Question about Topeak Joe Blow Ace Floor Pump
Cannot get my brand new Topeak Joe Blow Sport pump to lock onto a Presta valve. I have locked the lever down, but it does not hold the valve. It is as if the Presta valve is too small for the pump connection
    Brigadier General:
  • 8,546 Answers
Change the internal parts of the head to adapt to the valve type you're using.
http://www.bikenewyork.org/resources/nuts_bolts/tires.html
Posted on Jan 23, 2011
Which side do I use for a presta valve? How do I close it; yellow lever at a right angle or parallel?
The Side for a presta valve doesn't have what appears to be a pin inside. The schrader side has the pin. Just try putting it on a valve and pumping. If there isn't an air tight fit it means you need to move the leaver to the other position.
Jul 14, 2011 | Topeak Joe Blow Sport Pump
How do i use the schwinn airdriver 1100 pump
This pump is a bit strange to use. The valve in the filler head is odd in that it controls the flow of air in both direction...which is not a great design in my opinion...but it does allow for use in different filling applications. The trick is getting the pump into its different filling "modes"
For a Schrader bike valve:
1. Make sure the pump is in "tire mode" by blowing into the valve with your mouth. If you then pump the handle you should feel air filling your mouth.
2. Put the "locking lever" in the unlocked position, the unlocked position is when the silver metal lever is parallel to the air hose, or said another way it makes an "L" with the air outlet that goes on the tire air filling stem. To verify this is correct, look in the air outlet and move the lever from locked to un-locked, you will see slight change in the diameter of the outlet.
3. Push the air filler hole over the schrader valve really hard and make sure it is seated all the way down. Close the "locking lever" (silver metal lever should now be perpendicular to the air house and be in line with the air outlet... i.e. point straight out away from the tire filler stem.
4. Pump.
For a Presta bike valve:
1. Make sure the pump is in "tire mode" again.
2. Take off plastic caps off presta valves on bike tire.
3. Unscrew the little nut on the presta stem to allow the tire valve to open when pressure is applied (you can test this by pushing the stem in a little and air should escape, the nut holds the valve closed, so it needs to be loosened).
4. Take the adapter from the locking lever (silver metal lever) on the pump and screw it on the presta valve. The adapter is the brass looking thing. Screw the rubber gasketed side down on the presta valve.
5. Press the air pump tire filler outlet onto the adapter.
6. Close the locking lever to seal the filler head on the adapter.
7. Pump.
8. Unlock the locking lever and pull it off quickly.
9. Unscrew the presta adapter and screw down the presta valve nut but just finger tight.
10. Screw on the plastic cover cap for the presta valve.
To Fill a Ball:
1. Twist the ball pin filler out by rotating the gray plastic tab around until the ball pin filler is pointing straight out (in-line with the air hose).
2. Make sure the pump is in "Ball mode" by again blowing into the filler. Sometimes shaking the filler valve really hard is necessary.
3. Put the filler pin into a ball.
4. Pump.
Hope this helps.
Apr 27, 2011 | Schwinn Cycling
I have fitted the pump to the valve and locked it in position. When i start pumping air is coming out the other side and none in the tyre
For starters, I assume that you pushed the lever away from the valve -- if not, that is your problem. Other potential problems are: a worn gasget in the head or a valve stem that is not fitting properly. I had the bad valve stem and when I put in a new tube the problem was solved.
Jan 14, 2011 | Topeak Joe Blow Ace Floor Pump
The pressure gauge on my Topeak Joe Blow Ace floor pump is not working. The pump works fine. How do i take the pump apart and what should I be trying to do to repair?
http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html
  1. Rotate the wheel so the valve is resting just above the floor. Remove the valve cap.
  2. Unscrew the locking nut on the valve stem. Quickly press down the stem to loosen the seal. You should hear air escaping when the stem is pushed in--if you do not, loosen the nut and try again.
  3. Press the pump head onto the valve and flip the locking lever to make a seal. You'll hear air escape, but it should stop after you've locked the lever. If air continues to leak out, remove the pump head and reattach it.
  4. Make two pump strokes and listen for air moving into the tire. If the pump handle becomes hard to press down after only a few strokes, or if the pressure gauge elevates extremely quickly, remove the pump head and repeat Step 3.
  5. Inflate the tire to its recommended pressure. Remove the head by unlocking its lever and quickly pulling it off the valve stem. Secure the valve's locking nut and cap.
Presta Compressor Toolwww.prestaflator.comInflate Road or Mountain Bike Tires Accurately in Seconds!
Read more: How to Inflate a Bicycle Tire With a Presta Valve ' eHow.com http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html#ixzz1Brv5VfAX
Jan 09, 2011 | Topeak Joe Blow Ace Floor Pump
HOW DO I PUT AIR IN A MOUNTAIN BIKE TIRE WITH A PRESTA VALVE WITH A TOPEAK MINI MASTERBLASTER PUMP.
Nov 02, 2010 | Topeak Mini Master Blaster
I have just purchased a Topeak Mountain Morph pump, which can be used with both Presta/Scrader valves. I have a presta valve on my bike, but am not able to inflate my bike. Not sure if I am doing...
Aug 25, 2010 | Topeak Morph Pump
Cannot get my brand new Topeak Joe Blow Sport pump to lock onto a Presta valve. I have locked the lever down, but it does not hold the valve. It is as if the Presta valve is too small for the pump...
They should be designed to fit both styles of valve, but you need to reverse the seal.
you should be able to unscrew the end, remove the sealing rubber and a plastic fitting that pushes on the valve, replace them the opposite way around ,and they will fit the presta.
Aug 22, 2010 | Topeak Joe Blow Sport Pump
Topeak joe blow pumps front but not rear tire
What's different?
http://www.youtube.com/watch?v=Ehf6HL0aLTc
Aug 21, 2010 | Topeak Joe Blow Ace Floor Pump
I cannot figure out how to attach football inflating needle to Topeak Joe blow sport?
Older model pumps screw in. Newer models get inserted and then you either push the lever down or pull it up to lock onto the threaded end of the needle
Sep 27, 2009 | Topeak Joe Blow Ace Floor Pump
Topeak Joe Blow Ace Floor Pump Logo
368 people viewed this question
Top Topeak Cycling Experts
Michial Gueffroy
dante
jimmarmor_ma
Are you a Topeak Cycling Expert? Answer questions, earn points and help others
