 2010
Why my ST50 Samsung camera cannot work even after battery being charged. If I put on photo taking or video icon it will beep and then it gets turn off. Thanks Helen
It could be a lens error or battery already malfunctioning. Do you get any error message or any message at all before it turns off?
Nov 01, 2011 | Samsung TL100 / ST50 Digital Camera
When I take a photo, it just shows white on the screen and each photo is white when I view them. However I can still take videos just fine! whats wrong with it? It is a Samsung ST50
Hi you have very interesting problem. It seem to me just lens unit defective. What I can tell between camera picture mode work and video mode work are depend on how mechanical shutter unit and electro shutter signal work. It is kind of technical thing to figure them out. Maybe I am wrong, but I sure also. Thanks and best regard!
May 24, 2011 | Samsung Cameras
Samsung TL205 Battery Charger http://www.samsung-battery-charger.com/Battery-Charger/Samsung-TL205-Battery-Charger.html Samsung ST50 Digital Camera Battery...
What a battery of information you have accumulated - you must be a bright spark. Please put a plug in it now.
Jun 27, 2017 | Samsung Cameras
When i turn it on it says turn off and on again
I have just had exactly the same thing on my daughter's NV3. In this case the lens cover would not open but if you power on the camera with you finger on the display button you can view stored images. If the lens cover is jammed you need to open the casing and maybe take the lens cover assembly apart. You need a very small cross head screwdriver (No.00 should be OK). There are 5 screws in total, 4 screws on the outside of the case (3 plus1 under the headphone socket cap) and 1 inside the battery compartment. You need to remove all 5 to remove the camera front casing. There are some retaining springs top and bottom on the front cover, gently prize off to reveal the lens cover assembly. Check to see if the lens cover will operate by switching on and off - if it works then the camera front casing is preventing it from opening and is probably bent out of shape. A little careful bending back into shape should resolve the problem. If it still does not work with the casing removed, read on. This is the tricky part. There are two extremely small, black retaining screws to the left hand side which hold the assembly onto the lens cover motor. Remove these screws and the front of the lens cover assembly to reveal the lens cover and the back plate of the assembly. Lift off the lens cover and switch on the camera. If the motor is still working, you will see a short black peg move from side to side as you turn the camera on and off. Thoroughly clean the lens cover and assembly, remove any obstruction and replace the lens cover making sure you locate the hole in the lens cover over the motor peg (described above).
The motor is magnetic and will attract the screws away from their holes if you replace the assembly front straight away, so when you replace the front of the lens cover assembly, place the screws in the correct holes before lowering it into place and then screw onto the motor/assembly back. Test that the lens cover opens and closes and replace the Camera front cover taking care not to bend it too much - if this becomes distorted it can stop the lens cover from operating resulting in the same problem.
Apr 01, 2010 | Samsung NV3 Digital Camera
Sony DSC-S750 can only see black on LCD
It seems as though either the lens aperture is not opening or the CCD has failed. You could send it in to us at mackcam.com for an estimate
Dec 31, 2008 | Sony Cyber-shot DSC-S750 Digital Camera
L 100 digital camera is not switching on though the battery is fully charged.
Try removing the battery for a couple of seconds then insert it again. Click on the power button, it should turn on and turn it off again to close the lens.
Oct 17, 2008 | Samsung L200 Digital Camera
Jvc everio hard disk camcorder model# GZ-MG130U
my device lcd is not working properly the screen appears to be black always even though i open lens cover it does not work .......i tried restarting it several times but its not working though......please help me before i throw it awayyy.....!!!
May 12, 2008 | JVC 580136 Camcorder
Coolpix s6 lens cover error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. Its is a step by step solution with images.
Regards Mukesh
Aug 30, 2007 | Nikon COOLPIX S6 Digital Camera
Lens will not come out of camera
There is a workaround for this problem, when the lens cover is open press down on the area of the lens cover on the "s" of Olympus. This can operate the switch that opens the lens etc. The long term fix is to remove the lens cover by removing the 2 screws at the base of the lens cover, take the lens cover off and gently clean around the switch which is behind the "s" of Olympus when the cover is on. I found that the grease/oil Olympus had used on the switch attracted dust etc and by cleaning this off the camera began working. Be careful when taking the lens cover off, there is also a very small metal plate that separates from the lens cover - don't lose it.
Nov 12, 2006 | Olympus MJU 300 Digital Camera
Cameras Logo
57 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
