Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
I need to know what voltage and which polarity I need for a power supply for my wd5000po32 backup disk as I seem to have about a dozen different power transformers on hand. hope you can help
    Guru:
  • 825 Answers
12 VDC for most of the Drives...
Any how have a look at the following link....
http://www.wdc.com/en/products/productcatalog.asp?t=2#jump136
Posted on Aug 22, 2010
IS SONY SPEAKER VGP SP1 INPUT CONNECTION DIFFERENT FROM VGP SP2 SPEAKER CONNECTION
There may be many different power supplies that will work for your speaker system, but they must comply with the following:
1. The output voltage of the power supply should be correct as what the speaker system requires. (seems like 12 V in your case)
2. The specified maximum current output of the power supply should always be a higher value than the Amperage spec of the speaker system.
3. The output wires or pins of the plug on the power supply should correspond to the (+) and (-) on the power input of the speaker system.
A multimeter will come in handy to determine a power supply's output voltage and polarity.
Jan 25, 2016 | Sony Computers & Internet
Need user manual for magnasonic mld1526
I cannot find your part number on Magnasonic's website. Look where the power supply connects to the TV. Usually it will tell the voltage. It will usually also show you the polarity. There maybe a crescent with a dot in the middle. Then it will show + or - for the center. You need to make sure that the new power supply matches the size of the plug, the voltage and the polarity. There are generic adapters available.
Jan 11, 2014 | Televison & Video
I have Bose® Companion® 2 Series I computer speakers. I need to replace the adapater and want to know if speakers accept +ve or -ve polarity voltage. Thanks!
Each device is different.
If the receptacle for the plug is not marked, you have few options.
I suggest the following.
Go buy the exact same setup from a store you can easily return it to.
Take the whole box to Radio Shack and explain that you need a power supply to replace the power supply in the box. They will sell you one, plug and all, for about $10-15.
If you have a DVM (Digital Volt Meter), you can check the voltage and polarity yourself, and buy what you need, test it out, and install it.
--Dave
Feb 08, 2010 | Bose Companion 3 Computer Speakers
Voltage and polarity for Hyundai B70A
Your monitor needs a 12volt 5amp power supply with + 5,5mm tip. Most universal power supplies will not supply enough amps to power an LCD monitor. If you need an adapter we do have them in stock at:
http://www.ccl-la.com/parts_lcd.htm
I hope this helps, if so please rate this solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 16, 2010 | Hyundai ImageQuest B70A 17" LCD Monitor
I need to know what the power input is on this unit. I have one, and a pile of power supplies, but I don't know which one this unit takes!
Well, I think that above the power socket you will read the power rating, at least the voltage. If I see correctly on some picture I found, it says 12V.
Another very important thing is the polarity, which also seems to be shown on a picture near the power socket - whether it's plus on the inside and minus on the outside of the plug, or the other way round.
Once you establish these two facts, you have to look for a power supply that has a proper voltage, a polarity symbol as on the HDD box, and an output current anywhere between 1A to 2.5A
My guess would be 12V, positive inside, and 1.5A output - but that's just a slightly educated guess.
Oct 29, 2009 | SanMax 1 Bay (HD338CB) FireWire (IEEE...
Need to know polarity of power supply for JBL
Look where the plug goes in
There will be a C shape with a dot in the middle. Follow the line attached to the dot and you will see a + or - which is the polarity. Next you need to know Voltage. Look in the same area, or on the label for this info. If there is NO info by the power plug, it might be AC, which has no polarity - just plug it in. The label may have this information and will say something like 12VDC or 12VAC that is the key. DC Matters (+ and -) AC does not.
Mar 26, 2009 | HP JBL Platinum Computer Speakers
Power supply for logitech driving force steering wheel
It's OK to use a power supply with a bigger current capacity than needed. If you find once with, say, 24V and 1.0A then that's usable - the wheel will draw as much as it needs.
Therefore:
Same voltage (24V)
Same or greater current (=>0.75A)
Same polarity (positive centre) __________________
Same as the Momo Racing Black, positive inside, negative outside.
The G25 power supply output is stronger: 24Vdc, 1.75A, same polarity.
As long as output voltage, polarity, amperes and connectors are the same you should be fine using a compatible unit, if you find one. In your case it would be 24V, 0.75A, positive inside, but if I were in you I'd wait for some American Driving Force owner to confirm this to be completely sure. The American psu model should however be GAD-SLU-240A8, 110V input, same PSU as Driving Force Pro. Take a look at this for more info. I received this from a forum with people that had the same issues as you and I hope this helps. It seems like they're saying that a store bought universal power supply may mess up your wheel so be careful. If this helps, please leave feed back. FIXYA!
Feb 14, 2009 | Logitech DRIVING FORCE FEEDBACK STEERING...
Delphi NA10000 Losses Power, Turns OFF
I had the same problem and was able to fix it by finding a replacement cigarette lighter power cord with the same voltage and polarity. Input to cord is 12Volts. Output to GPS is 5Volts, with a positive center post.
larryjm123
PS I need an instruction book and disks (or disk copies) if you know where I can get them. Delphi no longer has them.
May 14, 2007 | Delphi NA10000-11B1 GPS Receiver
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
381 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
