My acer aspire one is getting slower and sluggish especially after it has been on for a while. applications take ages, internet browsing is slow etc etc. It does start up windows normally. the pc tends to feel quite hot after on the underside after a while, and i never hear a cooling fan go on. does it have a cooling fan at all. could it be hardware failure like the fan is not working or is it a question of software
  • 1,606 Answers
It definitly has a cooling fan so the fan may have failed or it is so clogged with dist hair etc there is no airflow. The air and bottom should be warm to the touch. It should not feel like you are going to burn your hand. That sensation is not as hot as you think but is a good indication for this. You should definitly feel some airflow even if you cannot hear the fan. If you can't feel any airflow then you do have a problem and you shouldn;t use the computer until you get it fixed. The slows are then being caused by the cpu overheating and putting itself into a safe mode to try to prevent damage. Older cpu's would just happily buzz away until they went poof. Newer versions try to protect themselves.
The only software issues that can cause the slows are a massive spyware or virus infection. And the only thing that I've seen not run the fans properlly are some unpatched versions of Linux where they ACPI bus drivers are not quite right. From your description I'd go with the fan/dust as the cause.
What you need to do is to get a flashlight or bright light and look for the opening where you can see the fan blades. Then turn it on and see if there is any movement. When it warms up which should only take a few minutes at most and if at that point you do not see movement the fan is probably defective and you need to shut down and replace it ASAP before using it any more. The fans are not expensive.
If you see the fan move then you probaly have a dirty cooling system. This you can try to clean out with compressed air. You need to stop the fan from rotating and then spray air in from the exit and then back through the inlet. This will loosen up the dust and hair. You may only see what seems like a small puf of dust and thats it. That is all it takes on some systems to overheat. If this helps but doesn;t fix the heating it probably has to come apart and be manually cleaned. Usually there is hair or lint blocking the internal vents.
If you call around local computer shop sthey may be able to fix the fan or clean it out. If you can;t find any you can go to the acer page and go through tech support to find the closest repair depot. You do need to correct this as both the fan or block cooling will eventually cause damage to the cpu by overheating.
Posted on Aug 22, 2010
My wifi is extremely slow on this exact Acer laptop model. I am using Windows 8 64-bit. Updated everything. Wifi is still unusually slow. Please help. (Acer Aspire Q5WPH/T6)
So, If you have internet connection speed problem with your wireless try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from ScanmySpeed.Com before and after following these steps.
Sep 08, 2013 | Acer Aspire Computers & Internet
Acer aspire 1800 running very slow. Can I improve it's performance?
FIXING A SLOW COMPUTER
A slow computer could be caused by a number of things - 1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM. 2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc. 3. Uninstall/remove unused programs, this will also free up hard disk space. 4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it. 5. Install latest Windows updates. 6. Update virus definition files and scan computer for viruses, Trojans, malware etc. 7. Clear the Internet cache for faster browsing. 8. Hard disk maintenance is required at least once a month to keep it functioning efficiently. Run the following programs - Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space. Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
Mar 30, 2013 | Computers & Internet
My acer aspire one laptop is slow in every way in start up, using programs, seeing videos, listening to music, etc. I did a virus scan, and a lot of other things but they dont seem to work.
More RAM would help... But also remove uninstall all software that you don't use anymore. Press Ctrl+Alt+ Del, Open Task manager. Look at what applications are running and what process are running. The more the slower. Try to lower the amount of items that are listed. You can also watch the graphic window that shows your performance. Again chances are everything is max'ed out and the graphice charts are at the top.
Feb 06, 2011 | Acer Aspire One Netbook 8.9" Notebook
While playing facebook games (ie: cafe world, restaurant city, etc) the screen refresh (not sure if this is what it is called) is very slow and there are lengthy delays. This did not occur originally ......
Use Internet Optimizer Tool
The sole objective of an Internet Optimizer tool is to optimize your internetby making change in the operating system configurations. It modifies varioustypes of settings which are directly and indirectly related to your internetperformance.
Download a System Utilities software that includes Internet Optimizer feature.Follow its instructions. If your Facebook is running slow, using an InternetOptimizer tool will be of great help.
Reset Settings
By resetting your web browser settings, you may fix Facebook slow speed. Hereare the steps to do so:
1. Open Internet Explorer.
2. Click Tools ' Internet Options.
3. Click Advanced tab.
4. Click Reset ' Reset.
Clean the Internet Cache
Facebook slow speed occurs when the contents stored in the internet cache arecorrupted. You can delete these contents using a System Cleaner application, orotherwise, through below steps:
2. Click Tools ' Delete Browsing History.
3. Click Delete button.
Disable Browser Extensions
The term browser extensions denote various add-on objects installed for yourweb browser. Many of us install the third party extensions to avail certainfeatures. This problem often results in Facebook slow speed.
Disable third party browser extensions as instructed below.
2. Click Tools ' Manage Add-Ons.
3. Disable the extensions which you do not wish to have enabled.
4. Click Close button.
Clean and Defrag the Registry
Using a System Cleaner application such as RegInOut Cleaner, clean theseentries. In addition to this, defragment it completely.
Aug 02, 2010 | Acer Aspire One PC Notebook
Slow internet browsing
Do you have a good, up-to-date, antivirus program? A virus can take over your machine and send out spam emails, apparently slowing your connection in the process.
Go to AVG Anti-Virus Free Edition to download the free version of AVG.
Apr 13, 2010 | Acer Aspire 3000 Notebook
My computer is too slow to respond when browsing.. only just bought it two weeks ago..
Try resetting internet explorer.Click onThe tool option,go down to internet option go to advance click Restore Defaults on the general page choose delete and delete your history,cookies etc.
Good luck
Oct 22, 2009 | Acer Aspire One PC Notebook
Laptop getting slower
Increase the RAM , delete Unnecessary Applications or Programs, Delete Temporary Files, Internet Files. This will increase the speed of your laptop.
Oct 19, 2009 | Acer Aspire 5100 Notebook
Computers
There are couple of troubleshootig steps which needs to be performed inorder to help get a web page load faster.
Go to Tools/options/ and delete the history, cached pages, cookies, password etc. Might want to ignore favourites.
Also type temp in run command line and then delete the files from the folder. This helps to increase the processing speed as well as the browsing speed of the accer.
This works with IE 6/7/8 though.
Thanks
Jul 08, 2009 | Acer Aspire One AOA110-1588 Notebook
Acer Aspire 5580 suddenly slowed down
Your acer is infected with virus that current antivirus cannot detect. uninstall new application programs that make your computer slower. however if non of those causes; please try to check the memory maybe is not function well. if it is not the cause then; You should reinstall your system to fixed all error on it. ( note: reinstalling will remove some important files and you should back up) Further more; the best thing to do is format the HDD and install the new windows.
Harry: take note: that other causes of the computer slower is the HDD , I encountered 50 times problems that computer become slower bcoz of the hard drive mulfunction. If this is the case you should replace hard drive that is covered with warranty.
Jan 09, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
