Question about Nikon D200 Body Only Digital Camera
Some humidity (coffee+milk) got inside the camera
By accident some humidity (coffee+milk) got inside the camera, mostly from the battery zone but also a bit into the flash card slot. Not much (I could check and remove any remaining humidity from the two zones) but enough to see moisture under the upper display (and it is still there). And the camera does not switch on.
  • Flaviomkm May 04, 2008
    I have followed your comment. Let's see....
  • 111 Answers
I can only suggest having the camera serviced by a qualified repair shop. This is a nice enough camera that you don't want to risk any further damage. It sounds like there is hope for it, but not a task that I would undertake myself.
Posted on May 16, 2008
Suggest me best Boba Milk Tea Powder?
Bubble milk tea just awesome, I love it. I perches from here Tea Zone Milk Tea Powder 1 32 lbs
Oct 04, 2016 | Home
My dog spilled coffee on my remote n now it works sometimes n doesn't most of the time
Bad dog. If it was just coffee it might work again. Take battery out leave off battery cover put someplace warm like radiator or sunny window for a day or two. It might wok when you put battery back in. If there was milk and or sugar, slim chance.
Apr 08, 2015 | Miscellaneous
Miele 4066 coffee says "fill the milk flask" when its full. How do I replace the sensor? Where do I buy a sensor from?
I have found that most of the time that I see this fault there is a broken wire at the brass contact that the lid of the milk container contacts with. This contact is on the door of the machine on the edge of the oval hole that the milk flask is inserted into. There is a torx 10 screw holding the cover on - remove that screw and you can lift that cover off. You will see a single wire going to the contact. If this wire is in fact making a good connection, then the issue is in the top handle of the milk flask - possibly water inside. I hope that helps.
Jan 10, 2015 | Miele CVA 4066 Stainless Steel
Our PrimaDonna coffee machine doesnt appear to be takeing in any milk from the jug to make latte's or cappuciono's, is there any way of sorting this out ?
Most common cause of this problem is a blockage in the milk jug. First thing you should try is soaking the complete jug top in a quality milk line cleaner (available from specialist coffee machine retailers) for at least an hour and then rinse thoroughly. Then try running a fresh cleaning solution through the jug instaed of milk. Good luck and post again if this doesnt work.
Nov 25, 2010 | DeLonghi Prima Donna Avante ESAM6700...
I have a Delonghi Prima Donna. Blows lots of stem but wont froth milk. The 3 orings have been replaced and the fittings cleaned, but still no frothing. I pulled the lid apart and it seems ok. Any...
Where is it blowing steam from? If it is coming from the milk spout then it most likely that the milk jug is blocked somewhere. If it is coming from where the jug connects to the machine (coupling) then you might need to change the complete coupling (assuming you used the correct orings). The biggest cause of frothing problems with these machines is lack of cleaning of the milk jug. Soak the top in quality milk cleaner for at least an hour and rinse thoroughly. Also run cleaner through it regularly using the milk only function.
Nov 19, 2010 | DeLonghi Prima Donna Avante ESAM6700...
Missing milk frothing tube
should be listed in the owners manual with a part number
Aug 14, 2009 | Coffee Makers & Espresso Machines
Cappuccinatore Milk Temperature on Saeco Royal Pro Machine
Hi
First open it up and run it without any milk attached until just mostly steam is coming thru. Turn off - then drop the tube into a jug of milk which is locted below the outlet. If its steaming, the milk will be heated up ok - it may need flow adjusting - lift the thin 'plug' near the tube up and down to adjust flow. You can add to the froth by lifting the tube out of the milk for a moment then back in again a few times.
To clean the unit just run clean water tru as tho it was milk until it comes out totally clear (about 1/4 cup). For hygiene sake make sure the tube is wiped clean on the outside with a clean paper each and every time when finished.
You can flush your main coffee lines out by making out its doing a large preground coffee - but don't put any preground in.
Select preground - select large coffee and go. Pays also to remove the brew unit and wash in warm water once a week - saves coffee goo building up and causing it to stick.
Feb 21, 2009 | Saeco Royal Professional Espresso Machine
Machine wont draw any milk through
You are not supposed to put milk in the resevoir and run it through the machine. That's likely the problem. But like most parents you will continue to blame your child until he is totally alienated and your relationshio is an empty shell.
Dec 13, 2008 | Breville ESP8XL Espresso Machine
The lens it well not go out
Send to manufacturer for repairs or see if you purchased a Service plan from your retailer.
The most common reason for this happening is:
  1. Sticky substance (Cola/Fruit Drink/Coffee) leaked inside the camera.
  2. Camera was dropped damaging the delicate internal motors.
  3. Normal wear-and-tear.
Repairs on cameras cause by accidents (#'s 1 and 2) can be costly if you do not have a service plan, and the camera is older than 6-9 months.
Nov 06, 2008 | Cameras
Nikon D200 Body Only Digital Camera Logo
49 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
