Question about Sony UWABR100 Network adapter USB 80211b 80211a 80211g 80211n Pre80211n
When trying to connect to my blu ray player (bdv-e970w) with wireless network adapter (uwa-br100) to my router, it just keeps failing. My Tivo and Wii and 2 computers do not have any trouble connectin
    Guru:
  • 825 Answers
The usb wifi adapter is supposed to be plugged in only in the computer and not in the blu ray players...
Posted on Aug 22, 2010
How to use Sony UWA-BR100 USB Wireless LAN pc
Hi
Required drivers can be downloaded from this program: Driver Update Software. Have a nice day
Peter
Nov 29, 2012 | Sony UWABR100 Network adapter USB ...
Can uwa-br100 work on the pc
Download Drivers from (Windows 7):
http://download.wireless-driver.com/driver/Atheros/Atheros_AR7010_Win_Driver.rar
Windows Vista/XP:
http://www.wireless-driver.com/atheros-ar7010-wireless-usb-windows-driver/
Substitute line "%ATHER.DeviceDesc.7010% = ATHER_DEV_7010.ndi, USBVID_0CF3&PID_7010" with "%ATHER.DeviceDesc.7010% = ATHER_DEV_7010.ndi, USBVID_0411&PID_017F" in all the *.inf file.
Works 100%
Jul 23, 2011 | Sony UWABR100 Network adapter USB ...
How do i connect my laptop to sony bravia using UWA-BR100 ?
Connect the Laptop and TV with a *CROSSOVER* ethernet cable and then enable "Internet Connection Sharing" on the Laptop's "Wireless Network Connection".
To enable "Internet Connection Sharing", open the Network Connections folder ("Start > Run" type NCPA.CPL and click OK). Right click the Wireless Network Connection, select Properties and then the Advanced tab [XP] or Sharing tab [Vista]. Tick the box "Allow other network users to connect through through this computer's internet connection.
Mar 02, 2011 | Sony UWABR100 Network adapter USB ...
Just brought a Sony Bravia HX 800 and added a wireless LAN adapter (UWA-BR100) to get Internet TV. After network set up NOT able to access internet. Message reads Wireless device OK Local Access FAILED...
Hi
I got the Bravia KDL-40EX713 and the uwa-br100 I had massive problems getting it to work with a BT home hub. Eventually I found manual setting that work. Firstly I logged on to the router and went the the advanced settings bit, then I went to the DHCP table that shows all the devices connected. I picked an unused Ip address from the range of existing ones being used (this sort of thing 192.168.1.73)
I then used the following settings for the other fields (I don't think the secondary dns setting is right but it still works)
ip 192.168.1.73
sn mask 255.255.255.0
default gateway 192.168.1.254
primary dns 192.168.1.254
secondary dns 192.168.22.23
If the DNS server ip is wrong then you get local access OK but internet access failed.
Hope this helps.
Ian
Jan 30, 2011 | Apple AirPort Extreme Base Station
Need UWA-BR100 drivers
When I install de UWA-BR100 driver with the fix mentioned above it works but it does not show all wireless networks available. When I look at the hardware properties I see 802.11b Preamble and a mention of Adhoc 11n.
When I look at the properties of my other wireless adapter there is mention in the properties of: 802.11n 20 MHz, 802.11n, 802.11n modus, Adhoc Qos, Adhoc 802.11b/g. This adapter shows more available wireless networks then when I use the UWA-BR100. With the UWA-BR100 I can not see my own wireless network.
Does anyone has a solution for this problem?
Thanks
Sandra.
Jan 23, 2011 | Sony UWABR100 Network adapter USB ...
Can i use any usb wireless adaptor for the bdp-s370?
Interesting timing for your post, as I also just got this player and was sitting down this morning to figure this problem out.. Unbelievably, Sony's UWA-BR100 wireless adapter is the only one that will work. I found the info in several reviews online (including one from an angry guy on Sony's own website) and finally had it confirmed by Sony support. You'd think if they were going to do somehting like this, they'd at least make it clear on the box and in product info, etc. I'm returning my new TV and the Bluray on principle and will go for Samsung,
Oct 30, 2010 | Sony BDPS370 BluRay Player
I have the Sony KDL60EX700 and the Sony UWA-BR100 wireless adapter. The adapter see's my router and has a strong reception (5 bars) but fails on Local access and Internet access. What to do?
I have had this EXACT problem (same models). Turning off the router and letting it restart get the TV going.
Once it is up it will some time loose the internet, and I have to restart the router.
I am working with Sony Support one this issue.
Sep 26, 2010 | Sony UWABR100 Network adapter USB ...
I do not have a phone line to do guided setup. I would like to use a wireless adapter with my home network router but have been unable to buy a compatible one from the tivo.com list locally. Is the list...
You can do the guided setup without a phone line up to the point where it attempts to connect to the network using the wireless adapter. If it successfully connects, then you can continue the guided setup. If it does not successfully connect, then you're stuck until you can. In other words, you don't need the phone line as long as you have a wireless adapter and that adapter can successfully connect to your network and the internet.
I believe that, with the exception of some dicey hacks, you're stuck using the Tivo wireless adapter. The Tivo Community Forum website is a good place to ask questions like this. The site is independent of Tivo, inc. and has a lot of great information.
Hope this helps.
Oct 05, 2009 | Toshiba RS-TX60 DVD Recorder
Sony UWABR100  Network adapter  USB  80211b 80211a 80211g 80211n Pre80211n Logo
1,155 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
