Question about Mitsubishi WT-46809 46" Rear Projection Television
Krazy colours my tv srarts ok for the first 2 minuts and after that the colours goes krazy at the top and the bottom of the scern, and it arches with very bloury pictur,after 10 minutslots of like spider wepp all over. what is the fix, thank you andy
    Scholar:
  • 131 Answers
Hi if picture is of it could be convergnce ic and that would require a tv tech cost is 250.00.
But the arching noise is usually your high voltage arching from fly back or spiltter you could take off back be careful it is very high voltage only do if you now this stuff, and you will see it arching when it is on and where ever the arc is coming from is the problem the fly back is a large transformer and is black with red high voltage lead coming out of it the leads could be bad to.
the splitter is where all the leads go into from tubes. i hope this helps cost to fix for tv shop is 350.00. thanks doctor video
Posted on May 04, 2008
My display is arched on the top and bottom of display on my sony kp61hs10. Wanted to know a solution to fix this issue.
Convergence output ICs in your tv got defective and causing arched on top/bottom of screen.
Convergence output ICs will be replaced to fix tv problem. There is Convergence Repair Kit available along with photo instructions to fix tv problem and you can attempt to repair tv if you have little experience for that to understand those instructions. Or local tv repair shop will help you to fix the tv problem.
Jul 19, 2010 | Sony KP-61HS10 61" Rear Projection...
Bottom screen colour all mixed up
OMG that happened 2 me once 2 turns out mine was broken the inside screen was busted
Feb 09, 2009 | Nintendo DS Lite Console
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
Arch on top and bottom of tv
You can try adjusting the convergence manually, but this is not a good symptom for your TV to have.
Look at this Quick Start Guide, p. 7:
http://www.p4c.philips.com/files/5/51mp392h_17/51mp392h_17_qsg_aen.pdf
Mar 19, 2008 | Philips Magnavox 51MP392H Rear Projection...
Samsung rear projection tv
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Jan 28, 2008 | Televison & Video
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Arches of words and top and bottom doubled with red words
Convergence mis-alignment = replace convergence amp IC's
Part # STK392-110 sub to upgrade STK394-160E. I use
Hitachi brand for no recalls.....................T.
Oct 31, 2007 | Philips 60PP9202 60" Rear Projection...
Rca tv picture blurry and arched up at bottom
Replace the Sanyo I.C. chip on the heat sink of the power supply convergence board STK730-XXX. Last 3 could be 130/010/020, any will work.
http://www.electronix.com/catalog/product_info.php/cPath/6_308/products_id/9541
Sep 20, 2007 | RCA P60921 60" Rear Projection Television
Sony KP-57WV600 rear projection
sounds like bad CRT, some of these sonys have had defective CRT issues, usually all will come and go sooner or later (all 3 bad), you can pull the speaker grill off(either 2 1/4" screws on bottom or 6 1/4" on back sides) and pull off the Crt box cover (2'X3' piece) and lightly tap the CRT's with tv on, if they flare or get colored streaks in pix they are bad, CALL SONY 800 # and complain, also could adjust G2 (Screen control for color) for short patch. Will need new crts.
Jul 31, 2007 | Sony KP-57WV600 57" Rear Projection...
Red and Green Vertical Arches
CHECK ANY MAGNETIC MATERIALS ON THE CORNER OF THE TV.IT HAPPENS DUE TO MAGNETIC MATERIALS ONLY. SUPPOSE IF IT IS THERE KEEP AWAY FROM THE TV. AND THEN GO TO THE MENU OPTIONS AND SET AUTO DEGAUSSER ON.
Apr 23, 2007 | Philips 32PT8302 32" TV
Mitsubishi WT-46809 46" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
